domoticz in synology as package! Available now.
- remb0
thanks to ny-hardcore
r2105: cedarview:
https://dl.dropboxusercontent.com/u/626 ... 105-10.spk
armada370:
All credits https://github.com/jorikcaljouw he fixed the spkrc thinks for domoticz.
the ftdi driversfor the USB receiversare here:
http://forum.synology.com/enu/viewtopic ... d3&start=0
r2105: cedarview:
armada370:
mschut
- Domoticz version: V3.5613
Interesting development!
Is compatibility for the 213+ and/or 207 also coming? These two didn't work for me....
steef84
- Domoticz version: DS213+
@mrschut.
Running this way on DS213+ qoriq for a few months now. No issues for me. Posted them on my dropbox https://www.dropbox.com/sh/891tnhldtx9y ... DxkIa?dl=0
- Stefan
mschut
Still small problem.
The driver package doesn't install. No drivers for 5.1
Any ideas?
Any ideas?
steef84
FYI: im still on DSM 5.0. You may try the "quick fix" on the last page from the official topic from the ftdi drivers also mentioned by Rembo.
Probably DSM 5.1 is also the reason from not starting package on your system.
- Stefan
mschut
Will read the quick fix.
Not starting was solved by uninstall and reinstall. I had an older version still installed and upgraded, this caused probably the issue. Domoticz now running, hoeray! Now trying to add usb drivers.
mschut
Update: installed the Domoticz package, and the USB drivers for DSM5.1
However, in Domoticz is says "Error: RFXCOM: Error opening serial port!"
What's wrong? Is it "plug and play" the package connected with the drivers? Does it for example matter in which USB port I connect my RFXCOM? Should I configure some more? I am so close!
Schim57300
- Domoticz version: 2024.7
Succeeded in installing Domoticz on a DS410J with DSM 5.0-4493 Update 3
I'm using it with a RFXTrx433E tranceiver.
I used to have the same error message as yours until I installed the spk below
http://lebovitz.co.il/SPK/UsbSerialDrivers_2.0.0.spk
After installing this package, the RFXTrx433E worked correctly.
Maybe these drivers would help you.
Keep us in touch
Schim'
Keep us in touch
Schim'
Eric
Raspberry 3b+
Debian GNU/Linux 11 (bullseye)
Mobile App : Home made progressive web app
RFXTrx433E transceiver (for my RTS devices)
Somfy Tahoma Switch (for my IO devices)
Aeon Labs Z-Stick S2
Raspberry 3b+
- sincze
- Domoticz version: 2024.4
Any suggestions I should know before installing this on a DS412+ without breaking it?
I also have a DS211 so it will be interesting
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mschut
I am running DSM 5.1 so I need UsbSerialDrivers_3.0.0.spk, it sounds like a issue in this version for 5.1. Anyone with DSM5.1 who got it running?Schim57300 wrote:I used to have the same error message as yours until I installed the spk below
http://lebovitz.co.il/SPK/UsbSerialDrivers_2.0.0.spk'
Schim57300
I didn't succeed in building Domoticz on my DS410jsincze wrote:Any suggestions I should know before installing this on a DS412+ without breaking it?
I had to ask developers for a spk file. But the latter depends on the CPU of your NAS
You can find the kind of CPU :
=> http://forum.synology.com/wiki/index.ph ... y_NAS_have
Eric
Raspberry 3b+
Raspberry 3b+
- sincze
Tnx. I'll have a look. Should hopefully be simpleSchim57300 wrote:I didn't succeed in building Domoticz on my DS410jsincze wrote:Any suggestions I should know before installing this on a DS412+ without breaking it?
I also have a DS211 so it will be interesting![]()
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
tehnoinstyle
- Domoticz version: 2.0.2276
Prompt please, whether there is a complete package for the Synology DS-214Play? And whether a package for installation on Qnap TS-119 arm5?
I have installed packages Openremote and SynoZwave (on Synology), and Openremote (on Qnap), with Z-Wave stick AeonLab S2 and Z-wave devices. All packages are working. Would like to try Domoticz, but do not really understand how to do it. In compiling and Linux is not strong. Maybe there is a ready-made bags, or someone will do it.
Thank you.
Thank you.
Syn DS3615xs DMS 5.1-5022U5(xpenology;Intel2700MUD;4GbRAM;2*3TbHDD->JBOD)
Syn DS3615xs DMS 5.2-5592(xpenology;asus p8-z68;I3;4GbRAM;6*2TbHDD->JBOD)
Z-Wave Aeon Labs Z-Stick S2->OpenRemote;Domoticz
sarakha63
To have a completely working domoticz whatever synology you use.
I strongly advice using a debian chroot. With this i have domoticz running since 5 months. With all update and all functions.
It takes some couple hours to configure the debian but it worths it as once it is done you can do whatever you want and you are not anymore spk dependant or else.
I guarantee you everyone. This really worths it.
My domoticz : DS 412+ synology/ Domoticz beta/AEON stick 2/Rfxtrx433E/Harmony Hub/Fibaro motions/Fibaro RGBs/Oregon sensors/Withings board/Fibaro Dimmers/Philio 3in1/Chacon Plugs/Phenix Plugs/Netatmo Thermostat/Xbmc/lg LM55860V/Yamaha rxv/ SARAH
tehnoinstyle
Thanks for the answer. But unfortunately, I do not have the knowledge to do it. For me that linux that Debian, very little knowledge. I saw on the forum ready-made package, but for other architectures. I tried https://dl.dropboxusercontent.com/u/626 ... 105-10.spk , but it does not install.
tehnoinstyle
It is from here?sarakha63 wrote: I strongly advice using a debian chroot.
https://synocommunity.com/package/debian-chroot
If possible, please describe in detail the installation process Domoticz on DS-214Play or DS-3612xs.
steef84
@sarakha63: i love to get debian chroot fully functional, however some Synology cpu's aren't fully supported by debian chroot. I previously tried multiple times but at least qoriq cpu is not and probably will never get full supported. apt-get isnt even functional. So for my Synology DS213+ the package for spksrc adapted by Jorik is heavily appreciated. For me its the only way to have Domoticz working on Syno.
- Stefan
steef84
Have you managed to solve this? For my 213+ on DSM5.0 its just plug and play. Will only upgrade to DSM5.1 when Domoticz will not failmschut wrote: What's wrong? Is it "plug and play" the package connected with the drivers? Does it for example matter in which USB port I connect my RFXCOM? Should I configure some more? I am so close!
- Stefan
tehnoinstyle
Good day.
Can anyone tell whether there is a package Domoticz for Synology ds214play or ds3612? Or explain step by step how to properly install. All drivers have been installed, as set SynoZwave package.
Help please.
Help please.
