Midea/Inventor (and other brand) Air Condition API
Alain
Domoticz version: 2022.1
Re: Midea/Inventor (and other brand) Air Condition API
Post by Alain »
No, I haven't had that issue. It's been running for about a week now, with three units connected, and the only thing I see happening is that the room and outside temperatures sometimes (simultaneously) return 0°C. Apart from that, no issues as yet. the unit's measured outside temperatures apparently don't refresh too often either. Looking in the logs, the outside temperature stays the same for hours at a time.
On one of the units I've also created a blockly script to automatically turn the unit off if the power is "On" at midnight. That works too.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | Qlima | Solaredge
TP-Link | Plugwise | Thermosmart | Node-Red | Grafana | Master and 5 remote servers
LouiS22
Post by LouiS22 »
Alain wrote: Sunday 12 July 2020 19:25 No, I haven't had that issue. It's been running for about a week now, with three units connected, and the only thing I see happening is that the room and outside temperatures sometimes (simultaneously) return 0°C. Apart from that, no issues as yet. the unit's measured outside temperatures apparently don't refresh too often either. Looking in the logs, the outside temperature stays the same for hours at a time.
Interesting, mine's doing this issue and haven't been able to find what triggers it.
Alain
Post by Alain »
Does it always do that with "Eco" and the temperature setting? Or is it random and will sometimes change the fan speed or on/off etc also?
Alain
Post by Alain »
Any errors showing up? Or strange "OnCommands"?
LouiS22
Post by LouiS22 »
Alain wrote: Sunday 12 July 2020 19:59 Any errors showing up? Or strange "OnCommands"?
I tested it now, and the obvious change is the following:
20-07-20 10:53:39.493 Status: User: Admin initiated a switch command (11990/Klíma - Mode/Set Level)
2020-07-20 10:53:43.143 Error: (Klíma) Level is: 50
Sure I won't switch it anything, but the AC finished the ECO mode and started to heat.
Alain
Post by Alain »
LouiS22 wrote: Monday 20 July 2020 10:57
I'm getting the error after a switch command too, but after that it still performs the command that I wanted. I'm not sure why it is giving that error. I haven't looked into it very much to be honest, because after all, it's still doing what I want it to do.
Domoticz version: 2024.7
LouiS22 wrote: Monday 06 July 2020 12:21
Alain wrote: Saturday 04 July 2020 23:50 I created a repository, but but it's all a bit messy. Not quite sure how to properly go about it as I have used parts from Mac_Zhou (msmart repo) and from NeoArcheron (to obtain device id).
Here's a link to my plugin: https://github.com/awalsum/Qlima
During your tests have you noticed an issue where the AC somehow changes its state (ie from 24 celsius and ECO to ECO OFF and 27celsius) without any interaction?
I had these issue too (BTW thanks Alain for this plugin!).
I fixed it by outcommenting lines 284, 299, 311 as they where trying to update the the Domoticz device with an invalid value like:
Devices[5].Update(nValue=device.power_state, sValue=str(device.operational_mode))
device.operational_mode is auto, heat, cool etc but the Device[5] sValue is expecting 10, 20 30 etc
LouiS22
Post by LouiS22 »
waltervl wrote: Sunday 27 September 2020 22:03
nice fix! :)
Alain
Post by Alain »
Thanks waltervl. I had another look at the code and outcommented some lines. I updated the repository on Github.
Thanks Alain.
I have another issue that is related to internet connection issues. It seems that when the device cannot be reached, midea refresh() gives back the values in _init_.
So I get sometimes values of 0.0 or 20 for values of indoor, outdoor and target temperatures.
I made an issue for this at the original mmac-zhou/midea-ac-py author because I think it cannot be solved easily in Domoticz plugin. But I am not a Python expert.
https://github.com/mac-zhou/midea-ac-py/issues/38
Last edited by waltervl on Wednesday 28 October 2020 19:41, edited 1 time in total.
Alain
Post by Alain »
waltervl wrote: Sunday 18 October 2020 17:59 Thanks Alain.
https://github.co/mmac-zhou/midea-ac-py/issues/38
Without having looked into a solution in depth, I'm not sure that there is an easy solution. The units themselves are very unstable in keeping an internet connection. Long before I had even looked into implementing them into Domoticz, I had already connected smart switches in the wall outlets for the power to the devices because often they would appear offline in the Nethome app. The only way to get them online again was to power them down, wait a few seconds and them power them up again. Although the devices cannot be reached in Domoticz intermittently and after a few heartbeats they can again, I do believe this is related.
The only fix I can think of, just quickly, is to verify if the newly obtained value is not equal to zero, then update the Domoticz device, else retain the old value, but that wouldn't work for the power function. When the connection drops, it's default is "False"which is "Off" and that would mean that a genuine "Off" command would never be allowed and therefore be processed.
I have come to just accept this for now.
I did not accept ;-)
I followed your suggestion and checked for the init values and raise an ConnectionError exception when they do. This will skip the updating of Domoticz values so no more 0 degree spikes in temp logging. In the end when the connection fails to many times (eg due to failing Wifi dongle in the device) Domoticz will see the non responsiveness and make the devices color red if it reaches the sensor timeout (default 90 minutes).
I will let it run now for a couple of days, see how it works out.
    def DataUpdate(self):
        device_ip = Parameters["Address"]
        device_id = Parameters["Mode3"]
        client = midea_device(device_ip, int(device_id),6444)
        device = client.setup()
        try:
            device.refresh()
            if device.indoor_temperature == 0.0 and device.indoor_temperature == 0.0 and device.target_temperature == 20.0:
               raise ConnectionError('Could not connect with device',)
            ******* Device updates *************
        except ConnectionError as error:
            Domoticz.Error(repr(error))
            return
        except:
            Domoticz.Error("Qlima (" + Parameters["Address"] + ") unavailable")
            return
After a couple of days running with the previous solution no more irregularities! Everything works fine.
A couple of times a day I see the connection error. I have the refresh time of the plugin set to 120 seconds.
daemonshome
Post by daemonshome »
Iam trying to setup mudea ac in domoticz, without success.
Anything I am doing wrong?, any hints would be appreciated :).
So far:
# midea-discover
INFO:msmart.cli:msmart version: 0.1.23
INFO:msmart.cli:Sending Device Scan Broadcast...
INFO:msmart.cli:Midea Local Data 192.168.1.102 xyz
INFO:msmart.cli:Decrypt Reply: 192.168.1.102 xyz
INFO:msmart.lan:Couldn't connect with Device 192.168.1.102:6444
INFO:msmart.cli:*** Found a unsupported device - type: '0xac' - version: V3 - ip: 192.168.1.102 - por
t: 6444 - id: xyz - sn: xyz - ssid: net_ac_A755
xyz-removed characters
So from here it is visible that the AC is in local network. midea app works as expected, no issues here.
qlima plugn installed into domoticz.
So I have the ip address and port, which I put into qlima plugin inside domoticz. Done.
Log below:
2020-10-25 14:05:41.363 Status: (qlimaAC) Stop directive received.
2020-10-25 14:05:41.629 Status: (qlimaAC) Exiting work loop.
2020-10-25 14:05:41.663 Status: (qlimaAC) Stopping threads.
2020-10-25 14:05:41.663 Status: (qlimaAC) Stopped.
2020-10-25 14:05:41.663 Status: (qlimaAC) Started.
2020-10-25 14:05:41.779 Status: (qlimaAC) Entering work loop.
2020-10-25 14:05:41.779 Status: (qlimaAC) Initialized version 1.0.0, author 'Alain'
2020-10-25 12:16:06.545 Status: New sensors allowed for 5 minutes...
2020-10-25 14:10:15.711 Status: Receiving of new sensors disabled!...
Sensors are available trough domoticz, but values are not updating.
Any addvice?
Looks like your device is not supported by the midea library that works as the core of the plugin.
What brand and type is your Airconditioning?
Can you controll it through the Nethome plus app on your phone? Or do you use another app?
daemonshome
Midea MBT-12N8D6-O Mission II 3,5 kw
App: Midea Air - working good
As per the forum discussions, midea should work...
What happens if you fill in your device in the example.py of the midea library? You will have to add to port address 6444 in the device declaration in line 9:
c = midea_device('YOUR_AC_IP', YOUR_AC_ID, 6444)
https://github.com/mac-zhou/midea-msmar ... example.py
If you run this with "python example.py" do you see communication?
daemonshome
[b]# python example.py[/b]
  from msmart.device import device as midea_device
File "/home/test/midea-msmart-master/msmart/device.py", line 17
  def convert_device_id_hex(device_id: int):
SyntaxError: invalid syntax
[b]# python3 example.py[/b]
{'id': 'xy', 'name': '192.168.1.102', 'power_state': False, 'prompt_tone': False, 'target_temperature': 17.0,'operational_mode': <operational_mode_enum.auto: 1>, 'fan_speed': <fan_speed_enum.Auto: 102>, 'swing_mode': <swing_mode_enum.Off: 0>, 'eco_mode': False, 'turbo_mode': False, 'indoor_temperature': 0.0, 'outdoor_temperature': 0.0}{'id': 'xy', 'name': '192.168.1.102', 'power_state': True, 'prompt_tone': False, 'target_temperature': 25, 'operational_mode': <operational_mode_enum.cool: 2>, 'fan_speed': <fan_speed_enum.Auto:102>, 'swing_mode': <swing_mode_enum.Off: 0>, 'eco_mode': False, 'turbo_mode': False, 'indoor_temperature': 0.0, 'outdoor_temperature': 0.0}
so it seems no , :(
other ideas, libs?
Looks like it is not connecting to your Midea on python 3. In- and outdoor temperature are reported as 0.0 which is indicating there is no connection.
I read somewhere that there is a difference in wifi dongle version OSK102 and OSK103. 102 is working with this lib, version 103 seems not to be.
Edit: I just checked my wifi dongle manual and it states I have a OSK102.
daemonshome
Correct.
mine is OSK103.
If any addvice would come, what to try, I am in to investigate/develop the solution.
Thanks for the hints and help so far.
