What is shown in the Domoticz log? Do you see there that it has updated the sensor values?arhangel76 wrote:not work...
https://prnt.sc/v51yp5
DHT11 Help !!!
- kiddigital
Re: DHT11 Help !!!
- kiddigital
Re: DHT11 Help !!!
Ok, the sensor gets updated as you can see the ‘last updated’ timestamp.
We now need to now how we provide the correct values to the sensor based on its type.
Try this on the command line
As see what it does.
Play around with the values between the quotes of svalue.
curl -s -i -H "Accept: application/json" "http://$SERVER/json.htm?type=command¶m=udevice&idx=10&nvalue=0&svalue=“11;77”
Re: DHT11 Help !!!
its stay like that what can i type next?
https://prnt.sc/v532c2
- kiddigital
Re: DHT11 Help !!!
Press CTRL+c to abortarhangel76 wrote:its stay like that what can i type next?
Remove the “ before http and try again
- kiddigital
Re: DHT11 Help !!!
Replace $SERVER with 127.0.0.1:8080
- kiddigital
Re: DHT11 Help !!!
Replace both the “ at the end with ‘
- kiddigital
DHT11 Help !!!
The command should be
If it return 401 Unauthorized, there is a permission issue to solve first.
Hopefully this works
curl -s -i -H "Accept: application/json" ‘http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=10&nvalue=0&svalue=“11;77”’
- kiddigital
Re: DHT11 Help !!!
Ok, we are fighting with the command line interpreter here. I will try it myself and get back to you later...
Maybe you can google in the mean time to figure out how a correct command should look like. I think there should be plenty examples on this forum.
Re: DHT11 Help !!!
its hard for newbye like me,im not understand to much
Re: DHT11 Help !!!
i find new script:
https://prnt.sc/v583et
and contain this text:
import Adafruit_DHT
import time
DHT_SENSOR = Adafruit_DHT.DHT11
DHT_PIN = 4
while True:
humidity, temperature = Adafruit_DHT.read(DHT_SENSOR, DHT_PIN)
if humidity is not None and temperature is not None:
print("Temp={0:0.1f}C Humidity={1:0.1f}%".format(temperature, humidity))
else:
print("Sensor failure. Check wiring.");
time.sleep(3);
import Adafruit_DHT
import time
DHT_PIN = 4
while True:
else:
time.sleep(3);
Re: DHT11 Help !!!
So nobody know?
i use this tutorial:
https://www.thegeekpub.com/236867/using ... spberry-pi
and the result is here:
https://prnt.sc/v61hoz
I want only to show in domoticz page...
- kiddigital
Re: DHT11 Help !!!
@arhangel76
Please try the command below. Make sure you have the double-quotes around both parts
Can you show the output?
And to update the values: You see svalue=10.3;66;0 where the first (10.3) is the temperature and the second (66) the humidity. The third (0) is not used here.
So you have to modify your script to this
curl -s -i -H "Accept: application/json" "http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=10&nvalue=0&svalue=10.3;66;0"
curl -s -i -H "Accept: application/json" "http://$SERVER/json.htm?type=command¶m=udevice&idx=$DHTIDX&nvalue=0&svalue=$TEMP;$HUM;0"
Re: DHT11 Help !!!
Thank you for your help but i succeed,the problem it was whit url link.
Now work just fine
Now work just fine
- ILoveIOT
- Domoticz version: 2020.2
Re: DHT11 Help !!!
1x OPI PC 5.8.16 Debian 10, MiniDNLA,SMD230,EpEver,MPD,800GB,Wiegand,7 temps,DHT,32/64 I/O,2022.1
2x OPI PC 4.19.25 Debian 9, MPD,7 temps,16/32 I/O,BMP,4.10717
1x IntelNUC 5.10 Debian 10, 2TB,DalyBMS,2023.1
3x ESPEasy NodeMCU V3, 16/16 I/O
