Hi all
At my dashticz dashboard I want to use the streamplayer. It works OK but:
When I pause the stream and I leave the tablet alone for like, a half a hour. If I pick up my tablet up again the streamplayer starts playing again. Maybe it is a feature but I want to turn it off until I start it again manually. Is that possible?
I use the following:
Domoticz 4.11423 at Synology NAS
Python Version: 3.5.1
Dashticz running at Syno too
Samsung SMT550 with fully browser plus.
Thank you
streamplayer autoplay
- Domoticz version: 4.10
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
Re: streamplayer autoplay
Does playing also start at initial start of Dashticz? I guess autoplay is enabled in fully browser plus.twoenter wrote: ↑Saturday 16 May 2020 15:07 Hi all
Thank you
Probably the half hour you mention is the Dashticz refresh interval. You can change the 'dashticz_refresh' parameter in CONFIG.js
Can you disable autoplay in fully browser plus? If not I can add a block parameter.
I changed a few settings in dashticz and fully.
When I turn off the screen and turn it on again, the steam start to play. Even when I paused it before.
When I leave the screen on and dashticz goes into the 'Screensaver mode' and I tap the screen, it starts to play a stream. But this happens after a while. When I tap the screen after a couple of seconds after the screensaver mode has been activated the streamplayer stay paused.
In the right corner I see Streamplayer connecting...
When I am in kiosk mode with fully and I press the home button, it starts to play a stream.
I like to have a autostart disable function. Or please tell me what I have configured wrong.
When I do a fresh start of dashticz it does not start the stream.Does playing also start at initial start of Dashticz? I guess autoplay is enabled in fully browser plus.
Can you check in Fully:
Settings -> Web Content Settings -> Autoplay audio
This should be set to false
- Domoticz version: 4.9700
Did you solve this?
I'm having the same problem.
When opening fully kiosk the stream does not start.
When the motion detection starts the screen again the stream player starts playing
I Checked: Settings -> Web Content Settings -> Autoplay audio
this is disabled.
What else could be the problem?
this is disabled.
Advanced settings -> Resume playback when getting to foreground
Disable this option.
