Zigate and Ikea Fyrtur
happyman
Post by happyman »
I recently connected a Zigate USB to my raspberry 3B with the Zigate plugin. The raspberry runs Domitcz 2020.2.
The ischium devices are well detected. I started with two Aqara PIR and two IKEA Fyrtur. Both PIR work properly. I can only open and close the IKEA Fyrtur from Domoticz. When I use the buttons on the Fytur, I can see the percentage change in Domoticz. But I cannot send Fytur from Domoticz at 25%.
Is it possible to set a percentage?
The IKEA Tradfri amplifier and the supplied push button are not connected.
pipiche
Re: Zigate and Ikea Fyrtur
Post by pipiche »
Could you check here https://github.com/pipiche38/Domoticz-Z ... -device.md
and also check your log if you have any thing particular when you are trying to set the % from Domoticz
I would say, that if you can do it from the buttons on the Fytur and see the result on Domoticz, the reverse shoyuld be possible
