8080 problem
Foglio
8080 problem
Post by Foglio »
I keep having problems accessing domoticz through internet.
So what i just did is:
- format my sd card
- install new version of jessie
- install new version of domoticz
at this point i expected to have te system running again.
My next step was:
https://www.domoticz.com/forum/viewtopi ... 0+internet
i downloaded the armhf version of libssl.so.1.0.0 from https://packages.debian.org/jessie/libssl1.0.0
In a terminal window and I installed the package. Still no acces :-(
Next steps:
checked the modem and port 8080 is forwarderd. (i only use domoticz inhouse at the moment)\
checked the modem and port 8080 is also triggered.
Still no acces.
pi@raspberrypi:~ $ wget localhost:8080
--2020-05-05 14:12:54-- http://localhost:8080/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:8080... failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:8080... failed: Connection refused.
pi@raspberrypi:~ $
is anyone able to help me? I would really like to acces domoticz again.
EddyG
Re: 8080 problem
Post by EddyG »
Try again with Buster as OS, see https://www.domoticz.com/forum/viewtopi ... =3&t=32372
Buster is mandatory!
There is a lot of info how to upgrade to Buster, or better start all over with Buster.
sancla
Re: 8080 problem
Post by sancla »
https://sancla.com/domoticz/raspberry-p ... -domoticz/
This explains all steps in detail.
If you need any help, just send me an email or post on this forum...
Check these howto's: https://sancla.com
Foglio
Re: 8080 problem
Post by Foglio »
So i went back to scratch ;)
Installed Buster and updated it.
Putty worked fine on the same ip-adress as before
installed domoticz
and it did not work again!!!
Now i started typing this post and thought…. let's try one last thing….. sudo service domoticz start..... and it is running!!!
just added the autorun, so now it's Always up and running.
Thanks all!
now time to setup everything from scratch :shock: will put more energy next period to domoticz, Always fun if you understand how something works.
sancla
Re: 8080 problem
Post by sancla »
Some work there, but at least it's working again...
Thanks for the feedback, appreciated!
henk99
Re: 8080 problem
Post by henk99 »
I have tried the exact routine above, but it won't let me connect to the webinterface. I can access the RPI fine, but 'connection refused' when I go to the webinterface. Help please
erem
Domoticz version: 2021.1
Re: 8080 problem
Post by erem »
Henk,
First determine if domoticz is actually running
sudo systemctl status domoticz.service
this should give something like
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; generated)
   Active: active (running) since Fri 2020-11-20 01:46:18 CET; 11h ago
     Docs: man:systemd-sysv-generator(8)
  Process: 12636 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/
    Tasks: 21 (limit: 2065)
   CGroup: /system.slice/domoticz.service
           └─12644 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443 -log
Nov 20 01:46:17 RPi-Rob systemd[1]: Starting LSB: Home Automation System...
Nov 20 01:46:18 RPi-Rob domoticz.sh[12636]: 2020-11-20 01:46:18.034  Status: Dom
Nov 20 01:46:18 RPi-Rob domoticz.sh[12636]: 2020-11-20 01:46:18.038  Status: Bui
Nov 20 01:46:18 RPi-Rob domoticz.sh[12636]: 2020-11-20 01:46:18.040  Status: Sta
Nov 20 01:46:18 RPi-Rob domoticz.sh[12636]: domoticz: Domoticz is starting up...
Nov 20 01:46:18 RPi-Rob domoticz[12642]: Domoticz is starting up....
Nov 20 01:46:18 RPi-Rob domoticz[12644]: Domoticz running...
Nov 20 01:46:18 RPi-Rob systemd[1]: Started LSB: Home Automation System.
if it is anything other than Active: active (running)
try
sudo systemctl restart domoticz.service
if it is running, try to access domoticz from the pi itself at 127.0.0.1:8080
Regards,
Rob
Users browsing this forum: Ahrefs [Bot] and 1 guest
