I have a counter updating every minute. is this a bug or Is it possible to disable those logmessages?2018-04-19 14:26:00.520 Set UserVariable counter = 27
2018-04-19 14:27:00.320 Set UserVariable counter = 28
2018-04-19 14:28:00.431 Set UserVariable counter = 29
Log Messages [SOLVED]
- DewGew
- Domoticz version: V4.10618
Log Messages
After I updated to latest beta v3.9269. I recive update uservarable in my log when I update a uservarable thrue dzVents.
dannybloe
Re: Log Messages [SOLVED]
It's not something caused by dzVents. Clearly somewhere in Domoticz got changed. I guess they want to bring this more in line with the rest of the logging. If you change a device like switching a switch, you also see this in the logs.
- DewGew
Re: Log Messages
Its a status change, same color as script logs but I'm not getting it when using lua..
commandArray['Variable:MyVar']='Some value'
MikeF
- Domoticz version: V2022.2
Re: Log Messages
I'm still not convinced by this. I have been running a dzVents script regularly for months, and I have just added these lines:dannybloe wrote: Wednesday 25 April 2018 11:32 It's not something caused by dzVents. Clearly somewhere in Domoticz got changed.
local d_setp_upd = dz.variables('setpoint')
local setpoint_updated = 0
-- do some code
d_setp_upd.set(setpoint_updated)
Status: Set UserVariable setpoint = 0
- waaren
Re: Log Messages
This statusmessage comes from deep down in domoticz.
main/SQLHelper.cpp:3600: _Log(LOG_STATUS, "Set UserVariable %s = %s", sd[0].c_str(), CURLEncode::URLDecode(itt->_sValue).c_str());You could also suppress the status messages to the log in your domoticz configurations settings. (/etc/init.d/domoticz.sh )
MikeF
Re: Log Messages
Of course! Thanks!waaren wrote: Sunday 11 October 2020 1:31 In dzVents you could check the value of the var and only set the value when it is different
