Ikea motion sensor - Off Delay Topic is solved
Varazir
Post by Varazir »
I have 2 Ikea sensors and one is set to 10 min and the second to 3 min.
I want to extend the second to 10 min so I changed the Off Delay but the lamps still turns off after 3 min even if I have set it to 1200 seconds.
Bug or is it something with zigbee ?
I use this script to control my lamps.
	on =
	   	devices =
	        'IKEA - Sensor sovrum'
	logging =
        level           = domoticz.LOG_FORCE,
        marker          = "IKEASensorSovrum"
    execute = function(dz, device)
        local function logWrite(str,level)
                dz.log(tostring(str),level)
        local dimLevel = 0
        logWrite('00...............Sensor triggerd')
        if dz.time.isNightTime or dz.devices(59).state == 'Closed' then
            if device.state ~= 'On' then
                dimLevel = 0
                logWrite('10...............Turning off the light')
                dimLevel = 60
                logWrite('20...............Night time')
            logWrite('30...............Dim value is ' .. dimLevel ..'%')
                dz.devices('IKEA - Taklampa Sovrum').dimTo(dimLevel)
                dz.devices('IKEA - Taklampa Hall').dimTo(dimLevel)
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Re: Ikea motion sensor - Off Delay
Varazir wrote: Monday 19 October 2020 20:46 Bug or is it something with zigbee ?
Neither.
By setting an off Delay you tell domoticz to switchOff() the device the amount of seconds after it has been switched On. It does not delay the switchOff() when the device receives a switchOff() command from a script-, hardware or API.
Varazir
Post by Varazir »
Neither.
Oh okay, I guess it's good to post your own setup so you can find another way.
What I mean after reading my script and your post I realized that I can set the delay in the script.
I was hoping that the device settings would override all commands. Oh well.
Daniel
Skickat från min EML-L29 via Tapatalk
Varazir
Post by Varazir »
Something like this should work right ?
It will extend the light with 5 min each time the sensor is triggered ( after the initial 5 min ) I hope :)
	on =
	   	devices =
	logging =
        local dimLevel = 0
        local delayTime = 0
                dimLevel = 0
                delayTime = 300
                dimLevel = 60
                delayTime = 0
                dz.devices('IKEA - Taklampa Sovrum').cancelQueuedCommands()
                dz.devices('IKEA - Taklampa Hall').cancelQueuedCommands()
                dz.devices('IKEA - Taklampa Sovrum').dimTo(dimLevel).afterSec(delayTime)
                dz.devices('IKEA - Taklampa Hall').dimTo(dimLevel).afterSec(delayTime)
