Hi to all!
I am using several NodeMCU's applied with ESP Easy as interface between sensors and Domoticz.
For monitoring with an inductive limit switch I am using an input of such a NodeMCU.
The NodeMCU is bound to Domoticz by the IDX.
Once the input is high this will be shown inside Domoticz as a 'locked' door.
But.... several times, if the input on NodeMCU is high Domoticz acts as if the input is low. i.e. shows the door is unlocked.
Any Idea what might be wrong?
TIA
Bart
Interface with ESP Easy fails sometimes
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
