Pass2PHP
ropske
Domoticz version: V3_8394
Re: Pass2PHP
Post by ropske »
Egregius wrote: Tuesday 24 November 2020 6:50
ropske wrote: Monday 23 November 2020 18:50 gonna update tonight to beta, fingers crossed :oops:
If you have a good backup there should be a risk. I'm running beta since the beginning 5 years ago.
well, the beta gave the same problems as before.
so i restored an image of my domoticz VM on proxmox to a data it was working before (i'm making backups every saterday)
but when restoring it, domoticz is still acting weird and certainly my zwave comms :?
a lot of timeouts again, some nodes not found (OpenZwave: node not found)
strange thing is, i had the same issue around the same period last year...
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
Egregius wrote: Tuesday 24 November 2020 6:48 How long was it running to reach pass2php_net 8134?
Mine has now been running 18 hours:
pass2php_raw 6489 request
pass2php_net 4551 after filtering _Temperature and _Utility devices
pass2php_effective 2983 executed because file exists in pass2php folder.
Guess between 15 min max 1 hour I
I can flush the cache and do it again.
It was enabled and then when I figured it out how to read the value in domoticz max 1 hour.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
ropske
Re: Pass2PHP
Post by ropske »
an example of an error i sometimes see in Domtoicz log:
Error: Error executing uvccapture command. returned: 32512
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
sincze wrote: Tuesday 24 November 2020 8:08 Guess between 15 min max 1 hour I
Then you must either have a huge amount of devices, or have a lot of powermeting.
I must say that I don't care about all those powermeters, most of them are disabled. Think only 2 or 3 devices are active.
Egregius
Re: Pass2PHP
Post by Egregius »
ropske wrote: Tuesday 24 November 2020 8:24 an example of an error i sometimes see in Domtoicz log:
Don't know where that came from, definitely not from pass2php.
sincze
Re: Pass2PHP
Post by sincze »
Egregius wrote: Tuesday 24 November 2020 8:36
Never seen that error before.
And yes all devices have power meters ;-)
If I disable the zwave network.. CPU goes down by a lot. But now I also have energy meters with Tasmota.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
I also have quite a large zwave network:
Do you really need all those power meterings? I found that they slow down the zwave network quite a bit.
Guess you need to find a way in between. Maybe stop metering for devices that aren't that important. Like once you now a light uses only 5W, why measure it? Or have the reporting frequency lower.
sincze
Re: Pass2PHP
Post by sincze »
Egregius wrote: Tuesday 24 November 2020 9:44 I also have quite a large zwave network:
You know how it goes... Because we can...
You start with 1......
And before you know it you have a few.
Then add 60 wifi devices .... and boem you have a newtwork.
I must say the network is still quite quick but it does have an impact on the CPU.
THe goal was to measure every consumed watt ;-) all watts accounted for. :lol: :lol:
It does create a nice graph.
But maybe you are right..
I use wasmachine / droger / vaatwasser to sound chromecast speakers with a message whenever they are ready doing a specific program.
"Attentie bericht van de Wasmachine, Ik ben klaar met centrifugeren" ,
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
Just checked the ZWAVE plug settings and it reports every 5 minutes. (or within)
7. Meter Report Interval: 300 (second) (actual: 300)
9. Configure power report: 50 (cA) (actual: 50)
Different plug
2. Meter Report Interval: 300 (second) (actual: 300)
6. Configure power report: 10 (%) (actual: 10)
Some hits indeed.
@Egregius, I noticed in your Github code you only use ACPu for a few devices (doorbell e.g.) the rest is still as is with the DB in the background ;-) right.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
Right, everything is in the MySQL database.
I just use APCu for small things that I don't want in my devices table.
The Ring doorbell is a good example. Notifications come in through IFTTT and a Python script. Ofcourse I only want 1 time a ding and not twice ;)
ropske
Re: Pass2PHP
Post by ropske »
about my strange error: i think i found it, there was a radiator valve: Eurotronic Spirit zwave+ valve acting strange, and it seems this one was 'disturbing' my zwave network it seems, after removing the batterys everything went normal again.
Something else Egrerius, sorry to bother you again :D
in your file(_TC_gasheating.php) on github, i dont see anymore you are setting your radiator valves, that's is comment now i see.
Before there was also the function: SetRadiator, but i don't see it anymore.
How are your radiators working then?
Thank you
Egregius
Re: Pass2PHP
Post by Egregius »
They don't ;)
We decided not to heat the bedrooms anymore so I installed the old manual thermostat valves back and set them to 10°.
The radiators in the living room are completely open to allow control only by the gas burner.
ropske
Re: Pass2PHP
Post by ropske »
ahhhh ok :p
and your bathroom is not controlled anymore by gas?
What about the kitchen for example?
you still use the fibaro smoke sensors as temperature device to control your burner?
thx!
Egregius
Re: Pass2PHP
Post by Egregius »
My bathroom is heated with an electrical heater. I find it a big waste of energy to heat the bathroom every day from lets say 6 to 8 am. Sometimes that just doesn't fit our needs. Therefor, the bathroom is only heated when we enter it in the morning. At other moments we need to activate it with the push of a button. There's a small radiator with a simple thermostatic valve set at 17° to provide basic heat and avoid humidity.
Kitchen is not heated, even removed the radiator. Must add to that that it's a semi-open kitchen.
Yes, the Fibaro smoke sensors are great for temperature measurements.
ropske
Re: Pass2PHP
Post by ropske »
is there any reason why you don't use these zwave controlled radiator valves?
You find you use less energy on the new method you use?
Egregius
Re: Pass2PHP
Post by Egregius »
We just didn't want to heat the bedrooms anymore. A bit tired of changing the batteries all the time.
And we installed a heating pump this year, if it's really needed we can power on that one.
For the living room, I'm convinced that having the radiators fully open is the best way. We only use the gas heater when it's colder than 10°C, everytime else it's done by the heating pump.
sincze
Re: Pass2PHP
Post by sincze »
Egregius wrote: Tuesday 24 November 2020 9:44 Do you really need all those power meterings? I found that they slow down the zwave network quite a bit.
Changed it to report only every 30 mins or so, to bring the load down and report if significant change is detected. A bit more difficult with the tasmota devices ;-), needs to be done via rules i guess.
TelePeriod 300
Backlog PowerDelta 0; Rule1 0; Rule1 5
Rule1   ON ENERGY#Power>=35 DO Backlog PowerDelta 10; Status 8 BREAK   ON ENERGY#Power>=15 DO Backlog PowerDelta 25; Status 8 BREAK   ON ENERGY#Power>5 DO Backlog PowerDelta 35; Status 8 BREAK   ON ENERGY#Power<=5 DO PowerDelta 100 ENDON
Rule1 1
Also started to monitor my Influx and PHP-FPM. ;-)
Pass2php - Influx.JPG (206.42 KiB) Viewed 11511 times
Pass2php - fpm.JPG (207.17 KiB) Viewed 11511 times
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
A new day, a new monitor. Let's monitor the MariaDB as well. :lol:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ropske
Re: Pass2PHP
Post by ropske »
i've got latest days a gas usage from around 10m³ / day
i'm falling behind.
We moved to a new house and it's a lot bigger than our house before, we also did a lot of renovations here so i thought the gasusage in winter period would be ok.
But ouch :(
badkamer seems a bit very high, but our droogmachine in dutch lol is also there, so this one give a lot of heat also, i can see this at the radiator valve in the bathroom, it does not need to change a lot.
ropske
Re: Pass2PHP
Post by ropske »
here you can see the setpoints of my radiator valves
so you can see @ bathroom, it does not ask to heat it (except in the morning)
