Check the settings of -www or -sslwww during startup of Domoticz.
Either of those needs to be defined.
JakubAnderwald wrote: Saturday 25 April 2020 13:16
Hello
I'm trying to setup MyDomoticz and would need some help. I've created an account at my.domoticz.com, donated 5 EUR since I believe you're doing a great job , obtained an API key and entered that API key and my password at my home domoticz instance. However, it doesn't seem to connect to my domoticz as I still can see no devices at my.domoticz.com, just the regular welcome screen.
In the domoticz logs at my Raspberry Pi I can find the following entry:
Since a few days I can connect to mydomoticz.com (or my.domoticz.com) and access to dashboard but cannot access to each of my instances anymore, when clicking on the icon the page doesn't respond and I got timeout after a while. Whatever brower I used, even after clearing cache.
I checked to log files of my Domoticz instances (on Synolgy) and the connection seems to be ok
2020-04-27 08:44:01.445 Accepting shared server connections via MyDomotiz (see settings menu).
2020-04-27 08:44:01.426 Status: Proxymanager started.
2020-04-27 08:44:03.055 Status: PROXY: Authenticate result: success.
I use version 4.9700 for an instance and even an older one on the others because of support trouble on old Synolgy hardware that can be upgraded. All of them have basic authentication access setting.
chimit wrote: Friday 03 January 2020 15:26
We identified the issue being the following:
When the Domoticz login page is enabled, Domoticz redirects the user the a login page at the webroot.
In case you enter via MyDomoticz, the login page is not in the webroot anymore but at /my/<your instance key>. Domoticz should be updated being able to use an alternative webroot, not just for Domoticz but also in case a local proxy server is used.
My "slave" looses contact approximately every other day and I need to go to the site where the slave is to restart domoticz on that pi and everything works fine for a few days and then it goes offline again. I know that I can set a restart of domoticz at the slave síte using cron but I wonder if someone knows a better way to fix this.
"Status: PROXY: Authenticate result: wrong password for apikey/instanceid combination."
I tried a few styles of password in case special characters aren't allowed.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
When I try and log in, the icon stays red. It worked when I had Domoticz running on Windows PC, but when I moved Domoticz inside a virtual machine with Ubuntu, I couldn't connect anymore.
There is a connection outside the virtual machine because the app on my phone works.
____________________________________________________________________ Raspberry PI 3 Model B with USB stick, Domoticz Stable, OTGW LAN with ESP wifi-bridge and Isense Thermostat using the Outside Temp from Buienradar via Domoticz, Milight Ibox-2(V6)
The master-slave functionality via MyDomoticz is still in beta. You can consider this a "known issue".
The maintainer wanted to refactor the original master-slave functionality, so that's why we hesitated to proceed with the development in MyDomoticz.
Make sure the apikey that you enter in the Domoticz settings page is the api key that you can find in your MyDomoticz settings and in the confirmation e-mail you got.
Especifically it is not the e-mail address that you use to log in to the site.
solarboy wrote: Friday 19 June 2020 17:43
I constantly get
What do your Domoticz log files say when that happens?
Alain wrote: Wednesday 24 June 2020 3:48
Unfortunately to both answers I have to answer that this still will take until after this year still.
This is due to the work load at my regular day time job.
sach wrote: Wednesday 24 June 2020 11:21
Thank you for this, its working well for me.
I have made a donation to the cause.
Quick question, is it possible to connect the mobile (iOS) app to MyDomoticz?
Also any idea on when IFTTT integration is likely to be implemented?
