Philips hue - port 80
valdoison
Post by valdoison »
I would like to include a "hue philips bridge" in DOMOTICZ. I have a problem with port 80 which I am already using.
Can we modify this port?
cordially
Domoticz version: 2026.3
Re: Philips hue - port 80
It is the port 80 of the hue Philips bridge itself. Not port 80 of the domoticz server. So no need to change this.
Or you have changed this port on the hue bridge yourself.
valdoison
Post by valdoison »
okay
This means that the hue bridge communicates to the outside through port 80, as Apache would if we did not change its port. For me, port 80 is already used by another software and therefore, to send a command by an HTTP request to the API of the hue bridge, I have to modify this port.
Is it possible?
valdoison wrote: Monday 23 November 2020 20:52 This means that the hue bridge communicates to the outside through port 80, as Apache would if we did not change its port. For me, port 80 is already used by another software and therefore, to send a command by an HTTP request to the API of the hue bridge, I have to modify this port.
Is it possible?
Any HTTP request to the Hue bridge will be send to a combination of an IP address and a port. The combination of these two should be unique in every environment.
And to add to waaren, if you did or did not change the port on the hue bridge there is no need to change ports on your domoticz server. If you use port 80 on your domoticz server for something else it will not conflict with the communication to IP_of_hue_bridge:80
Verstuurd vanaf mijn moto g(7) power met Tapatalk
