Return to previous brightness value  [Solved]
eleutscher
Post by eleutscher »
Hello
Is it possible in Blocky (or scripting) to set the brightness of a lamp that is already on at 25% to 80% for x minutes and after this time to set it back to its previous value at 25%?
Is there a entry that saves the previous value so that you can use this again?
Thx, Erik
Zigbee, KAKU, Hue, Google, Honeywell, MotionEye, Telegram, Tasmota, Shelly, IFTTT, etc
Re: Return to previous brightness value
eleutscher wrote: Friday 25 September 2020 16:43 Is it possible in Blocky (or scripting) to set the brightness of a lamp that is already on at 25% to 80% for x minutes and after this time to set it back to its previous value at 25%?
I would not know how to do this in Blockly but it is possible to restore the brightness to a previous state using dzVents. What would trigger the Brightness increase and what is the condition for it to return to the previous state ?
eleutscher
Hai Waaren,
For example. I have my outside lights at 25% brightness and I would like them to go to 100% for 5 minutes after a PIR gets triggered or another event/button. After the 5 min they have to back to the 25%. But I do not want to think about what their previous value was. Just the value before the event. Hope you can help. Thx, Erik
eleutscher wrote: Monday 28 September 2020 19:44 I have my outside lights at 25% brightness and I would like them to go to 100% for 5 minutes after a PIR gets triggered or another event/button. After the 5 min they have to back to the 25%. But I do not want to think about what their previous value was.
Can you try with below dzVents script?
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
return
    on =
        devices =
            'PIR', -- change to name of PIR or other triggering device
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all ok
        marker = 'restore brightness',
    execute = function(dz, item)
        if item.active then
            local light = dz.devices('outside light') -- change to name of light
            local currentLevel = ( light.active and light.level ) or 0
            light.cancelQueuedCommands()
            light.dimTo(100)
            light.dimTo(currentLevel).afterSec(300)
eleutscher
Hai Waaren, Thanks for your reply and this seems to work.
But I have multiple outside light with corresponding values. Is it possible to extend this script for let's say 5 lights? With light 1 has an initial level of 25 and light 2 an level of 40 ad light 3 can only be on or off, etc.
I hope you understand this and can help me with this.
eleutscher wrote: Tuesday 10 November 2020 11:27 I have multiple outside light with corresponding values. Is it possible to extend this script for let's say 5 lights? With light 1 has an initial level of 25 and light 2 an level of 40 ad light 3 can only be on or off, etc.
Please try with below script
return
    on =
        devices =
    logging =
        local DIMMER = 1
        local SWITCH = 2
        local delay = 300
        local lights =
        {    -- name, TYPE
            ['outside light'] = DIMMER,          -- Change to your device names and add the type of devices
            ['outside light2'] = DIMMER,
            ['outside light2'] = SWITCH,
        if item.active then
            for name, type in pairs(lights) do
                local light = dz.devices(name)
                if type == DIMMER then
                    light.dimTo(100)
                    light.dimTo(currentLevel).afterSec(delay)
                elseif type == SWITCH then
                    if light.state == 'Off' then
                        light.switchOn()
                        light.switchOff().afterSec(delay)
                    dz.log(name .. ' Has an unknown type: ',dz.LOG_ERROR)
eleutscher
Re: Return to previous brightness value  [Solved]
:D Yep, this is working! Thx @waaren
