Domoticz-Google-Assistant (dzga) Topic is solved
Alexa, Google Home and Siri
spawnol
Re: Domoticz-Google-Assistant (dzga)
Post by spawnol »
This is my configuration..
# Instantly create a public HTTPS URL. Don't have to open any port on router and do not require a reverse proxy.
# When ngrok_tunnel set to True the auth token is required to keep the tunnel alive.
# Create account at ngrok.com and paste the token in this file.
# Ngrok assigns random urls. When server restart the server gets a new url.
ngrok_tunnel: false
ngrok_auth_token: 'auth_token'
# Use SSL encryption in HTTP server if not using ngrok
use_ssl: true
ssl_key: /etc/letsencrypt/live/xxxxxx.duckdns.org/privkey.pem
ssl_cert: /etc/letsencrypt/live/xxxxxx.duckdns.org/fullchain.pem
DewGew
Domoticz version: V4.10618
Post by DewGew »
spawnol wrote: Monday 07 December 2020 21:41 This is my configuration..
ngrok_tunnel: false
use_ssl: true
Make sure you have user permission to read cert and key files
emichiels
Post by emichiels »
emichiels wrote: Monday 30 November 2020 12:47
DewGew wrote: Friday 27 November 2020 17:07
emichiels wrote: Wednesday 18 November 2020 19:47 hi there,
I have been using Domoticz-google-assistant for a long time. A while ago google assistant started saying that domoticz is not accessable at the moment, when i asked to do a task. I'm trying to figure out the problem, I can access access DZGA. over there everything looks fine. But I can't sync the devices. Then it says homegraph API key is invalid. in the past it worked.... homegraph Api is enabled and I have a homegraph API key in my config,yaml.
I don't know how to get this solved.
any idea's?
I think its your smart-home-key.json is not valid or corrupt. Generate a new and replace. If you use smart-home-key.json, homegraph API key is not needed.
DewGew, thanks for your reaction. I tried, but it's not solving the problem.
I regenerated the smart-home-key.json file with this procedure:
Navigate to the Google Cloud Console API Manager for your project id.
Enable the HomeGraph API.
Navigate to the Google Cloud Console API & Services page.
Select Create Credentials and create a Service account key
Create a new Service account
Use the role Service Account > Service Account Token Creator
Click Done
Click on the newly created Email Account under Service Accounts
Add key > create new key
Choose JSON
Click create and download the JSON file.
Upload and Save this in ../Domoticz-Google-Assistant/config folder as smart-home-key.json
after restarting DZGA I tried to update the devices. But it gave:
Page not found!: 403 Client Error: Forbidden for url: https://homegraph.googleapis.com/v1/devices:requestSync
the log file gives:
2020-11-30 12:43:23 - DEBUG - Starting new HTTPS connection (1): raw.githubusercontent.com:443
2020-11-30 12:43:23 - DEBUG - https://raw.githubusercontent.com:443 "GET /DewGew/Domoticz-Google-Assistant/beta/const.py HTTP/1.1" 200 2037
2020-11-30 12:43:23 - DEBUG - Starting new HTTPS connection (1): homegraph.googleapis.com:443
2020-11-30 12:43:23 - DEBUG - https://homegraph.googleapis.com:443 "POST /v1/devices:requestSync HTTP/1.1" 403 None
2020-11-30 12:44:07 - DEBUG - Starting new HTTPS connection (1): raw.githubusercontent.com:443
2020-11-30 12:44:08 - DEBUG - https://raw.githubusercontent.com:443 "GET /DewGew/Domoticz-Google-Assistant/beta/const.py HTTP/1.1" 200 2037
any other idea's?
Solved the problem. After reconnect account from the Home app, it worked again.
Last edited by emichiels on Wednesday 30 December 2020 18:49, edited 1 time in total.
spawnol
Post by spawnol »
DewGew wrote: Tuesday 08 December 2020 16:01
ngrok_tunnel: false
use_ssl: true
$ sudo nginx -t
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
I think it's good.
spawnol
Post by spawnol »
I am really disapointed.. i tried a many times and it doesn't work..
i can't start dzga with nginx... i have reinstalled debian a lot of time but it still doesn't work... :'(
i really don't undestand why because it worked two weeks ago on my raspberry..
pi@raspberrypi:~ $ python3 Domoticz-Google-Assistant/
Loading configuration...
Connecting to Domoticz on http://XXXXXXXXXXX
Service account key is not found. Report state will be unavailable
Using SSL connection
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "Domoticz-Google-Assistant/__main__.py", line 109, in <module>
startServer()
File "Domoticz-Google-Assistant/__main__.py", line 52, in startServer
secure(server)
File "Domoticz-Google-Assistant/__main__.py", line 26, in secure
server.socket = ssl.wrap_socket (server.socket, keyfile=key, certfile=cert, server_side=True, ssl_version=ssl.PROTOCOL_TLSv1_2)
File "/usr/lib/python3.7/ssl.py", line 1216, in wrap_socket
context.load_cert_chain(certfile, keyfile)
PermissionError: [Errno 13] Permission denied
Justintime
Post by Justintime »
spawnol wrote: Sunday 13 December 2020 17:29 I am really disapointed.. i tried a many times and it doesn't work..
startServer()
secure(server)
Got the same log..... i finally got locations to work. so *.ddns.net:port/domoticz. Took me several hours as a noob.
the only part i didnt have is "Service account key is not found. Report state will be unavailable"
I can reach my login screen on the DNS but when i fill in my credentials it wont login.
Also when i tick the box on SSL in the menu it won't stick.
I have filled in my path to the key and certificate. like this /etc/letsencrypt/live/***.ddns.net/privkey.pem
ALso whats that PID file?? is that only when you have installed as a docker?
spawnol
Post by spawnol »
Justintime wrote: Wednesday 16 December 2020 23:23
startServer()
secure(server)
Sorry, maybe i didn't understand but did you solve it ? The issue with the log ?
DewGew we really need your help... :(
Justintime
@spawnol
I am also not in coding.....but its working now!!! I literally jumped 1 meter high of joy. Spent many hours hahaha
Did you change the name of the folder?? "Domoticz-Google-Assistant" if so dont do that.
If you want to reach DZGA on your domain name type in https://your_domain:SSL_port/Domoticz-Google-Assistant/settings
This is my Nginx config
server {
    listen 85 default_server;
    listen [::]:85;
    server_name yourdomain.com;
    #change to match your address
    return 301 https://yourdomain.com$request_uri;
server {
        listen 448 ssl default_server;
        listen [::]:448 ssl default_server;
        ssl_certificate /etc/letsencrypt/live/yourdomain.com/fullchain.pem;
        ssl_certificate_key /etc/letsencrypt/live/yourdomain.com/privkey.pem;
        ssl on;
        ssl_session_cache  builtin:1000  shared:SSL:10m;
        ssl_protocols  TLSv1 TLSv1.1 TLSv1.2;
        ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
        ssl_prefer_server_ciphers on;
        location /domoticz/ {
                rewrite ^/domoticz/?(.*) /$1 break;
                proxy_set_header Host $host;
                proxy_set_header X-Real-IP $remote_addr;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Scheme $scheme;
                proxy_pass http://192.168.1.165:13631; #Local ipno to dzga
                proxy_read_timeout  90;
         location /Domoticz-Google-Assistant/ {
         rewrite ^/assistant/?(.*) /$1 break;
         proxy_pass http://localhost:3030/; #local ipno to dzga
spawnol
Post by spawnol »
and what's your DZGA config ?
Justintime
Strange thing is.... i dont see connected devices when i enter dzga by domain.....when i look internal its showing.
its syncing and thats the most important.
Strang thing i have got still. i have to restart Nginx manually
spawnol wrote: Thursday 17 December 2020 22:12 and what's your DZGA config ?
Armaway:
  lang: nl
  level_synonym:
  - weg und bewachen
  - Level 2
  - SL2
Armhome:
  lang: nl
  level_synonym:
  - zuhause und bewachen
  - Level 1
  - SL1
Camera_Stream:
  Cameras:
    Camera_URL:
 Idx:
  Enabled: false
CheckForUpdates: true
ClientID: xxxxxx
ClientSecret: xxxxxx
Device_Config: null
Domoticz:
  ip: http://internal ip
  password: psswrd
  port: '13631'
  roomplan: '0'
  switchProtectionPass: '1234'
  username: usrname
Image_Override:
  Fan:
  - Fan
  Light:
  - Light
  Media:
  - Media
  - TV
  Outlet:
  - WallSocket
  Speaker:
  - Speaker
  Switch:
  - Generic
Low_battery_limit: 9
PidFile: ''
Scene_Config: null
ang: nl
auth_pass: psswrd
auth_user: usrname
loglevel: Info
logtofile: true
ngrok_auth_token: xxxxx
ngrok_tunnel: false
pathToLogFile: ''
port_number: 3030
ssl_cert: /etc/letsencrypt/live/mydomain.com/fullchain.pem
ssl_key: /etc/letsencrypt/live/mydomain/privkey.pem
use_ssl: false
userinterface: true
spawnol
Post by spawnol »
Justintime wrote: Thursday 17 December 2020 23:02 Strange thing is.... i dont see connected devices when i enter dzga by domain.....when i look internal its showing.
Armaway:
  lang: nl
  level_synonym:
  - weg und bewachen
  - Level 2
  - SL2
Armhome:
  lang: nl
  level_synonym:
  - Level 1
  - SL1
Camera_Stream:
  Cameras:
    Camera_URL:
 Idx:
  Enabled: false
ClientID: xxxxxx
Device_Config: null
Domoticz:
  password: psswrd
  port: '13631'
  roomplan: '0'
  username: usrname
Image_Override:
  Fan:
  - Fan
  Light:
  - Light
  Media:
  - Media
  - TV
  Outlet:
  - WallSocket
  Speaker:
  - Speaker
  Switch:
  - Generic
PidFile: ''
Scene_Config: null
ang: nl
auth_pass: psswrd
auth_user: usrname
loglevel: Info
logtofile: true
ngrok_tunnel: false
pathToLogFile: ''
port_number: 3030
use_ssl: false
userinterface: true
Use_ssl is set to false.. so you are not using your ssl connection .. right ?
Justintime
spawnol wrote: Saturday 19 December 2020 14:24
Armaway:
  lang: nl
  level_synonym:
  - weg und bewachen
  - Level 2
  - SL2
Armhome:
  lang: nl
  level_synonym:
  - Level 1
  - SL1
Camera_Stream:
  Cameras:
    Camera_URL:
 Idx:
  Enabled: false
ClientID: xxxxxx
Device_Config: null
Domoticz:
  password: psswrd
  port: '13631'
  roomplan: '0'
  username: usrname
Image_Override:
  Fan:
  - Fan
  Light:
  - Light
  Media:
  - Media
  - TV
  Outlet:
  - WallSocket
  Speaker:
  - Speaker
  Switch:
  - Generic
PidFile: ''
Scene_Config: null
ang: nl
auth_pass: psswrd
auth_user: usrname
loglevel: Info
logtofile: true
ngrok_tunnel: false
pathToLogFile: ''
port_number: 3030
use_ssl: false
userinterface: true
I am using Nginx reverse proxy. Same as Domoticz..... or is that not sufficient?
spawnol
Post by spawnol »
Justintime wrote: Sunday 20 December 2020 0:33
Armaway:
  lang: nl
  level_synonym:
  - weg und bewachen
  - Level 2
  - SL2
Armhome:
  lang: nl
  level_synonym:
  - Level 1
  - SL1
Camera_Stream:
  Cameras:
    Camera_URL:
 Idx:
  Enabled: false
ClientID: xxxxxx
Device_Config: null
Domoticz:
  password: psswrd
  port: '13631'
  roomplan: '0'
  username: usrname
Image_Override:
  Fan:
  - Fan
  Light:
  - Light
  Media:
  - Media
  - TV
  Outlet:
  - WallSocket
  Speaker:
  - Speaker
  Switch:
  - Generic
PidFile: ''
Scene_Config: null
ang: nl
auth_pass: psswrd
auth_user: usrname
loglevel: Info
logtofile: true
ngrok_tunnel: false
pathToLogFile: ''
port_number: 3030
use_ssl: false
userinterface: true
Nginx proxy manager ?
salmonsalar
Post by salmonsalar »
I have followed the installation and didnt get the ngrok to work so I followed the Nginx reverse proxy Wiki page.
I can access the DZGA settings page from internet and I can find the [test] when I setup a new link in Google Home frome my phone.
I come to the login page at DZGA and I enter the login credentials but then I dont get any further.
Google Home just jumps back to the page where all applications are listed, nothing more happen.
What can be wrong?
pdrobek
Post by pdrobek »
I resolved all issues which was written here before.
Please can you describe how to use imported devices to Google Home via voice call. Always when i try something like "turn the light on" or similar o get answer "device not configured" or jump to web browser
Thank you
twoenter
Domoticz version: 4.10
Post by twoenter »
Does this plugin support the broadcast feature of Google home /nest hub? Or can I implement it by myself via this plugin by sending a text query to the hub?
I want to send spoken notifications to my nest hub when the dryer or washer is done or when there is somebody at the front door. Benefit of the broadcast function is, when there is music or video playing it resumes after the broadcasted message.
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
phuocdai
Post by phuocdai »
Hi everyone,
How the sensor or switch status were report to Google home in real time? If I am opening the Google app and go to page that is showing the light/sensor, then I change status of these by manually, I didn't see any update on Google app.
Loekie63
Post by Loekie63 »
Hello All,
I have a simple doorbell connected to Domoticz via RFLink. In Domoticz it is sortedt as Lamp/Switch. i set switch type to "door bell" in Domoticz but still it shows up as a lamp in "Google Home app" and gets sorted accordingly.
Questions: Can somebody tel me how to change this? Is there something else Google home app can do with this doorbell as only showing on / off?
Thanks in advance.
Justintime
After checking some things i noticed i am running tthe beta version of DZGA.
Cant remember i did that.
So i am running DZGA Version: 1.10.6 beta
How can i switch to the release version of DZGA?
damien60
Post by damien60 »
salmonsalar wrote: Monday 28 December 2020 1:28 Hello,
What can be wrong?
Hello, I have a similar problem. I cannot retrieve devices in google HOME.
I think I have problem with token (access.log 401):
[02/Feb/2021:13:17:41 +0100] "POST /dzga/token HTTP/1.1" 401 188 "-" "OpenAuth"
I have no smart-home-key.json but it works with ngrok. (with correct url in smarthome, oauth & token)
I configured reverse proxy in nginx to access to dzga with https://<public_url>:4433/dzga/settings
My box redirect 4433 to nginx:443 and nginx redirect /dzga/ to localhost:3030 and remove /dzga in url.
I found one bug and I fixed it : https://github.com/DewGew/Domoticz-Goog ... issues/244
I can access to https://<public_url>:4433/dzga/ from Internet and I can login with HOME app.
But after that, there is no association with my account, no devices listed and it returns to the list of services available.
My certificate is no more self-signed (I used another ACME client with standalone mode : https://github.com/acmesh-official/acme.sh)
What can I check? It works with ngrok...
Where can I check logs from google?
