I just want a lua script that will execute a script after turning on an device..
For example, if an device has turned on, it has at least the need for 30 seconds to connect to wi-fi, after that i can execute my script.
Is it possible to add a sleep in lua, or something?
Thanks!!
Howto? Device ON, execute script after x seconds Topic is solved
- waaren
Re: Howto? Device ON, execute script after x seconds
In classic Lua you need a dummy device to do this because the script will be canceled by domoticz after 10 seconds. In dzVents (100% Lua) you could do it without an extra dummy, using emitEvent() triggering a customEvent.BarryT wrote: Saturday 12 December 2020 8:59 For example, if an device has turned on, it has at least the need for 30 seconds to connect to wi-fi, after that i can execute my script.
BarryT
- Domoticz version: 2024.3
Thanks for answering!waaren wrote: Saturday 12 December 2020 10:12In classic Lua you need a dummy device to do this because the script will be canceled by domoticz after 10 seconds. In dzVents (100% Lua) you could do it without an extra dummy, using emitEvent() triggering a customEvent.BarryT wrote: Saturday 12 December 2020 8:59 For example, if an device has turned on, it has at least the need for 30 seconds to connect to wi-fi, after that i can execute my script.
Could you share the script for a classic lua then?
And what is the meaning of the dummy device compared to a normal device to do this?
- waaren
A dummy (virtual) device does not send a real command to a physical device.BarryT wrote: Saturday 12 December 2020 17:22 What is the meaning of the dummy device compared to a normal device to do this?
Could look like thisCould you share the script for a classic lua then?
local myWifiConnectedDevice = 'WifiConnectedDevice' -- change to name of your wifi connected device
local dummy = 'virtual switch' -- change to name of your virtual (dummy) helper device
local delay = 30 -- set to required delay
local debug = true -- set to false when everything is OK
local function dPrint(data)
local function tPrint (t, indent, done) -- table print function for debugging purposes
local done = done or {}
indent = indent or 0
for key, value in pairs (t) do
pre = (string.rep (" ", indent)) -- indent it
if type (value) == "table" and not done[value] then
done [value] = true
print (pre .. tostring (key) .. ":");
tPrint (value, indent + 2, done)
elseif type(value) == 'function' and not done[value] then
print( pre .. (tostring (key) .. "()"))
pre = pre .. (tostring (key) .. ": ")
print (pre .. tostring(value))
if debug and type(data) ~= 'table' then
print('Debug: ' .. tostring(data) )
elseif debug then
tPrint(data)
local function state (name)
if devicechanged[name] then return devicechanged[name], true
elseif otherdevices[name] then return otherdevices[name], false
else return false, false
local function isChanged(name)
return devicechanged[name] ~= nil
local function afterSec(switch, action, delay)
commandArray[switch] = action .. ' AFTER ' .. delay
dPrint(switch .. ' will be set to ' .. action .. ' after ' .. delay .. ' seconds.')
if isChanged(myWifiConnectedDevice) and tostring( state(myWifiConnectedDevice) ) == 'On' then
afterSec(dummy, 'On', delay )
return
elseif isChanged(dummy) and tostring( state(dummy) ) == 'On' then
dPrint(devicechanged[dummy])
return
-- Rest of your script (to be executed 30 seconds after 'myWifiConnectedDevice' is activated below this line.
BarryT
Thanks Waaren, works perfect!waaren wrote: Saturday 12 December 2020 21:13A dummy (virtual) device does not send a real command to a physical device.BarryT wrote: Saturday 12 December 2020 17:22 What is the meaning of the dummy device compared to a normal device to do this?Could look like thisCould you share the script for a classic lua then?Code: Select all
local myWifiConnectedDevice = 'WifiConnectedDevice' -- change to name of your wifi connected device local dummy = 'virtual switch' -- change to name of your virtual (dummy) helper device local delay = 30 -- set to required delay local debug = true -- set to false when everything is OK commandArray = {} local function dPrint(data) local function tPrint (t, indent, done) -- table print function for debugging purposes local done = done or {} indent = indent or 0 for key, value in pairs (t) do pre = (string.rep (" ", indent)) -- indent it if type (value) == "table" and not done[value] then done [value] = true print (pre .. tostring (key) .. ":"); tPrint (value, indent + 2, done) elseif type(value) == 'function' and not done[value] then print( pre .. (tostring (key) .. "()")) else pre = pre .. (tostring (key) .. ": ") print (pre .. tostring(value)) end end end if debug and type(data) ~= 'table' then print('Debug: ' .. tostring(data) ) elseif debug then tPrint(data) end end local function state (name) if devicechanged[name] then return devicechanged[name], true elseif otherdevices[name] then return otherdevices[name], false else return false, false end end local function isChanged(name) return devicechanged[name] ~= nil end local function afterSec(switch, action, delay) commandArray[switch] = action .. ' AFTER ' .. delay dPrint(switch .. ' will be set to ' .. action .. ' after ' .. delay .. ' seconds.') end if isChanged(myWifiConnectedDevice) and tostring( state(myWifiConnectedDevice) ) == 'On' then afterSec(dummy, 'On', delay ) return elseif isChanged(dummy) and tostring( state(dummy) ) == 'On' then dPrint(devicechanged[dummy]) else return end -- Rest of your script (to be executed 30 seconds after 'myWifiConnectedDevice' is activated below this line. return commandArray
