Hi all
Upgrade from 2020.2 build 12393 to Build 2020.2 (build 12554) and lost all ZWave data in the Hardware tab, ZWave setup stays on RED.
If looked into the setup no entries available not even my controller ZW090 Z-Stick Gen5 EU.
In my OZW_Log.txt only the entry "OpenZwave Version 1.6-1520-g893e076a Starting Up"
So decided to restore my completed domoticz directory, copied back my domoticz.db and everything is working again after 5 or 10 minutes.
Is it a problem with the update?
Lost all ZWave data after upgrade to Build 2020.2 (build 12554)
Re: Lost all ZWave data after upgrade to Build 2020.2 (build 12554)
No I don't think so, mine is running fine on the same version.
Pull the GEN5 stick and put it in again and see on which port it is with
Verify if that is the same port as in Domoticz.
dmesg | grep ttyWho is online
