Zigate and Ikea Fyrtur
happyman
Post by happyman »
I recently connected a Zigate USB to my raspberry 3B with the Zigate plugin. The raspberry runs Domitcz 2020.2.
The ischium devices are well detected. I started with two Aqara PIR and two IKEA Fyrtur. Both PIR work properly. I can only open and close the IKEA Fyrtur from Domoticz. When I use the buttons on the Fytur, I can see the percentage change in Domoticz. But I cannot send Fytur from Domoticz at 25%.
Is it possible to set a percentage?
The IKEA Tradfri amplifier and the supplied push button are not connected.
pipiche
Re: Zigate and Ikea Fyrtur
Post by pipiche »
Could you check here https://github.com/pipiche38/Domoticz-Z ... -device.md
and also check your log if you have any thing particular when you are trying to set the % from Domoticz
I would say, that if you can do it from the buttons on the Fytur and see the result on Domoticz, the reverse shoyuld be possible
Wiki is available here.
Zigbee for Domoticz FAQ
