Hi there,
I want add some zigbee devices to my Domoticz installation.
So far I use only RFXCom.
So I looked @ Zigbree controllers in order to user Zigbee devices.
But I cant manage to choose between :
- Zigate
- Conbee II
- Zigbee2MQTT
and more than that I wonder if I should just use the Tradfri Gateway wich is quite cheap and still use any Zigbee device like a bulb or temp sensor or anything else.
wich controller ?
- heggink
- Domoticz version: 12451
Re: wich controller ?
I really like z2mqtt. So far, it had been a great switch from the IKEA hub and moroen plugin to z2mqtt. More functionality and better control despite the great work from moroen (the hub really limits access). I use a zzh stick and start to prefer zigbee over zwave.
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
Thorgal789
- Target OS: -
The tradfri Gateway support realy less device than the "multi brand" gateways.and more than that I wonder if I should just use the Tradfri Gateway wich is quite cheap and still use any Zigbee device like a bulb or temp sensor or anything else
But to help you to choose the one you prefer, I think it s better for you to search on google, all thoses 3 are realy different, they are not just similar usb key.
