2020-12-05 17:32:34.728 Error: dzVents: Error: (3.0.2) dumpAttributes: An error occurred when calling event handler Script #1
2020-12-05 17:32:34.728 Error: dzVents: Error: (3.0.2) dumpAttributes: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:57: attempt to call a nil value (field 'osCommand')
In your dzVents version (3.0.2) the osCommand function was not part of dz.utils yet. Can you do it again with this modified identification script where I added dz.utils.osCommand locally?
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:36:39.750 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:36:39
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:36:39.751 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:36:39.801 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:36:39.801 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:36:39.801 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:36:39.802 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:36:41.043 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {"1"}
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:36:41.044 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:36:41.104 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:41.104 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:36:41.104 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:36:41.104 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:36:41.104 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:36:41.104 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:36:41.104 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 1
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 1
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:36:40
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:36:41.105 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:36:41.106 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:41.106 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:36:41.155 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:36:41.155 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:36:41.155 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:36:41.155 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:36:43.915 (Module Rfxcom) RFY (La Porte du Garage)
2020-12-05 22:36:43.907 Status: User: Admin initiated a switch command (52/La Porte du Garage/Stop)
2020-12-05 22:36:44.036 Status: dzVents: Info: Handling events for: "La Porte du Garage", value: "Stopped"
2020-12-05 22:36:44.036 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:36:44.036 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:44.036 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:36:44.037 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:36:44.037 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:36:44.037 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:36:44.037 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {}
2020-12-05 22:36:44.037 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:36:44.037 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:36:44.037 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:36:44.094 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 2020-12-05 22:36:43
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 6
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 0.0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 1.0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 0.0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 1.0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> nil
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:36:44.095 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:36:44.096 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:44.141 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:36:44.141 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:36:44.141 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:36:44.142 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:36:49.153 (Module Rfxcom) RFY (La Porte du Garage)
2020-12-05 22:36:49.146 Status: User: Admin initiated a switch command (52/La Porte du Garage/On)
2020-12-05 22:36:49.277 Status: dzVents: Info: Handling events for: "La Porte du Garage", value: "Closed"
2020-12-05 22:36:49.278 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {}
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:36:49.278 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:36:49.339 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 3
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 2020-12-05 22:36:49
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 6
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 0.0
2020-12-05 22:36:49.340 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 1.0
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 0.0
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 1.0
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 0
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> nil
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:36:49.341 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:36:49.389 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:36:49.389 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:36:49.389 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:36:49.389 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:36:56.510 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:36:56.510 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:36:56.570 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 1
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 1
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:36:56
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:36:56.571 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:36:56.627 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:36:56.627 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:36:56.627 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:36:56.627 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:36:56.629 Status: dzVents: Info: Handling events for: "Porte Garage Sensor", value: "Closed"
2020-12-05 22:36:56.629 Status: dzVents: Info: quiet gate: ------ Start internal script: Controle sensor garage: Device: "Porte Garage Sensor (Conbee)", Index: 148
2020-12-05 22:36:56.629 Status: dzVents: Debug: quiet gate: State of Porte Garage Sensor is Closed
2020-12-05 22:36:56.629 Status: dzVents: Debug: quiet gate: OpenURL: url = http://127.0.0.1:8080/json.htm?type=command¶m=udevice&nvalue=0&svalue=0&idx=52
2020-12-05 22:36:56.629 Status: dzVents: Debug: quiet gate: OpenURL: method = GET
2020-12-05 22:36:56.629 Status: dzVents: Debug: quiet gate: OpenURL: post data = nil
2020-12-05 22:36:56.629 Status: dzVents: Debug: quiet gate: OpenURL: headers = nil
2020-12-05 22:36:56.629 Status: dzVents: Debug: quiet gate: OpenURL: callback = nil
2020-12-05 22:36:56.629 Status: dzVents: Info: quiet gate: ------ Finished Controle sensor garage
2020-12-05 22:36:56.630 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-12-05 22:36:56.791 Status: dzVents: Info: Handling events for: "La Porte du Garage", value: "Stopped"
2020-12-05 22:36:56.791 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:36:56.791 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:56.791 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:36:56.791 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:36:56.791 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:36:56.791 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:36:56.791 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {"0"}
2020-12-05 22:36:56.791 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:36:56.792 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:36:56.792 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:36:56.849 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:36:56.849 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:36:56.849 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:36:56.849 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:36:56.849 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:36:56.849 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:36:56
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:36:56.850 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:36:56.851 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:36:56.851 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:36:56.851 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:36:56.851 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:36:56.896 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:36:56.896 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:36:56.896 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:36:56.897 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:39:03.998 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:39:04.056 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:39:03
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:39:04.057 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:39:04.114 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:39:04.114 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:39:04.115 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:39:04.115 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:39:04.117 Status: dzVents: Info: Handling events for: "Porte Garage Sensor", value: "Open"
2020-12-05 22:39:04.117 Status: dzVents: Info: quiet gate: ------ Start internal script: Controle sensor garage: Device: "Porte Garage Sensor (Conbee)", Index: 148
2020-12-05 22:39:04.117 Status: dzVents: Debug: quiet gate: State of Porte Garage Sensor is Open
2020-12-05 22:39:04.117 Status: dzVents: Debug: quiet gate: OpenURL: url = http://127.0.0.1:8080/json.htm?type=command¶m=udevice&nvalue=1&svalue=1&idx=52
2020-12-05 22:39:04.117 Status: dzVents: Debug: quiet gate: OpenURL: method = GET
2020-12-05 22:39:04.117 Status: dzVents: Debug: quiet gate: OpenURL: post data = nil
2020-12-05 22:39:04.117 Status: dzVents: Debug: quiet gate: OpenURL: headers = nil
2020-12-05 22:39:04.117 Status: dzVents: Debug: quiet gate: OpenURL: callback = nil
2020-12-05 22:39:04.118 Status: dzVents: Info: quiet gate: ------ Finished Controle sensor garage
2020-12-05 22:39:04.119 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-12-05 22:39:04.303 Status: dzVents: Info: Handling events for: "La Porte du Garage", value: "Open"
2020-12-05 22:39:04.303 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {"1"}
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:39:04.303 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:39:04.361 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:04.361 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 1
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 1
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:39:04
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:39:04.362 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:39:04.363 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:39:04.363 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:39:04.363 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:39:04.363 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:39:04.363 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:39:04.363 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:39:04.363 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:39:04.409 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:39:04.409 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:39:04.409 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:39:04.410 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:39:22.133 (Module Rfxcom) Temp (T° Chambre Marie)
2020-12-05 22:39:28.067 Status: dzVents: Info: Handling events for: "La Porte du Garage", value: "Open"
2020-12-05 22:39:28.067 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:39:28.067 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:28.067 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:39:28.067 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:39:28.067 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:39:28.067 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:39:28.067 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {"1"}
2020-12-05 22:39:28.068 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:39:28.068 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:39:28.068 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:39:28.125 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:39:27
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:39:28.126 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:39:28.127 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:28.127 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:39:28.174 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:39:28.174 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:39:28.174 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:39:28.174 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:39:28.317 Status: dzVents: Info: Handling events for: "La Porte du Garage", value: "Stopped"
2020-12-05 22:39:28.317 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {"0"}
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:39:28.317 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:39:28.375 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:39:28.375 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:39:28.375 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:39:28.375 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:39:28.375 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 2020-12-05 22:39:27
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 6
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 0.0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 1.0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 0.0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 1.0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:39:28.376 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> 0
2020-12-05 22:39:28.377 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:39:28.377 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:39:28.377 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:39:28.377 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:39:28.377 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:39:28.377 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:39:28.424 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:39:28.424 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:39:28.424 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:39:28.424 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
2020-12-05 22:41:17.698 Status: User: Admin initiated a switch command (52/La Porte du Garage/On)
2020-12-05 22:41:17.860 Status: dzVents: Info: Handling events for: "La Porte du Garage", value: "Closed"
2020-12-05 22:41:17.861 Status: dzVents: Info: dumpAttributes: ------ Start internal script: Script #1: Device: "La Porte du Garage (Module Rfxcom)", Index: 52
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: attribute -> value (dzVents)
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: type, subType -> RFY, RFY
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: switchTypeValue -> 3
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: adapters -> {"Switch device adapter"}
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: rawData -> {}
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: hwType -> RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, 1
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: levelNames -> nil
2020-12-05 22:41:17.861 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: modes -> nil
2020-12-05 22:41:17.919 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage
2020-12-05 22:41:17.919 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: field -> value (database)
2020-12-05 22:41:17.919 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: ID -> 52
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: HardwareID -> 6
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: DeviceID -> 000203
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Unit -> 1
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Name -> La Porte du Garage
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Used -> 1
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Type -> 26
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SubType -> 0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SwitchType -> 3
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Favorite -> 1
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: SignalLevel -> 12
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: BatteryLevel -> 255
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: nValue -> 3
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: sValue -> 2020-12-05 22:41:17
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastUpdate -> 6
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Order -> 0.0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue -> 1.0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti -> 0.0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjValue2 -> 1.0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: AddjMulti2 -> 0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam1 -> 0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: StrParam2 -> 0
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: LastLevel -> nil
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Protected -> nil
2020-12-05 22:41:17.920 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: CustomImage -> nil
2020-12-05 22:41:17.921 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Description -> nil
2020-12-05 22:41:17.921 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Options -> nil
2020-12-05 22:41:17.921 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Color -> nil
2020-12-05 22:41:17.921 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: system -> value (versions)
2020-12-05 22:41:17.967 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: OS -> Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
2020-12-05 22:41:17.967 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Domoticz -> 2020.2
2020-12-05 22:41:17.967 Status: dzVents: !Info: dumpAttributes: 52: La Porte du Garage: Dzvents -> 3.0.2
2020-12-05 22:41:17.967 Status: dzVents: Info: dumpAttributes: ------ Finished Script #1
samourai47 wrote: Saturday 05 December 2020 22:43
the 3rd.... Door garage is close but on the device is noted Stopped, and i push the close button on domoticz
Your type of blind does react just a bit different to the nValue in the API call..
return
on =
devices =
'Porte Garage Sensor (Conbee)',
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all is OK
marker = 'quiet gate',
execute = function(dz, item)
local gate = dz.devices('La Porte du Garage')
local opened = 1
local closed = 3
local stopped = 0
function updateQuiet(id, nValue, sValue)
local url = dz.settings['Domoticz url'] ..
'/json.htm?type=command¶m=udevice' ..
'&nvalue=' .. nValue ..
'&svalue=' .. sValue ..
'&idx=' .. gate.id
dz.openURL(url)
dz.log('State of ' .. item.name .. ' is ' .. item.state, dz.LOG_DEBUG)
if item.active then
updateQuiet(gate.id, opened, 0) -- change to closed if action is reverted
updateQuiet(gate.id, closed, 0) -- change to opened if action is reverted
Hello
I confirm my doubt. When i use Goggle Home with DGZA if the door for example is open with telecommande the device is update to open, but if i want closed with GH it say me that the device is already closed.... And Vice versa
