OpenZwave broken, devices malfunction
packetloss
Domoticz version: 4.11590
Post by packetloss »
Dear All,
It seems my Zwave devices are horibly broken, so I cannot use my shutters, screens and door/window contacts anymore :(. Please help.
This is not the first time all the zwave devices are out of function, but last two times I just stoped domoticz, removed the domoticz directory and put back a backup. This doesn't work anymore. I am running domoticz beta and I think its the OpenZwave tool / libs that break with updates. Unfortunaly, like I said, putting back a backup doesn't help it back to running. This is what I run now: Version: 2020.2 (build 12451)
The Zwave hardware, as lsusb tells me: Bus 001 Device 006: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
The devices are red:
and the device via Hardware is red:
When rebooting the rasp Pi, or restarting Domoticz, syslog says:
OpenZWave: Exception. Type: 1, Msg: Cannot Load/Read ManufacturerSpecificDB! - Missing/Invalid Config File?, File: /home/pi/build32/open-zwave-read-only/cpp/src/ManufacturerSpecificDB.cpp (Line 74) OpenZWave.cpp:1037
and *that* I don't understand.. as far as I know, there never existed a build32 directory on my Pi for the last whatever years. Why is OpenZwave / Domoticz complaining about it now?
Several reboots of the didn't help. The device exists in raspbian, for years the same:
root@elmo:~# ls -larht /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Oct  6 18:49 /dev/ttyACM0
I tried installing the stable version of Domoticz and importing / restoring the latest database backup, no luck (doesnt supprise, because versions differ). Then I installed a fresh new Domoticz beta version and imported the latest backup of the database, also no luck.
can you please help?? I'd like to close my shutters tonight! :D
mobalang
Re: OpenZwave broken, devices malfunction
Post by mobalang »
today i get the same error.
The file manufacturer_specific.xml was renamed to manufacturer_specific.xml.2.
I stoped domoticz renamed the file and start domoticz again.
vodor
Post by vodor »
Thanks same issue for me today. Seems the latest manufacturer_specific.xml is causing the issue. I copied manufacturer_specific.xml.2 back into manufacturer_specific.xml and now zwave devices works again.
