Select problem  [Solved]
kroonp
Select problem
Post by kroonp »
Hello
I am struggling with the following problem. I have an ELRO switch with 4 positions On and Off. With this switch I want to switch on 4 different scenes. I have already tried it in different ways but they don't work or they influence each other. I am probably using the wrong structure. Who can help me on my way.
Peter
          devices = {
             'Switch1_1',
             'Switch1_2',
             'Switch1_3',
             'Switch1_4'
    	    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is OK
        marker = 'Slkmr_switch',
	execute = function(dz, device, triggerInfo)
	    local Automaat = dz.devices('Automaat')
        local Slapen = dz.devices('Slapen')
        if(Automaat.state=='On') then
            if  ( device . name  ==  'Switch1_1'  and  device .name. state=='On')  then
                dz.scenes('sc_bedverlichting_100').switchOn()
         if  ( device . name  ==  'Switch1_2'  and  device .name. state=='On')  then
        	    dz.scenes('sc_bedverlichting_50').switchOn()
         if  ( device . name  ==  'Switch1_3'  and  device .name. state=='On')  then
        	    dz.scenes('sc_bedverlichting_10').switchOn()
         if  ( device . name  ==  'Switch1_4'  and  device .name. state=='On')  then
        	    dz.scenes('sc_bedverlichting_tv').switchOn()
            if  ( device . name  ==  'Switch1_1'  and  device .name. state=='Off')  then
        	    dz.scenes('sc_bedverlichting_uit').switchOn()
Re: Select problem
kroonp wrote: Thursday 10 December 2020 22:01 Hello
I don't know if the syntax errors were the only reason but can you try below script?
If not yet OK then please include log of the execution and show what you expected and what actually happened.
return
    on =
        devices =
            'Switch1_*',
    logging =
    execute = function(dz, device)
        if Automaat.state == 'On' then
            if device.name == 'Switch1_1' and device.state == 'On' then
            elseif device.name == 'Switch1_2' and device.state == 'On' then
            elseif device.name == 'Switch1_3' and device.state == 'On' then
            elseif device.name == 'Switch1_4' and device.state == 'On' then
            elseif device.name == 'Switch1_1' and device.state == 'Off' then
kroonp
Re: Select problem  [Solved]
Post by kroonp »
Hello waaren
Thank you very much for the quick answer. Your solution works fine. (As always). I have learned a lot again. Thank you for doing this work to help people move forward.
Have a nice day.
Peter
