Timing rule as trigger no longer works lastest beta 2020.2 (build 12554)  [Solved]
besix
Post by besix »
I noticed that the script that worked ok in the lastest beta 2020.2 (build 12554)
stopped working.
The entire script below
return
    on =
     timer = {'every 2 minutes and between 4 minutes after sunrise and 58 minutes after sunset , between 59 minutes after sunset and 3 minutes after sunrise'},
     devices = {'Opady'}
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Oczko ogród',
    execute = function( dz, item)
        if item.isTimer then
            dz.log('Time trigger is: ' .. item.trigger,dz.LOG_INFO )
            if (dz.time.matchesRule('between 4 minutes after sunrise and 58 minutes after sunset') and dz.devices('Opady').state == 'Off') then
                dz.devices('Gniazdo Oczko').switchOn()
                dz.log('Oczko włączone')
            elseif (dz.time.matchesRule('between 59 minutes after sunset and 3 minutes after sunrise') or dz.devices('Opady').state == 'On') then
                dz.devices('Gniazdo Oczko').switchOff()
                dz.log('Oczko wyłączone')
This is probably related to the time rule, because if I leave it only every 2 minutes, then it works
return
    on =
     timer = {'every 2 minutes'}
     devices = {'Opady'}
    logging =
What has changed in dzVents and what can I do to fix it?
Time.lua does not support timeRules ?
Re: Timing rule as trigger no longer works lastest beta 2020.2 (build 12554)
besix wrote: Sunday 08 November 2020 8:53 timer = {'every 2 minutes and between 4 minutes after sunrise and 58 minutes after sunset , between 59 minutes after sunset and 3 minutes after sunrise'},
Although it might have done something in earlier versions, this rule was never supported. In fact I don't understand what it should do.
Should it trigger:
every 2 minutes 24/7
every 1 minute between 4 minutes after sunrise and 58 minutes after sunset
every 1 minute between 59 minutes after sunset and 3 minutes after sunrise
Please elaborate in text when you want the script to be triggered.
dannybloe
Post by dannybloe »
Indeed, this should be split into separate rules. And's and comma's are not supported. The reason it might have worked is purely coincidental, perhaps due to how dzVents parses the rules.
besix
Post by besix »
Thanks for the answers.
After your suggestions I changed the script and this is probably what I expect. I don't know why I made it so complicated myself.
return
    on =
     timer = {'every 2 minutes and between 4 minutes after sunrise and 58 minutes after sunset'},
     devices = {'Opady'}
    logging =
                dz.devices('Gniazdo Oczko').switchOn().checkFirst()
                dz.devices('Gniazdo Oczko').switchOff().checkFirst()
This first script, however, worked in earlier versions of dzVents
besix wrote: Sunday 08 November 2020 13:19 After your suggestions I changed the script and this is probably what I expect. I don't know why I made it so complicated myself.
Your rule
Use an unsupported syntax.
If you want the script to be triggered every 2nd minute between 4 minutes after sunrise and 58 minutes after sunset, the rule should be
'every 2 minutes between 4 minutes after sunrise and 58 minutes after sunset'
If you want the script to be triggered every two minutes 24/7 and every 1 minute between 4 minutes after sunrise and 58 minutes after sunset the rules should be
'every 2 minutes',
'every minute between 4 minutes after sunrise and 58 minutes after sunrise',
besix
Re: Timing rule as trigger no longer works lastest beta 2020.2 (build 12554)  [Solved]
Post by besix »
waaren wrote: Sunday 08 November 2020 13:36 If you want the script to be triggered every two minutes 24/7 and every 1 minute between 4 minutes after sunrise and 58 minutes after sunset the rules should be
'every 2 minutes',
thanks a lot for your help. Your last tip is what I needed
