Samsung Washmachine read status from json "SOLVED"  [Solved]
Tjeerd13
Re: Samsung Washmachine read status from json "SOLVED"
Post by Tjeerd13 »
Updated code V1.1
*Typo row:93 weightSensing
*Row:182 Prevent error log if wm_percent.percentage = nil om some unknown reaseon
-- assumpitions for Samsung Wasmachine Script V1.1
	 Dummy textdevices WM Programma,  WM Klaar om, WM aan het, WM Toerental, WM Resterend, WM Temperatuus.
 	Dummy on/of switch WM Status
 	Dummy Percentaeg WM Percentage
 	API key from  https://developer.samsung.com/smartthings
 	Deivce ID:
 	With this curl reqeust you can get all the device info from the command line (somewhere in the response look for "deviceId" ) (There is an 	space betwean Bearer and < YOUR API KEY> ! )
 	curl --location --request GET 'https://api.smartthings.com/v1/devices/' \ --header 'Authorization: Bearer <Your API KEY>'
local API = '<YOUR API>'
local Device = '<YOUR DEVICE ID>'
local scriptVar = 'wasmachine_JSON'
--Define dz Switches
local WM_STATUS =  'WM Status'  --Domoticz virtual switch ON/Off state  Washer
local WM_PERCENT = 'WM Percentage'
local LOGGING = true
return
    on =
        timer =
            'every minute', -- just an example to trigger the request
        devices =
         200,               -- Just an Switch to activated the script manualy for testing.
        httpResponses =
            scriptVar, -- must match with the callback passed to the openURL command
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    execute = function(dz, item)
    	local wm_status = dz.devices(WM_STATUS)
    	local wm_percent = dz.devices(WM_PERCENT)
        if item.isTimer or item.isDevice then
            dz.openURL({
                url = 'https://api.smartthings.com/v1/devices/'.. Device .. '/states',
                headers = { ['Authorization'] = 'Bearer '.. API },
                method = 'GET',
                callback = scriptVar, -- httpResponses above.
            return
        elseif item.ok then
            if (item.isJSON) then -- when recognized as json then dzVents will convert it to a table for you
                rt = item.json.main
                if _G.logLevel == dz.LOG_DEBUG then -- Only when script loglevel is set to debug
                    -- dump the string represenation of the complete table to log
                    dz.utils.dumpTable(item.json)
                    dz.log('\n-\nAnd now some subtables \n-\n ', dz.LOG_DEBUG)
                    dz.log('\n-\n ------------  main.data.value\n-\n', dz.LOG_DEBUG)
                    --dump the string representation of the DATA table to log, The data attributes changes depending on the state of the washer.
                    dz.utils.dumpTable(dz.utils.fromJSON(item.json.main.data.value))
                local function codeToDutch(code)        --Convert Table_00_Course_* and Washingstate to Dutch
                        local translationcode =
                               D0 = 'Katoen',
                               D1 = 'Eco Katoen',
                               D2 = 'Syntethisch',
                               D3 = 'Fijne Was',
                               D4 = 'Spelen+Centrifugeren',
                               D5 = 'Eco Trommelreiniging',
                               D6 = 'Beddengoed',
                               D7 = 'Outdoor',
                               D8 = 'Wol',
                               D9 = 'Donkere Kleding',
                               DA = 'Super Ecowas',
                               DB = 'Super Speed',
                               DC = '15 min Kort',
                               BA = 'Centrifugeren',
                               none = 'Niksen',
                               weightSensing = 'Wegen',
                               wash = 'Wassen',
                               rinse = 'Spoelen',
                               spin = 'Centrifugeren',
                               finish = 'Klaar',
                        return translationcode[code:gsub('Table_00_Course_','')] or translation[code]
                local endprogram = 'Programma gereed'
                --Update textdevices only when status is changed to prevent too many irrelevant log rows
                local function updateTextOnlyWhenChanged( textSensorName, newText)
                    local textDevice = dz.devices(textSensorName)
                    if textDevice.text == newText then
                        return
                        textDevice.updateText(newText)
                --Update percentagedevices only when status is changed to prevent too many irrelevant log rows
                local function updatePercentageOnlyWhenChanged( percentageSensorName, newPercentage)
                    local percentageDevice = dz.devices(percentageSensorName)
                    if percentageDevice.percentage == newPercentage then
                        return
                     --   percentage.updatePercentage(newPercentage)
                        percentageDevice.updatePercentage(newPercentage)
                local function convertTime(dateString, offset )                             --convert the time to Hour,Minutem,second.
                        local function makeTimeStamp(dateString)
                            local pattern = '(%d+)%-(%d+)%-(%d+)%T(%d+):(%d+):(%d+)(%.*)' -- %d+ = 1 or more digits , %.* = 0 or more any character
                            local xyear, xmonth, xday, xhour, xminute, xseconds = dateString:match(pattern) -- split the string using the pattern
                            local convertedTimestamp = os.time({year = xyear, month = xmonth, day = xday, hour = xhour, min = xminute, sec = xseconds})
                            return convertedTimestamp
                        return os.date('%H:%M:%S', makeTimeStamp(dateString) + offset )
                    local values = dz.utils.fromJSON(item.json.main.data.value)
                    local remainingTime = values.payload.remainingTime or  values.payload["x.com.samsung.da.remainingTime"] or 'not found'
                    local progressPercentage = values.payload.progressPercentage or  values.payload["x.com.samsung.da.progressPercentage"] or 'not found'
                    local completionTime = convertTime(rt.completionTime.value, 3600 )   --Making 1 hour ofset to get local time
                    local switch = rt.switch.value
                    local washerWaterTemperature = rt.washerWaterTemperature.value
                    local washerJobState = rt.washerJobState.value
                    local washerMode = rt.washerMode.value
                    local washerSpinLevel = rt.washerSpinLevel.value
                    if switch == ('on') then                                            -- Turn on Domoitcz switches updates only when Washer is Active.
                            dz.log('Debuggg if swithc on:' ..  switch, dz.LOG_DEBUG)
                            wm_status.switchOn().checkFirst()     --turn on dz WM status switch
                            updateTextOnlyWhenChanged('WM Temperatuur', washerWaterTemperature )
                            updateTextOnlyWhenChanged('WM Aan het', codeToDutch(washerJobState))
                            updateTextOnlyWhenChanged('WM Toerental', washerSpinLevel)
                            updateTextOnlyWhenChanged('WM Resterend', remainingTime)
                            updateTextOnlyWhenChanged('WM Klaar om', completionTime)
                            updateTextOnlyWhenChanged('WM Programma', codeToDutch(washerMode))
                            updatePercentageOnlyWhenChanged('WM Percentage', progressPercentage)
                    else        --Upate text deices with endprogram wen swithc is off
                                dz.log('Debuggg if switch off:' ..  switch, dz.LOG_DEBUG)
                                wm_status.switchOff().checkFirst()
                                dz.log('washerMode if switch off:' ..  endprogram, dz.LOG_DEBUG)
                                updateTextOnlyWhenChanged('WM Temperatuur', endprogram)
                                updateTextOnlyWhenChanged('WM Aan het', endprogram)
                                updateTextOnlyWhenChanged('WM Toerental', endprogram)
                                updateTextOnlyWhenChanged('WM Resterend', endprogram)
                                updateTextOnlyWhenChanged('WM Klaar om', endprogram)
                                updateTextOnlyWhenChanged('WM Programma', endprogram)
                                updatePercentageOnlyWhenChanged('WM Percentage', 100)
                            if LOGGING then
                                dz.log('\n-\nWhats happening: \n-\n ', dz.LOG_INFO)
                                dz.log('Klaar om:' .. completionTime, dz.LOG_INFO)
                                dz.log('Status:' .. switch, dz.LOG_INFO)
                                dz.log('Temperatuur:' .. washerWaterTemperature, dz.LOG_INFO)
                                dz.log('Aan het:' .. washerJobState, dz.LOG_INFO)
                                dz.log('Programma:' .. washerMode, dz.LOG_INFO)
                                dz.log('Toerental:' .. washerSpinLevel, dz.LOG_INFO)
                                dz.log('remaining time = ' .. remainingTime, dz.LOG_INFO)
                                dz.log('progressPercentage  = ' .. progressPercentage, dz.LOG_INFO)
                                if wm_percent.percentage == nil then                                            --Prevent error log if wm_percent.percentage = nil om some unknown reaseon
                                    dz.log('Percentage WM Percentage NIL', dz.LOG_INFO)
                                else    dz.log('Percentage WM Percentage = ' .. wm_percent.percentage .. '%' , dz.LOG_INFO)
                                dz.log('\n-\n============================== \n-\n ', dz.LOG_INFO)
                return
                dz.log('result was not recognized as a JSON', dz.LOG_ERROR)
            dz.log('result was not OK', dz.LOG_ERROR)
        dz.log(item,dz.LOG_ERROR) -- dump all to log as one long string
Pi3, Pi4, Pi4 for Testing, Dashticz, RFXtrx433, Nest: "Thermostat V2, V3, Hello". Honywell Lyric T6R, RFXCom, KaKu, HUE, P1, Open Zwave USB,
vlamke
Post by vlamke »
Tjeerd13 wrote: Thursday 05 March 2020 13:56 Updated code V1.1
 	Deivce ID:
return
    on =
        timer =
        devices =
        httpResponses =
    logging =
        marker = scriptVar,
            dz.openURL({
                method = 'GET',
            return
        elseif item.ok then
                rt = item.json.main
                               D0 = 'Katoen',
                               D1 = 'Eco Katoen',
                               D2 = 'Syntethisch',
                               D3 = 'Fijne Was',
                               D6 = 'Beddengoed',
                               D7 = 'Outdoor',
                               D8 = 'Wol',
                               DB = 'Super Speed',
                               DC = '15 min Kort',
                               none = 'Niksen',
                               wash = 'Wassen',
                               rinse = 'Spoelen',
                               finish = 'Klaar',
                        return
                        return
                            if LOGGING then
                return
Tjeerd13 thanks for your code, its working fantastic and I have made some changes below is my code:
 	Deivce ID:
local WM_STATUS =  1537		  		--Domoticz virtual switch ON/Off state of the Washer
local WM_PERCENT = 1538				--Domoticz virtual text device Percentage of the Washer
local WM_WATER_TEMPERATURE = 1536	--Domoticz virtual text device Temperature of the Washer
local WM_JOB_STATE = 1533 			--Domoticz virtual text device Job State of the Washer
local WM_SPIN_LEVEL = 1534			--Domoticz virtual text device Spin Level of the Washer
local WM_REMAINING_TIME = 1535		--Domoticz virtual text device Remaining Time of the Washer
local WM_COMPLETION_TIME = 1532		--Domoticz virtual text device Completion Time of the Washer
local WM_MODE = 1531				--Domoticz virtual text device Mode of the Washer
return
    on =
        timer =
        devices =
        httpResponses =
    logging =
        marker = scriptVar,
            dz.openURL({
                method = 'GET',
            return
        elseif item.ok then
                rt = item.json.main
                               D0 = 'Katoen',
                               D1 = 'Eco Katoen',
                               D2 = 'Syntethisch',
                               D3 = 'Fijne Was',
                               D6 = 'Beddengoed',
                               D7 = 'Outdoor',
                               D8 = 'Wol',
                               DB = 'Super Speed',
                               DC = '15 min Kort',
                               none = 'Niksen',
                               wash = 'Wassen',
                               rinse = 'Spoelen',
                               finish = 'Klaar',
                        return
                        return
                            updateTextOnlyWhenChanged(WM_WATER_TEMPERATURE, washerWaterTemperature)
                            updateTextOnlyWhenChanged(WM_JOB_STATE, codeToDutch(washerJobState))
                            updateTextOnlyWhenChanged(WM_SPIN_LEVEL, washerSpinLevel)
                            updateTextOnlyWhenChanged(WM_REMAINING_TIME, remainingTime)
                            updateTextOnlyWhenChanged(WM_COMPLETION_TIME, completionTime)
                            updateTextOnlyWhenChanged(WM_MODE, codeToDutch(washerMode))
                            updatePercentageOnlyWhenChanged(WM_PERCENT, progressPercentage)
                                dz.log('The washerMode if switch off:' ..  codeToDutch('endprogram'), dz.LOG_DEBUG)
                                updateTextOnlyWhenChanged(WM_WATER_TEMPERATURE, codeToDutch('endprogram'))
                                updateTextOnlyWhenChanged(WM_JOB_STATE, codeToDutch('endprogram'))
                                updateTextOnlyWhenChanged(WM_SPIN_LEVEL, codeToDutch('endprogram'))
                                updateTextOnlyWhenChanged(WM_REMAINING_TIME, codeToDutch('endprogram'))
                                updateTextOnlyWhenChanged(WM_COMPLETION_TIME, codeToDutch('endprogram'))
                                updateTextOnlyWhenChanged(WM_MODE, codeToDutch('endprogram'))
                                updatePercentageOnlyWhenChanged(WM_PERCENT, 100)
                            if LOGGING then
                                dz.log('Ready to:' .. completionTime, dz.LOG_INFO)
                                dz.log('Temperature:' .. washerWaterTemperature, dz.LOG_INFO)
                                dz.log('Job State:' .. washerJobState, dz.LOG_INFO)
                                dz.log('Program:' .. washerMode, dz.LOG_INFO)
                                dz.log('Rpm:' .. washerSpinLevel, dz.LOG_INFO)
                                dz.log('Remaining Time = ' .. remainingTime, dz.LOG_INFO)
                                dz.log('Progress Percentage  = ' .. progressPercentage, dz.LOG_INFO)
                return
                dz.log('The result was not recognized as a JSON', dz.LOG_ERROR)
            dz.log('The result was not OK', dz.LOG_ERROR)
I have modified the option to need specific the names of these sensors and replaced it with that everyone can give specific names or IDX this is set in the local.
Also I have moved the "endProgram" text to the translation table so that everyone can also translate that in there language if needed.
kulderzipke
Post by kulderzipke »
Thanks for the scripts, but i can you help me find the API-Key from https://developer.samsung.com/smartthings?
I can not find it?
kulderzipke
How can I find the Api-Key that is needed to get this script running?
Can someone help me were to click on the website: https://developer.samsung.com/smartthings to retreive the Api-Key.
kulderzipke
I see. had to make an account om developers site of Samsung.
Than i got a attempt to index field 'washerMode' (a nil value) error.
Fixed it by checking the logfile, if there was a new name for WasherMode, this is changed by WasherCycle.
Can be that you have to check the variables and change the Script with new names....
Finally I got it to work
Thanks for the scripting
Tjeerd13
Post by Tjeerd13 »
Version 2.0 of the working script:
Some lite changes:
WasherMode changed to WaherCycle (WHY Samsung!?)
Typo's
-- assumpitions for Samsung Wasmachine Script V2.0 04-Jan-2021
--[[   Dummy textdevices WM Programma,  WM Klaar om, WM aan het, WM Toerental, WM Resterend, WM Temperatuus.
 	Device ID from  https://smartthings.developer.samsung.com/docs/api-ref/st-api.html#operation/getDevices  i used postman to get the device.
  	Making a get request with https://api.smartthings.com/v1/devices/
local Device = <Your Local device>'
return
    on =
        timer =
        devices =
         200,               -- Just on Switch to activated the script manualy for testing.
        httpResponses =
    logging =
        level = domoticz.LOG_ERROR,
        marker = scriptVar,
            dz.openURL({
                method = 'GET',
            return
        elseif item.ok then
                rt = item.json.main
                               D0 = 'Katoen',
                               D1 = 'Eco Katoen',
                               D2 = 'Syntethisch',
                               D3 = 'Fijne Was',
                               D4 = 'Spoelen+Centrifugeren',
                               D5 = 'ECO Trommelreiniging',
                               D6 = 'Beddengoed',
                               D7 = 'Outdoor',
                               D8 = 'Wol',
                               DB = 'Super Speed',
                               DC = '15 min Kort',
                               none = 'Niksen',
                               Weightsensing = 'Wegen',
                               wash = 'Wassen',
                               rinse = 'Spoelen',
                               finish = 'Klaar',
                        return
                        return
                    local datatest1 = values.payload["10.x.com.samsung.da.progressPercentage"] or 'test1 not found'
                    local datatest2 = values.payload["3.x.com.samsung.da.cumulativePower"] or 'test2 not found'
                    local datatest3 = values.payload["3"].rep["x.com.samsung.da.cumulativePower"] or 'test3 not found'
                    local datatest4 = values.payload["4"]["x.com.samsung.da.options"]["27"] or 'test4 not found'
                    local datatest5 = values.payload["4"].rep["x.com.samsung.da.options"]["27"] or 'test5 not found'
                    local datatest6 = values.payload["4"]["x.com.samsung.da.options"] or 'test6 not found'
                    local datatest7 = values.payload["4"].rep["x.com.samsung.da.options"]["28"] or 'test7 not found'
                    local datatest8 = values.payload["4"]["x.com.samsung.da.options"]["28"] or 'test8 not found'
                --     local completionTime = convertTime(rt.completionTime.value, 7200)   --Making no ofset to get local time (summerimte)
                    local completionTime = convertTime(rt.completionTime.value, 3600 )   --Making 1 hour ofset to get local time (wintertime)
                    local washerCycle = rt.washerCycle.value
                            updateTextOnlyWhenChanged('WM Programma', codeToDutch(washerCycle))
                            if LOGGING then
                                dz.log('Programma:' .. washerCycle, dz.LOG_INFO)
                                    dz.log('Percentage WM Percentage NILL', dz.LOG_INFO)
                return
billytkid
Post by billytkid »
Hi Tjeerd & Waaren,
I've just installed a samsung smart washing machine today so I've been giving this a go, thanks for all the efforts, amazing work and well beyond anything I'd have been able to do by myself :)
I noticed a couple of things:
1. To get the device ID rather than use a get request this seems to also be shown in the URL at (https://graph-eu01-euwest1.api.smartthi ... evice/list)
2. There were some typos in the required device names (WM Temperatuur & WM Aan het)
I've got an error in the log, do you have any ideas what this means:
2021-02-21 13:13:01.530 Error: dzVents: Error: (3.0.2) wasmachine_JSON: An error occurred when calling event handler SamsungWashing
2021-02-21 13:13:01.530 Error: dzVents: Error: (3.0.2) wasmachine_JSON: ...icz/scripts/dzVents/generated_scripts/SamsungWashing.lua:98: attempt to index a nil value (global 'translation')
By changing line 98 to be
, rather than
fixed it.
Does this matter?
Thanks again!
billytkid wrote: Sunday 21 February 2021 14:13 I've just installed a samsung smart washing machine today so I've been giving this a go
Does this matter?
it does a bit because the function will now return nil without error when it could not find the code in the translationcode table
can you change line 98
from
to
                local code = tostring(code)
                local translatedCode = translationcode[code:gsub('Table_00_Course_','')] or translationcode[code]
                if translatedCode == nil then
                    dz.log('codeToDutch: Found unknown code: ' .. tostring(code),dz.LOG_ERROR )
                return translatedCode or '?'
and try again?
billytkid
Post by billytkid »
Hi Waaren,
Thank you for this, it now works perfectly!
I'm going to see if I can tweak this into English and will post updated code if it works.
Thanks,
Will
billytkid
Post by billytkid »
Hi Tjeerd & Waaren,
I've just had a further play with this and have made some minor changes but IMHO make it easier to setup for a newbie (ie me!).
Amazing work on this and I hope this can help someone else:
-- SETUP YOUR API CONFIGURATION HERE --
-- API key from  https://account.smartthings.com/tokens (You'll need to register first ane ensure your machine is on the same account)
-- Device ID from  https://graph-eu01-euwest1.api.smartthings.com/device/list (click on your machine, then use the number in the URL after the last /)
local API = 'GET YOUR API KEY FROM THE URL ABOVE'
local Device = 'GET YOUR DEVICE ID FROM THE URL ABOVE'
-- CREATE YOUR OWN OUTPUTS HERE --
-- Create virtual sensors in Domoticz Hardware settings that will show the output from the washing machine.
-- Names are suggested [in square brackets], you need to input the device ID in (brackets) below.
local WM_PROGRAM = (493) -- Virtual device showing washing machine Program [Washing - Device type = text
local WM_COMPLETION = (494) -- Virtual device showing washing cycle completion time - Device type = text
local WM_SPIN = (496) -- Virtual device showing washing spin state - Device type = text
local WM_REMAINING = (497) -- Virtual device showing time remaining on wash - Device type = text
local WM_TEMP = (498) -- Virtual device showing washing machine Temperature - Device type = text
local WM_STATUS = (499)  -- Virtual device showing washing machine On/Off - Device type = on/off switch
local WM_PERCENT = (500) -- Virtual device showing washing machine percentage - Device type = percentage
local WM_STATE = (501) -- Virtual device showing washing cycle state - Device type = text
return
    on =
        timer =
        devices =
        httpResponses =
    logging =
        marker = scriptVar,
            dz.openURL({
                method = 'GET',
            return
        elseif item.ok then
                rt = item.json.main
                local function codeToEnglish(code)        --Convert Table_00_Course_* and Washingstate to English
                               D0 = 'Cotton Wash',
                               D1 = 'Eco Cotton Wash',
                               D2 = 'Synthetics',
                               D3 = 'Delicates',
                               D4 = 'Rinse & Spin',
                               D5 = 'Drum Cleaning',
                               D6 = 'Bed Linnen',
                               D7 = 'Outdoor',
                               D8 = 'Wool',
                               D9 = 'Dark Wash',
                               DA = 'Super Eco Wash',
                               DB = 'Super Speed Wash',
                               DC = '15 min quick wash',
                               BA = 'Spin',
                               none = 'Nothing',
                               Weightsensing = 'Weight Sensing',
                               wash = 'Washing',
                               rinse = 'Rinsing',
                               spin = 'Spinning',
                               finish = 'Ended',
                                  dz.log('codeToEnglish: Found unknown code: ' .. tostring(code),dz.LOG_ERROR )
                local endprogram = 'No active program'
                        return
                        return
                            updateTextOnlyWhenChanged(WM_TEMP, washerWaterTemperature )
                            updateTextOnlyWhenChanged(WM_STATE, codeToEnglish(washerJobState))
                            updateTextOnlyWhenChanged(WM_SPIN, washerSpinLevel)
                            updateTextOnlyWhenChanged(WM_REMAINING, remainingTime)
                            updateTextOnlyWhenChanged(WM_COMPLETION, completionTime)
                            updateTextOnlyWhenChanged(WM_PROGRAM, codeToEnglish(washerCycle))
                    else        --Upate text devices with endprogram wen swithc is off
                                updateTextOnlyWhenChanged(WM_TEMP, endprogram)
                                updateTextOnlyWhenChanged(WM_STATE, endprogram)
                                updateTextOnlyWhenChanged(WM_SPIN, endprogram)
                                updateTextOnlyWhenChanged(WM_REMAINING, endprogram)
                                updateTextOnlyWhenChanged(WM_COMPLETION, endprogram)
                                updateTextOnlyWhenChanged(WM_PROGRAM, endprogram)
                            if LOGGING then
                                dz.log('Completion Time:' .. completionTime, dz.LOG_INFO)
                                dz.log('State:' .. washerJobState, dz.LOG_INFO)
                                dz.log('Program:' .. washerCycle, dz.LOG_INFO)
                                dz.log('Spin Speed:' .. washerSpinLevel, dz.LOG_INFO)
                                dz.log('ProgressPercentage  = ' .. progressPercentage, dz.LOG_INFO)
                return
Robinjoo94
Domoticz version: 2022.1
Post by Robinjoo94 »
Hi all on this topic.
I have purchased two Samsung Washing machines which were installed yesterday (one dryer actually). I would like to thank anyone who contributed to these scripts. I have both the washing machine as the dryer working with similar scripts! Happy days....
Things I stumbled upon:
1. These are dzVents scripts, not bare lua
2. Dryer has completely different JSON structure, logging with the present logging feutures was not working so removed them competely
I have added some more translation stuff, and removed non-working logging rules as explained above.
I would like to share my contribution here, feel free to re-add the parts that you like!
I hope the isdst (Is Daylight Saving Time) implementation is working, so far it does on my setup.
Furthermore I changed the script so it should not crash when you add less dummy devices since you like to (untested).
P.s. I did a cleanup of the code structure, since, well, I am a software developer with some OCD ;)
Code for the washing machine:
-- API key from  https://account.smartthings.com/tokens (You'll need to register first and ensure your machine is on the same account)
local WM_TEST_SWITCH = (200)  -- Virtual on switch to activated the script manually for testing.
local scriptVar = 'WashingMachine'
--Convert Table_00_Course_* and WashingState to English
local function codeToEnglish(dz, code)
		   Table_00_Course_D0 = 'Cotton Wash',
		   Table_00_Course_D1 = 'Eco Cotton Wash',
		   Table_00_Course_D2 = 'Synthetics',
		   Table_00_Course_D3 = 'Delicates',
		   Table_00_Course_D4 = 'Rinse & Spin',
		   Table_00_Course_D5 = 'Drum Cleaning',
		   Table_00_Course_D6 = 'Bed Linnen',
		   Table_00_Course_D7 = 'Outdoor',
		   Table_00_Course_D8 = 'Wool',
		   Table_00_Course_D9 = 'Dark Wash',
		   Table_00_Course_DA = 'Super Eco Wash',
		   Table_00_Course_DB = 'Super Speed Wash',
		   Table_00_Course_DC = '15\' Quick Wash',
		   Table_00_Course_BA = 'Spin',
		   Table_02_Course_1B = 'Cotton',
		   Table_02_Course_1C = 'Eco 40-60',
		   Table_02_Course_1D = 'Super Speed Wash',
		   Table_02_Course_1E = '15\' Quick Wash',
		   Table_02_Course_1F = 'Intense Cold',
		   Table_02_Course_20 = 'Hygenic Steam',
		   Table_02_Course_21 = 'Colored Wash',
		   Table_02_Course_22 = 'Wool',
		   Table_02_Course_23 = 'Outdoor',
		   Table_02_Course_24 = 'Bed Linnen',
		   Table_02_Course_25 = 'Syntetic',
		   Table_02_Course_26 = 'Delicates',
		   Table_02_Course_27 = 'Rinse & Spin',
		   Table_02_Course_28 = 'Drain & Spin',
		   Table_02_Course_29 = 'Drum Cleaning',
		   Table_02_Course_2A = 'Jeans',
		   Table_02_Course_2B = 'All Wash',
		   Table_02_Course_2D = 'Silent Wash',
		   Table_02_Course_2E = 'Baby Clothes',
		   Table_02_Course_2F = 'Sportswear',
		   Table_02_Course_30 = 'Cloudy Day',
		   Table_02_Course_32 = 'Shirts',
		   Table_02_Course_33 = 'Towels',
		   none = 'Nothing',
		   weightSensing = 'Weight Sensing',
		   wash = 'Washing',
		   rinse = 'Rinsing',
		   spin = 'Spinning',
		   finish = 'Ended',
	local translatedCode = translationcode[code]
--Update text devices only when status is changed to prevent too many irrelevant log rows
local function updateTextOnlyWhenChanged(dz, textSensorName, newText)
	if textSensorName ~= nil then
		if textDevice.text ~= newText then
--Update percentage devices only when status is changed to prevent too many irrelevant log rows
local function updatePercentageOnlyWhenChanged(dz, percentageSensorName, newPercentage)
	if percentageSensorName ~= nil then
		if percentageDevice.percentage ~= newPercentage then
--Convert the time to Hour,Minute,second.
local function convertTime(dateString)
	local convertedTimestamp = os.time({year = xyear, month = xmonth, day = xday, hour = xhour, min = xminute, sec = xseconds, isdst = os.date("*t", os.time()).isdst})
	return os.date('%H:%M:%S', convertedTimestamp + 3600)
return
    on =
        timer =
        devices =
            WM_TEST_SWITCH, -- Just on Switch to activated the script manually for testing.
        httpResponses =
    logging =
        marker = scriptVar,
            dz.openURL({
                method = 'GET',
            return
        elseif item.ok then
                rt = item.json.main
                local endProgram = 'No active program'
				local completionTime = convertTime(rt.completionTime.value)
					-- Turn on Domoticz switches updates only when Washer is Active.
					dz.log('Debug if switch on:' ..  switch, dz.LOG_DEBUG)
					updateTextOnlyWhenChanged(dz, WM_TEMP, washerWaterTemperature )
					updateTextOnlyWhenChanged(dz, WM_STATE, codeToEnglish(dz, washerJobState))
					updateTextOnlyWhenChanged(dz, WM_SPIN, washerSpinLevel)
					updateTextOnlyWhenChanged(dz, WM_REMAINING, remainingTime)
					updateTextOnlyWhenChanged(dz, WM_COMPLETION, completionTime)
					updateTextOnlyWhenChanged(dz, WM_PROGRAM, codeToEnglish(dz, washerCycle))
					updatePercentageOnlyWhenChanged(dz, WM_PERCENT, progressPercentage)
					--Update text devices with endProgram when switch is off
					dz.log('Debug if switch off:' ..  switch, dz.LOG_DEBUG)
					dz.log('washerMode if switch off:' ..  endProgram, dz.LOG_DEBUG)
					updateTextOnlyWhenChanged(dz, WM_TEMP, endProgram)
					updateTextOnlyWhenChanged(dz, WM_STATE, endProgram)
					updateTextOnlyWhenChanged(dz, WM_SPIN, endProgram)
					updateTextOnlyWhenChanged(dz, WM_REMAINING, endProgram)
					updateTextOnlyWhenChanged(dz, WM_COMPLETION, endProgram)
					updateTextOnlyWhenChanged(dz, WM_PROGRAM, endProgram)
					updatePercentageOnlyWhenChanged(dz, WM_PERCENT, 100)
                return
        dz.log(item, dz.LOG_ERROR) -- dump all to log as one long string
Then I have some equal code for the Dryer, I have still to do some work on the translations... :
local DR_TEST_SWITCH = (55)  -- Virtual on switch to activated the script manually for testing.
local DR_PROGRAM = (56) -- Virtual device showing washing machine Program [Washing - Device type = text
local DR_COMPLETION = (57) -- Virtual device showing washing cycle completion time - Device type = text
local DR_REMAINING = (58) -- Virtual device showing time remaining on wash - Device type = text
local DR_STATUS = (61)  -- Virtual device showing washing machine On/Off - Device type = on/off switch
local DR_PERCENT = (62) -- Virtual device showing washing machine percentage - Device type = percentage
local scriptVar = 'Dryer'
		   Table_03_Course_16 = 'Cotton',
		   Table_03_Course_17 = 'Super Speed',
		   Table_03_Course_18 = 'Synthetics',
		   Table_03_Course_19 = 'Delicates',
		   Table_03_Course_1A = 'Wool',
		   Table_03_Course_1B = 'Bed Linnen',
		   Table_03_Course_1C = 'Shirts',
		   Table_03_Course_1D = 'Towels',
		   Table_03_Course_1E = 'Outdoor',
		   Table_03_Course_1F = 'Colored Wash',
		   Table_03_Course_20 = 'Iron Dry',
		   Table_03_Course_21 = 'Hygenic Care',
		   Table_03_Course_23 = '35\' Fast Dry',
		   Table_03_Course_24 = 'Cold Air',
		   Table_03_Course_25 = 'Warm Air',
		   Table_03_Course_26 = 'Air Wash',
		   Table_03_Course_27 = 'Time Program',
		   finish = 'Ended',
	local translatedCode = translationcode[code:gsub('Table_03_Course_','')] or translationcode[code]
return
    on =
        timer =
        devices =
            DR_TEST_SWITCH, -- Just on Switch to activated the script manually for testing.
        httpResponses =
    logging =
        marker = scriptVar,
    	local dr_status = dz.devices(DR_STATUS)
		local dr_percent = dz.devices(DR_PERCENT)
            dz.openURL({
                method = 'GET',
            return
        elseif item.ok then
                rt = item.json.main
				local dryerCycle = rt.dryerCycle.value
					dr_status.switchOn().checkFirst()     --turn on dz WM status switch
					updateTextOnlyWhenChanged(dz, DR_REMAINING, remainingTime)
					updateTextOnlyWhenChanged(dz, DR_COMPLETION, completionTime)
					updateTextOnlyWhenChanged(dz, DR_PROGRAM, codeToEnglish(dz, dryerCycle))
					updatePercentageOnlyWhenChanged(dz, DR_PERCENT, progressPercentage)
					dr_status.switchOff().checkFirst()
					updateTextOnlyWhenChanged(dz, DR_REMAINING, endProgram)
					updateTextOnlyWhenChanged(dz, DR_COMPLETION, endProgram)
					updateTextOnlyWhenChanged(dz, DR_PROGRAM, endProgram)
					updatePercentageOnlyWhenChanged(dz, DR_PERCENT, 100)
                return
The combined version should contain all the above!
local wmDevice = 'GET YOUR DEVICE ID FROM THE URL ABOVE'
local drDevice = 'GET YOUR DEVICE ID FROM THE URL ABOVE'
local TEST_SWITCH = (55)  -- Virtual on switch to activated the script manually for testing.
local WM_PROGRAM = (47) -- Virtual device showing washing machine Program - Device type = text
local WM_COMPLETION = (48) -- Virtual device showing washing cycle completion time - Device type = text
local WM_SPIN = (49) -- Virtual device showing washing spin state - Device type = text
local WM_REMAINING = (50) -- Virtual device showing time remaining on wash - Device type = text
local WM_TEMP = (51) -- Virtual device showing washing machine Temperature - Device type = text
local WM_STATUS = (53)  -- Virtual device showing washing machine On/Off - Device type = on/off switch
local WM_PERCENT = (54) -- Virtual device showing washing machine percentage - Device type = percentage
local WM_STATE = (52) -- Virtual device showing washing cycle state - Device type = text
local DR_PROGRAM = (56) -- Virtual device showing dryer Program - Device type = text
local DR_COMPLETION = (57) -- Virtual device showing drying cycle completion time - Device type = text
local DR_STATUS = (61)  -- Virtual device showing dryer On/Off - Device type = on/off switch
local DR_PERCENT = (62) -- Virtual device showing dryer percentage - Device type = percentage
local wmScriptVar = 'WashingMachine'
local drScriptVar = 'Dryer'
		   none = 'Nothing',
		   wash = 'Washing',
		   rinse = 'Rinsing',
		   spin = 'Spinning',
		   finish = 'Ended',
--Update switch devices only when exists
local function updateSwitchOnlyWhenExists(dz, switchName, newState)
	if switchName ~= nil then
		local switch = dz.devices(switchName)
		if newState == 'ON' then
			switch.switchOn().checkFirst()
			switch.switchOff().checkFirst()
return
    on =
        timer =
        devices =
        httpResponses =
            wmScriptVar, -- must match with the callback passed to the openURL command
			drScriptVar, -- must match with the callback passed to the openURL command
    logging =
        marker = 'SamsungWashingMachines',
            if wmDevice ~= nil and wmScriptVar ~= nill then
				dz.openURL({
					url = 'https://api.smartthings.com/v1/devices/'.. wmDevice .. '/states',
					method = 'GET',
					callback = wmScriptVar, -- httpResponses above.
			if drDevice ~= nil and drScriptVar ~= nill then
				dz.openURL({
					url = 'https://api.smartthings.com/v1/devices/'.. drDevice .. '/states',
					method = 'GET',
					callback = drScriptVar, -- httpResponses above.
            return
        elseif item.ok then
                rt = item.json.main
				-- Check whether it is a dryer or a washing machine
				if rt.n.value == "[dryer] Samsung" then
						updateSwitchOnlyWhenExists(dz, DR_STATUS, 'ON')     --turn on dz DR status switch
						updateSwitchOnlyWhenExists(dz, DR_STATUS, 'OFF')     --turn off dz DR status switch
						dz.log('dryerMode if switch off:' ..  endProgram, dz.LOG_DEBUG)
						updateSwitchOnlyWhenExists(dz, WM_STATUS, 'ON')     --turn on dz WM status switch
						updateSwitchOnlyWhenExists(dz, WM_STATUS, 'OFF')     --turn off dz WM status switch
                return
Ofcourse I have some wild plans:
1. First of all finish the translations on the dryer. Done :)
2. Then I want to combine the two into one dzVents script Done as well :)
3. Rewrite the scripts into an python plugin to have one single washing machine "widget" with all needed info :) Never done so, but a nice hobby project.
dizzeenl
Post by dizzeenl »
Thank you all for this awesome code! and the further development. I now use the combination code from the last post 8-)
Unfortunately i get an error;
2021-03-30 12:54:00.778 Error: dzVents: Error: (3.1.7) SamsungWashingMachines: An error occurred when calling event handler 09 SAMSUNG WASHDRY
2021-03-30 12:54:00.778 Error: dzVents: Error: (3.1.7) SamsungWashingMachines: ...scripts/dzVents/generated_scripts/09 SAMSUNG WASHDRY.lua:204: attempt to index a nil value (local 'values')
any id why this is happening to me? beside above error i dont get any other errors but the custom devices stay on default :(
Note for other beginners, be sure you use the number in the URL after the last slash if you opened the selected device and not the device network id :D
dizzeenl wrote: Tuesday 30 March 2021 13:16
Parsing item.json.main.data.value through the JSON parser is wrong and will return nil.
Can you try again after changing line 203 from
to
local values = item.json.main.data.value
Robinjoo94
waaren wrote: Tuesday 30 March 2021 14:21 Parsing item.json.main.data.value through the JSON parser is wrong and will return nil.
In my Domoticz, it is functional, when I applied the suggested changes, it showed similar errors in the log as dizzeenl had with my implementation.
Where are these differences coming from?
Furthermore, since last saterday the Daylight Saving Time started, I saw that particular bit of magic just did not do the trick, therefore some changes:
	local tmp_time = os.time()
	local d1 = os.date("*t",  tmp_time)
	local d2 = os.date("!*t", tmp_time)
	d1.isdst = false
	local zone_diff = os.difftime(os.time(d1), os.time(d2))
	return os.date('%H:%M:%S', convertedTimestamp + zone_diff)
Robinjoo94 wrote: Tuesday 30 March 2021 20:24 In my Domoticz, it is functional, when I applied the suggested changes, it showed similar errors in the log as dizzeenl had with my implementation.
No clue but the complete JSON should already be converted to a Lua (sub)table
can you insert these commands to show what the state is of this JSON / table?
dz.utils.dumpTable(item.json.main.data.value)
dz.log(item.json.main.data.value)
Robinjoo94
waaren wrote: Tuesday 30 March 2021 20:46
I got the following error on both instances of dz.utils.dumpTable. Tried both, the first and the later seperately.
Error: dzVents: Error: (3.0.2) SamsungWashingMachines: /home/pi/domoticz/dzVents/runtime/Utils.lua:425: bad argument #1 to 'pairs' (table expected, got string)
Robinjoo94 wrote: Wednesday 31 March 2021 10:00
Please try again after removing first of these lines
Robinjoo94
waaren wrote: Wednesday 31 March 2021 10:02
As mentioned, I did, so first attempt:
Second attempt:
-- dz.utils.dumpTable(item.json.main.data.value)
Third attempt:
-- dz.utils.dumpTable(dz.utils.fromJSON(item.json.main.data.value))
Same error messages
Robinjoo94 wrote: Wednesday 31 March 2021 10:31 Same error messages
That should not be possible as the dz.log(item.json.main.data.value) does not call the function that contains line 425 of /home/pi/domoticz/dzVents/runtime/Utils.lua
Can you share the script as it is now and the complete log?
dizzeenl
Post by dizzeenl »
to
Unfortunately in my case the above change will still result in the same error :cry:
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
