I use the zzh stick. Flashing is a breeze and it's nicely powerful.BertB wrote:True, but now I have to decide to buy an USB Zigbee device.
Can you recommend one?
Can you pm me if you still have the problem, I need too the device JSON, if it work with phoscon I need to work with domoticz too.
It is now working perfectly with the beta code! Great job finding it so quickly! Many thanks.Thorgal789 wrote: ↑Friday 04 December 2020 17:13Can you pm me if you still have the problem, I need too the device JSON, if it work with phoscon I need to work with domoticz too.
Never mind I took it back to lidl and got my money back.
Check this viewtopic.php?t=33841AndrewmHull wrote: ↑Tuesday 08 December 2020 10:27 Hi,
I am exploring the whole zigbee side of things.. I currently have a mixture of RF 433mhz and Sonoff basic (tasmota) devices all happily working with Domoticz....
a few weeks ago i got the Sonoff Zigbee bridge which I flashed with Tasmota. I successfully paired some Sonoff Zigbee temperature sensors and use rules to send the info to Domoticz... this all works ok.
So I have now bought some of Lidl Smart plugs.
last night I got the Plugs to pair with the Sonoff Zgbee bridge.. I can issue the ZBsend command (from the tasmota console)to turn it on or off. this works ok.
Is there a way to send information from Domoticz to turn on plug? maybe MQTT...
any hints and Tips greatly received.
Cheers
Andy
Thanks Waltervl,waltervl wrote: ↑Tuesday 08 December 2020 11:05Check this viewtopic.php?t=33841AndrewmHull wrote: ↑Tuesday 08 December 2020 10:27 Hi,
Cheers
Andy
Thorgal789 wrote: ↑Wednesday 09 December 2020 16:45 @BertB wich one deconz have you ? You need the last one for sensors
You need too the beta version of the domoticz plugin for some bulbs (but it s color problem, not inclusion one, you will see later).
But bulbs are working natively, wich one bulb have you ? What if your reset procedure for the bulb ?
It mean it have worked or not ?Ok, i did reset the bulb aan IT was in connect mode.
No, IT did not.Thorgal789 wrote: ↑Thursday 10 December 2020 17:20 2.07 beta is fine for door sensor > https://github.com/dresden-elektronik/d ... ssues/3767
Do you already have a working device on the conbee, or it s your first one ?When you power up a device for the first time, the light will start flashing. At this point, you can not pair yet.
The best thing to do is to reset it first by switching on/off or remove/insert power 3 times quickly. Just like with the Trådfri stuff (although the latter requires 6 power cycles).
Now you have to wait a few minutes for the device to stop flashing. I think the flashing is a pairing mode for the Lidl gateway.
After the flashing stops, you can pair it like any other Trådfri device using the IKEA app. However, make sure you are several meters away from any Trådfri device, since the remotes heavily prefer those over the Lidl devices, and will try to pair with them instead.
Do you mean, I have to use the Ikea app to pair a LIDL bulb to a ConBee II ?Thorgal789 wrote: ↑Thursday 10 December 2020 19:04 From the manual with your device, it need to blink after the procedure, you have the blink ?
From a forum, they work exactly like the ikea one (and are compatible)Do you already have a working device on the conbee, or it s your first one ?When you power up a device for the first time, the light will start flashing. At this point, you can not pair yet.
