Zigate and Aqara Relay Error OUT OF RANGE
pfloryann
Domoticz version: 2025.2
Post by pfloryann »
From a while i have a strange error from Aqara Relay (i have 2 relays same model in 2 different places of the house). Every few minutes i recived in Domoticz logs error OUT of range from every relays but ONLY ON CHANNEL 1. When it occurs this error all my automation doesn't work or they have a big delay 5-10 seconds. I checked the level signal for every relay is 3 for channel 1 and 4 or better on channel 2. I don't know what is the problem.
2020-11-30 16:04:00.286 Error: (Zigate) ReadCluster 0b04 - 59c0/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:06:40.622 Error: (Zigate) ReadCluster 0b04 - c023/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:19:00.684 Error: (Zigate) ReadCluster 0b04 - 59c0/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:21:41.018 Error: (Zigate) ReadCluster 0b04 - c023/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
2020-11-30 16:34:01.025 Error: (Zigate) ReadCluster 0b04 - 59c0/01 Attribute: 050b Type: 29 Size: 0002 Data: ffff Out of Range!!
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
pipiche
Re: Zigate and Aqara Relay Error OUT OF RANGE
Post by pipiche »
pfloryann wrote: Monday 30 November 2020 15:38 Hi,
The message indicate that the devices 59c0 , c023 are reported bad data as regards to Instant Power.
Now, you are refering to channel 1 and or channel 2. What channels are you referring ?
Which version of the plugin and which branch are you ?
pfloryann
Post by pfloryann »
59c0 - is Aqara relay from kitchen room lights and c023 is Aqara relay from roller blinds, is 2 different devices. The error is on channel 1 for both relays. I using domoticz 2020.2 build 12709 and Zigate Plugin: 4.12.062 beta branch
I think the problem has arisen since I installed the relay no 2 (c023) but i'm not sure.
pipiche
Post by pipiche »
I don't understand what you mean by Channel 1 ? There is no channel 1 on Zigbee nor on Zigate.
Domoticz version: 2025.1
I think he uses the aqara relay https://zigbee.blakadder.com/Xiaomi_LLKZMK11LM.html that has 2 relays (=channel). So he has an issue on one of the 2 relays in the device.
pfloryann
Post by pfloryann »
Yes I use 2 x Xiaomi Aqara relay https://zigbee.blakadder.com/Xiaomi_LLKZMK11LM.html everyone as 2 ways/switches (sorry my bad i said 2 channels in my post) I did not refer to zigbee channels. I have this error only on first way(first switch widget in domoticz or so i think) for both Aqara relays.
pfloryann
Post by pfloryann »
Export from zigate webadmin
export(1).txt
(185.38 KiB) Downloaded 24 times
pipiche
Post by pipiche »
What I need is an export of the Plugin RAW Devices (json).
Could you also enable some debug parameter ( Tools-> Debug Advanced )
- debugLumi
- debugClusters
When they are enabled, then just do the actions on 1 relay (which work) and 1 action on 1 relay which doesn't work.
[EDITED]
You have 2 switches and each of 2 "channels", correct ?
You have the same behaviour on each, correct ?
Behaviour is "ReadCluster 0b04 - c023/…ata: ffff Out of Range!!"
on the other the 2 switches performs the action requested , correct ?
