Zigate on a remote domoticz
pascal3111
Post by pascal3111 »
I'm using 2 domoticz server on raspberry, and i'm sharing some devices between the slave and the master.
I added a PIZIgate on the slave and I'm using the Zigate pluggin on domoticz, the installation is working correctly on the slave (all zigbee devices are seen) but I don't see the devices on the master. All others device on the slave are seen correctly on the master, only devices connected through the zigate are not visible. Do you you have a idea on how to correct that ? Or at least how to debug. ?
I see nothing anormal on the logs (both master & slave)
pipiche
Re: Zigate on a remote domoticz
Post by pipiche »
You might report that to a domoticz subject as it is more related to the master/slave setup.
I wonder if master/slave is supported with python plugin like zigate plugin
HenkHavelaar
Post by HenkHavelaar »
pascal3111, did you find a solution for this problem? I'm encountering the same problem, all sensors exept the Zigate sensors visible on the master.
Domoticz on Synology NAS and Intel NUC (Linux)
Interfaces: zWave, Zigbee and RFXcom
Locations: Netherlands and Portugal
Domoticz version: 2026.3
Looks like an old but unsolved domoticz python plugin issue https://github.com/domoticz/domoticz/issues/2642
