I have searched already but cannot find a way to get the Type or SubType (e.g. like Switch, Temp, General, etc) of a known Device Idx using LUA-scripting.
How can I retrieve this information?
Thanks in advance,
Kees
Get Device subtype?
- waaren
Re: Get Device subtype?
in dzVentsKeesje wrote: Saturday 19 December 2020 15:53 Hi all,
Thanks in advance,
Kees
return
on =
timer =
'every minute',
execute = function(dz)
item = dz.devices(3)
dz.log(item.name .. ': Type => ' .. item.deviceType)
dz.log(item.name .. ': Type => ' .. item.deviceSubType)
package.path = 'scripts/lua/?.lua;' .. package.path -- prepend to package path to allow use of mudules in scripts/lua
local idx = 3
local port = 8084 -- change to your domoticz port number
local ip = '127.0.0.1' -- or localhost or real domoticz IP (make sure source IP does not require password
local json = '/json.htm?type=devices\\&rid=' .. idx
local url = 'http://' .. ip .. ':' .. port .. json
local function tprint (t, indent, done)
local done = done or {}
indent = indent or 0
for key, value in pairs (t) do
pre = (string.rep (" ", indent)) -- indent it
if type (value) == "table" and not done[value] then
done [value] = true
print (pre .. tostring (key) .. ":");
tprint (value, indent + 2, done)
elseif type(value) == 'function' and not done[value] then
print( pre .. (tostring (key) .. "()"))
pre = pre .. (tostring (key) .. ": ")
print (pre .. tostring(value))
local function osCommand(cmd)
local file = assert ( io.popen(cmd) )
local output = assert ( file:read('*all') )
local rc = { file:close() }
return output, rc[3]
result = osCommand('curl ' .. url )
local JSON = require "JSON" -- use generic JSON.lua
local jsonParse = JSON:decode(result)
-- tprint (jsonParse) -- debug only
local attributes = jsonParse.result[1]
print (attributes.Name .. ': Type => ' .. attributes.Type)
print (attributes.Name .. ': SubType => ' .. attributes.SubType)
Keesje
- Domoticz version: 2020.2
That's lua script is more complicated than expected.
Thanks for your contribution.
Kees
Kees
- waaren
Maybe a bit less if you leave out the tprint function which is only needed when debugging the script and identify all return values from the json?Keesje wrote: Saturday 19 December 2020 22:25 That's lua script is more complicated than expected.
Kees
