Read British Gas Hive Heating temperature
homemonitor
Re: Read British Gas Hive Heating temperature
How do you get it to work with the new two-factor login? My monitoring stopped working on 30/9.
My script failed a couple of hours ago. Now when I try to get a session from
https://api.prod.bgchprod.info/omnia/auth/sessions
I get
"genericError": {
"error": {
"reason": "GONE",
"message": "Not supported anymore"
I can get an OAuth Bearer Token, using the Authorize button at
https://api.prod.bgchprod.info/omnia/swagger-ui.html
so instead of the header
X-Omnia-Access-Token: <SESSIONID>
you can use
Authorization: Bearer <TOKEN>
but this only lasts a while and I can't find a way to refresh it.
https://oauth.prod.bgchprod.info/oauth2/token
seems to want to play ball, but with no documentation, I can't work out what to pass it, so I always just get an Unauthorized response.
Can anyone who's better at internet protocols than me figure it out?
I get
"genericError": {
"error": {
"reason": "GONE",
you can use
dgilbert2
- Domoticz version: 2024.7
My Hive scripts also stopped working at 14:30 today
. My account though does not (yet?) require any two-factor login.
Maybe it will start working again soon!!?? I'm fearing not though!
orionn2o
Another person who's Hive dropped out today at 14:30 after working flawlessly for years
I wasn't specifically using a python plugin, just Bash with some Curl scripts.
Started getting the same error "not supported anymore"
does this mean I've now got to go get a new heating control system ...
Ive heard EvoHome is pretty good
mark.sellwood
I'm looking to move to something else possibly Nest due to the problems with Hive.
My Hive hub drops off the internet randomity, Hive have admitted its a software issue but will not be fixing it, they have given me 2 options, pay to replace the hub or plug the hub in to a time switch & power cycle it daily.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
OK, I'm making progress. By using Stream (an iOS network debug tool) to sniff the protocol from the iOS Hive app, I've found that it calls
https://beekeeper-uk.hivehome.com/1.0/c ... resh-token
passing it a token, accessToken and refreshToken
It gets the same items back with new values, and "token" can be used to access the API using
--header 'Authorization: Bearer '$TOKEN
This seems to be working - it's clumsy having to get your initial tokens from Stream, but from a bit more sniffing, it seems like the initial login is a complex challenge/response interaction with AWS. So long as I set a script to refresh my tokens every 30 min though, I hopefully won't have to do this again.
dgilbert2
Some more clues maybe??
I looked at https://community.smartthings.com/t/hiv ... g/206851/8 and github https://github.com/alyc100/SmartThingsP ... ect.groovy, although a different platform / project, they have managed to get the hive api to work again by changing to https://beekeeper.hivehome.com/1.0/cognito/login.
I don't know though how to get this working on the scripts we use here. eg I've tried changing the login lines as below;
...but this produces an error "MALFORMED_REQUEST".
Hopefully someone who understands these scripts better than me can get it working as it does seem possible if you know what your doing
login=$(curl -s -k --cookie-jar cookie.jar -g -H "Content-Type: application/vnd.alertme.zoo-6.4+json" \
-H "Accept: application/vnd.alertme.zoo-6.4+json" -H "Content-Type: 'application/*+json'" \
-H "X-AlertMe-Client: Hive Web Dashboard" \
-d '{"sessions":[{"username": "xx@xx", "password": "xx", "devices": false, "products": false}]}' \
https://beekeeper.hivehome.com/1.0/cognito/login)
dgilbert2
FIXED!!!
The login & sessionId sides of the script needs updating as below, which is based on Mike's older version, but it worked for me
(Only applicable if your still using MikeF's original V6 script.)
#!/bin/bash
# Sends current and target temperatures to Domoticz
cd "${0%/*}"
login=$(curl -s -k -g -H "Content-Type: application/json" \
-H "Accept: application/json" \
-d '{"username":"xx@xx","password":"xx"}' \
sessionId=$(echo $login | python -c 'import sys, json; print json.load(sys.stdin)["token"]')
dgilbert2
Easiest way to get things working is to turn off two-factor login. In the Hive app go to the three bars in the top corner, Account, My Details and then edit Two Factor authentication to disabled.homemonitor wrote: Friday 02 October 2020 17:10 How do you get it to work with the new two-factor login? My monitoring stopped working on 30/9.
mark.sellwood
I have never setup two-factor login & its showing as disabled but still the Plugin isn't working.
dgilbert2
Got ya. Hopefully @imcfarla will update the plugin soon with the revised Hive API login details as detailed above.mark.sellwood wrote: Saturday 03 October 2020 13:51 I have never setup two-factor login & its showing as disabled but still the Plugin isn't working.
Good jobs, thanks! This is the final piece of the jigsaw - it annoyed my having to store my login credentials on my IoT devices, but this lets me generate tokens on my laptop, then pass them over for periodic refreshing on the ESP. Thanks!dgilbert2 wrote: Saturday 03 October 2020 12:25 FIXED!!!
The login & sessionId sides of the script needs updating as below, which is based on Mike's older version, but it worked for me![]()
#!/bin/bash # Sends current and target temperatures to Domoticz cd "${0%/*}" login=$(curl -s -k -g -H "Content-Type: application/json" \ -H "Accept: application/json" \ -d '{"username":"xx@xx","password":"xx"}' \ https://beekeeper.hivehome.com/1.0/cognito/login) sessionId=$(echo $login | python -c 'import sys, json; print json.load(sys.stdin)["token"]')
orionn2o
brill well done
back up and running again phew!
If i could ask, how did you debug this?
dgilbert2
I added "echo $login" to the bash script so that I could see what was going on when manually running it in PuTTY.
I'm sure there are much smarter ways though
imcfarla
Panic over I have updated both the plugin.py and plugin.urllib.py
both are now version 1.2 and should handle the new login API
dgilbert2
Where do you download these files from? Thanksimcfarla wrote: Sunday 04 October 2020 0:04 Panic over I have updated both the plugin.py and plugin.urllib.py
EDIT:
Found them
dgilbert2
@imcfariaimcfarla wrote: Sunday 04 October 2020 0:04 Panic over I have updated both the plugin.py and plugin.urllib.py
I still use the original bash script by MikeF and have found the Logout section no longer works (so have #'ed it out for now). I see the equivalent "def onStop(self)" in your plugin code also has remarks that its not currently working. I would be interested how you manage to fix this in the future so I can go back and update my bash scripts. I guess though this is a "nice to have" for now, to end the session rather than keep asking for new tokens. At least the main parts are all working now
Och
Thank you!imcfarla wrote: Sunday 04 October 2020 0:04 Panic over I have updated both the plugin.py and plugin.urllib.py
My system failed on Friday and I had to rebuild yesterday. It took me a few hours to work out that the Hive plug-in not working was nothing to do with me rebuilding the system. Great to have the plug-in updated so quickly.
roadsnail
- Domoticz version: 13314
Thank you for the quick fix!imcfarla wrote: Sunday 04 October 2020 0:04 Panic over I have updated both the plugin.py and plugin.urllib.py
BTW. I am still running a very of version of plugin.urllib.py so I was able to fix my old version by patching GetSessionID from your github version. But in doing so I spotted that you need to add a close curly bracket to the end of line 806, (only in the plugin.urllib.py version), else a syntax error is thrown at execution time.
ie line 806...
payload = {'username':Parameters["Username"], 'password':Parameters["Password"]
becomes
payload = {'username':Parameters["Username"], 'password':Parameters["Password"]}
Thanks again!
Cheers
Chris
_______________________________________________________________________________________________
Pi4, Z-Wave: Danfoss TRVs, aeotec hem, d-link siren, heiman door contacts. Hive heating ctrl, esp8266 based sensors, zigbee2mqtt, Zigbee bulbs etc
imcfarla
Fixed that now - thanks
