MQTT not working with zwave devices
naps1saps
Post by naps1saps »
I got my system configured with an MQTT broker and installed Node-Red to interface with Google Home. It's all working with Domoticz.
I created a node in Node-Red to turn on a zwave switch via MQTT and Domoticz shows the switch turning on and off in the interface but the zwave commands are not sent to the device to actually turn it on/off.
Is this a bug? How do I get this to work?
FireWizard
Re: MQTT not working with zwave devices
Post by FireWizard »
Hi, @naps1saps
See: viewtopic.php?f=6&t=31711&hilit=mqtt&start=20
Your setting in "Prevent Loop" should be "False".
naps1saps
Post by naps1saps »
Yeah I saw that and tried it already and I get the same result that the interface turns on/off but no zwave command is sent. I still have it set to false.
LOG: you can see no zwave command is sent after the MQTT is received. I manually flipped the switch afterwards to show what happens in the log.
2020-10-17 11:55:32.450 MQTT: Topic: domoticz/in, Message: {"idx":92,"nvalue":1}
2020-10-17 11:55:47.945 OpenZWave: Domoticz has send a Switch command! NodeID: 3 (0x03)
2020-10-17 11:55:47.972 (ZWave) Light/Switch (Kitchen Light)
2020-10-17 11:55:47.944 Status: User: Admin initiated a switch command (92/Kitchen Light/Off)
2020-10-17 11:55:48.981 OpenZWave: Domoticz has send a Switch command! NodeID: 3 (0x03)
2020-10-17 11:55:48.980 Status: User: Admin initiated a switch command (92/Kitchen Light/On)
2020-10-17 11:55:49.000 (ZWave) Light/Switch (Kitchen Light)
jvdz
Domoticz version: 4.107
Post by jvdz »
Have you tried it as described in the WiKi?: https://www.domoticz.com/wiki/MQTT#Send ... ch_Command
{"command": "switchlight", "idx": 92, "switchcmd": "On" }
Jos
naps1saps
Post by naps1saps »
Wish I would have found that last week when I was searching. Thanks.
