Dashticz v3.7.1 beta
Lokonli
Post by Lokonli »
Dashticz v3.7.1 beta is a small update with mainly clock related changes.
New clock: haymanclock
Further,I've copied 'clock' to 'basicclock' and made it responsive.
That means that 'basicclock', 'stationclock', 'flipclock' and 'haymanclock' will automatically scale to the block width.
You can reduce the width of the clock via two parameters:
  • width: Instead of the width of the block the value of this parameter will be used as width of the clock
  • scale: This is a scale factor (0..1) to scale down the width of the clock, relative to the block width
The clocks will center horizontally.
Nefsolive
Re: Dashticz v3.7.1 beta
Post by Nefsolive »
Hello Lokonli,
Thank you, for always innovating.
Krenstik
Post by Krenstik »
Hi, is any simple way to use a flip clock without a seconds? Just hours and minutes?
Lokonli
Post by Lokonli »
Krenstik wrote: Wednesday 23 December 2020 11:44 Hi, is any simple way to use a flip clock without a seconds? Just hours and minutes?
Implemented in latest beta:
Add the block parameter:
   showSeconds: false
Krenstik
Post by Krenstik »
blocks['hodiny'] = { type: 'flipclock', showSeconds: false }
I did this, but I still have a second....
Lokonli
Post by Lokonli »
DId you do 'git pull' first?
Krenstik
Post by Krenstik »
Sorry, what? :-D :)
I have lastest beta updatw, for sure final is:
columns[1] = {}
columns[1]['blocks'] = ['hodiny','venku','spotreba','sunrise',
Lokonli
Post by Lokonli »
I pushed the change at 12:20 today. Did you update after that?
I' still have to increase the version number, I'll do that at the end of the week.
Krenstik
Post by Krenstik »
aaa, o.k. no I have a version from this morning ;-) you are faster than me, also I check a beta manual, and now is a second set there.
Lokonli
Post by Lokonli »
The manual was updated at 12:20 as well :)
Krenstik
Post by Krenstik »
Now is nice ;-)
so as a hint to have in flop design day and weekday? or week? ;)
