Unable to update a user variable
duodiscu92
Domoticz version: 4.10717
Post by duodiscu92 »
Hi everyone,
Below is a part of my script_device code in lua where b1 and b2 are user variables
I can easily read them but I cannot change them
b1 = 'Batterie1'
b2 = 'Batterie2'
if (devicechanged[actb1]) then
  print("B1 : " .. tostring(devicechanged[actb1]) .. " User VarB1 = " .. uservariables[b1])
  if( (tostring(devicechanged[actb1]) == "EN SERVICE") and (uservariables[b1] == 0) ) then
    print ("En service et B1 == 0")
    commandArray['Variable:b1'] = '1'
The line
seems to be without effect
An idea ?
Thanks for your help
sieth
Re: Unable to update a user variable
Post by sieth »
if b1 is a string
commandArray[#commandArray+1]={['Variable:b1'] = tostring ('1')}
or if 1b is an integer:
commandArray[#commandArray+1]={['Variable:b1'] = 1}
duodiscu92
Thank you Sieth but I have found just now :
is not allowed, because b1 is not replaced by its value which is "Batterie1"
So the good writing is :
commandArray['Variable:Batterie1'] = '1'
and then it works well.
