Time translation
Toulon7559
Domoticz version: <2025
Time translation
Post by Toulon7559 »
Reading a JSON-file from a Domoticz-device, the time info included is often reported in different formats.
Below is result of extraction of a few fields from a JSON-file by means of a lua-script:
Actualtime is EPOCH, other fields are text.
========== JSONFile-times ==========
 Actualtime  = 1605803582
 Servertime  = 2020-11-19 17:33:02
 LastUpdate  = 2020-11-13 06:06:58
For harmonization of time-values from a JSON-file (for a common_base time-processing, or just for display of the date&time-string also for Actualtime), it seems useful to have quick translation back & forth.
Plenty of dedicated, longer scripting solutions, and 'glueing' of found pieces will ultimately do the job,
but looking for a very short & simple 'general' set of functions performing both.
;-) No reason to reinvent the wheel ....
Therefore question related to lua-scripting:
- is short translation function available from a given EPOCH value to text-string?
- is reverse a short translation function available from given text-string to related EPOCH value?
Test case to be processed, see above.
Re: Time translation
Toulon7559 wrote: Thursday 19 November 2020 17:52 - is short translation function available from a given EPOCH value to text-string?
Could look like below (incl. examples)
local function date2Timestamp(dateString, pattern)
	local pattern = pattern or '(%d+)%D+(%d+)%D+(%d+)%D+(%d+)%D+(%d+)' -- yyyy-mm-dd hh:mm
	local year, month, day, hour, minute, seconds = dateString:match(pattern)
	return os.time({year = year, month = month, day = day, hour = hour, min = minute, sec = seconds})
local function timestamp2Date(timestamp, pattern)
	return os.date( ( pattern or '%Y-%m-%d %H:%M:%S') , ( timestamp or os.time() ) )
-- date2Timestamp examples
print ( 'now               --> ' .. os.time() )                    -- no date2Timestamp function needed
print ( 'yesterday         --> ' .. os.time() - 24 * 3600  )       -- no date2Timestamp function needed
print ( '2020-12-31 23:59  --> ' .. date2Timestamp('2020-12-31 23:59') )   -- default pattern
print ( '20201231235901   --> ' .. date2Timestamp('20201231235901','(%d%d%d%d)(%d%d)(%d%d)(%d%d)(%d%d)(%d%d)') ) -- supply own pattern
-- timestamp2Date examples
print ( 'now               --> ' .. timestamp2Date() ) -- now / default pattern
print ( 'now time          --> ' .. timestamp2Date(nil, '%X') )
print ( 'now date          --> ' .. timestamp2Date(nil, '%x') )
print ( 'now year          --> ' .. timestamp2Date(nil, '%Y') )
print ( '\n1605810922 day month --> ' .. timestamp2Date(1605810922, '%A %B') ) -- default pattern
-- test Cases
 local Actualtime  = 1605803582
 local Servertime  = '2020-11-19 17:33:02'
 local LastUpdate  = '2020-11-13 06:06:58'
print ('\nActualtime --> '  .. timestamp2Date(Actualtime) )
print ('Servertime --> '  .. date2Timestamp(Servertime) )
print ('LastUpdate --> '  .. date2Timestamp(LastUpdate) )
Toulon7559
Waaren,
;) As hoped & expected, a whole cart with tools already present somewhere!
Another step for processing of those JSON-files with correct time-values.
Thanks for these nice short translation-sets!
Last edited by Toulon7559 on Friday 20 November 2020 16:04, edited 1 time in total.
Toulon7559 wrote: Thursday 19 November 2020 23:29 Thanks for these nice short translation-sets!
Your welcome.
Below is a little bit longer but might be useful for Lua coders that cannot remember the Lua date/time format codes.
local function timestamp2DateFormat(timestamp, humanizedPattern)
    local function convertMnemomic2FmtCode(humanizedPattern)
        local humanizedPattern = humanizedPattern or 'yyyy-mm-dd hh:MM:ss'
        mnemomics =
            {'dddd' , '%A'}, -- full weekdayname(e.g. Wednesday) language depends on locale
            {'ddd'  , '%a'}, -- abbreviated weekdayname(e.g. Wed) language depends on locale
            {'dd'   , '%d'}, -- day of the month(16){[01-31]
            {'mmmm' , '%B'}, -- full monthname(e.g September) language depends on locale
            {'mmm'  , '%b'}, -- abbreviated monthname(e.g. Sep) language depends on locale
            {'mm'   , '%m'}, -- month[01-12]
            {'yyyy' , '%Y'}, -- 4-digit year
            {'yy'   , '%y'}, -- two-digityear(98){[00-99]
            {'hh'   , '%H'}, -- hour 24-hour clock){[00-23]
            {'ii'   , '%I'}, -- hour 12-hour clock[01-12]
            {'MM'   , '%M'}, -- minute{[00-59]
            {'ss'   , '%S'}, -- second [00-60]
            {'W'    , '%W'}, -- weeknumber [01-53]
            {'w'    , '%w'}, -- weekday{[0-6] Sunday-Saturday
            {'datm' , '%c'}, -- date and time (e.g. 09/16/98 23:48:10) format depends on locale
            {'mer'  , '%p'}, -- either "am" or "pm"
            {'date' , '%x'}, -- date(e.g. 09/16/98) format depends on locale
            {'time' , '%X'}, -- time(e.g. 23:48:10)
        for _, conversion in ipairs(mnemomics) do
            humanizedPattern = string.gsub(humanizedPattern, conversion[1], '%' .. conversion[2])
        return humanizedPattern
    local dateTimeString = os.date( convertMnemomic2FmtCode(humanizedPattern)  , ( timestamp or os.time() ) )
    if dateTimeString:find('nZero') then  -- remove leading zero's
        return dateTimeString:gsub('nZero',''):gsub(' 0',' '):gsub('^0','')
print('\n----\n-- timestamp2DateFormat examples\n----')
print ( 'now                               --> ' .. timestamp2DateFormat() ) -- now / default pattern
print ( 'now date time                     --> ' .. timestamp2DateFormat(nil,'date time') ) -- now / default pattern
print ( 'now ddd mm mmm yyyy ii:MM mer     --> ' .. timestamp2DateFormat(nil, 'ddd mm mmm yyyy ii:MM mer') )
print ( 'timestamp ii:MM mer nZero         --> ' .. timestamp2DateFormat(1598077445, 'ii:MM mer nZero') )
print ( 'timestamp mm/yy ii:MM mer nZero   --> ' .. timestamp2DateFormat(1598077445, 'mm/yy ii:MM mer nZero') )
print ( 'timestamp dddd                    --> ' .. timestamp2DateFormat(1605803582, 'dddd') )
print ( 'timestamp W                       --> ' .. 'Week ' ..timestamp2DateFormat(1605803582, 'W') )
print ( 'timestamp w                       --> ' .. 'Weekday ' ..timestamp2DateFormat(1605803582, 'w') )
