Dashticz Dial - Features, Fixes & Updates
Bochelork
Re: Dashticz Dial - Features, Fixes & Updates
Post by Bochelork »
Wow, that looks great, I will give it a try this weekend! Thanks!`
Do other types work as well? Watt, KWh? I've still empty slots....
Dashticz Watt:
blocks['379_1'] = {
  width: 4,
  type: 'dial',
Dashticz KWh:
blocks['379_2'] = {
  width: 4,
  type: 'dial',
Domoticz:
Idx 	Hardware ID		Unit	Name	Type	SubType	Data
379	Panelen	00082379	1	GroWatt	General	kWh	2.700 kW
Lokonli
Post by Lokonli »
Bochelork wrote: Friday 02 October 2020 11:42 Wow, that looks great, I will give it a try this weekend! Thanks!`
Dashticz Watt:
blocks['379_1'] = {
  width: 4,
  type: 'dial',
Dashticz KWh:
blocks['379_2'] = {
  width: 4,
  type: 'dial',
Domoticz:
blocks[6] = {
    type:'dial',
    values: ['CounterToday'],
    showunit: true
blocks[46] = {
    type:'dial',
    showunit: false
blocks[636] = {
    type:'dial',
    showunit: true
blocks[1027] = {
    type:'dial',
    showunit: true
blocks[1028] = {
    type:'dial',
    showunit: true
columns[2] = {}
columns[2] = {
    blocks: [
        6, 46, 636, 1027, 1028
    width: 6
Lokonli
Post by Lokonli »
Set the min/max parameter to position the dial correctly (and get better formatting ...)
Example: L1 return from my P1 meter:
blocks[759] = {
    type:'dial',
    min: 0,
    max: 3000,
    showunit: true
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
How you get the new dials smaller
I've the other one at 50%, but the new add dials are 100%
I've this is my custom.css
.dial-center 				{height: 50%!important;width: 50%!important;}
The inner ring is smaller, but the outer ring remain large
Found it !
in CONFIG.js
blocks[262] = {width: 2,type:'dial',.....}
zenit
Post by zenit »
Hi Lokonli,
Thanks for your great development and support on this! :D . The new dials are working perfect over here.
Lokonli wrote: Thursday 01 October 2020 20:32 ok.
beta 3.6.3
Give it a try :)
See:
https://dashticz.readthedocs.io/en/beta ... neric-dial
Bochelork
Post by Bochelork »
The generic dial works great. Thanks.
I've a request about the dimmer dials. Now you have to control them by dragging the dial, would it be possible to add the option to just click on the position to set the dimmer? (e.g. click on top of outer ring to set 50%)
Mrblomme
Post by Mrblomme »
Hi all
I'm new here and got my dashticz running for a few days now. At this moment I've implemented Dial for my Tado thermostats.
The problem I'm having is that I cant switch the temperature (setpoin/desiredt) at the temp/hum dial and I cant see the temperature at the setpoint dial...
Is it possible to combine the 2? So I can adjust the temperature and also see the current temp in 1 dial?
Lokonli
Post by Lokonli »
Mrblomme wrote: Friday 09 October 2020 9:12 Hi all
For some devices this will work already. As an example, define your block as follows:
blocks['thermostat'] = {
    title:'Living Room',
    idx: 25,
    temp: 27,
    type:'dial',
In this case '25' is the Domoticz device id of the thermostat device. '27' is the temperature device.
Currently the temperature in my living room is 20,9 degrees (device 27), while the central heating setpoint is 17,7 degrees (device 25). By turning the needle, the setpoint will be adjusted.
HansieNL
Post by HansieNL »
Is it also possible to have one dial with setpoint, temperature and humidity?
Blah blah blah
Lokonli
Post by Lokonli »
HansieNL wrote: Friday 09 October 2020 17:26 Is it also possible to have one dial with setpoint, temperature and humidity?
Not yet,,,
What would be a clean way to define such a dial?
What do you think of the following:
block['myblock'] = {
  type: dial,
  values: [
        idx: 12,
        value: 'Temp'
       idx: 13,
       value: 'Setpoint',
       isSetpoint: true
      idx: 14,
      value: 'Humidity'
In this example we combine the data from three devices (12, 13, 14). but you can use the same idx as well.
The first value will be used as the central big number in the dial block (device 12, temperature). The needle will be used to set the device labeled with isSetpoint: true
Would this be useful?
(To be clear: Currently this is not implemented yet)
HansieNL
Post by HansieNL »
Lokonli wrote: Friday 09 October 2020 19:23
Not yet,,,
  type: dial,
  values: [
        idx: 12,
        value: 'Temp'
       idx: 13,
       value: 'Setpoint',
       isSetpoint: true
      idx: 14,
      value: 'Humidity'
That will be a good way I think. Take your time to implement this option.
Blah blah blah
madpatrick
Is it possible to get a color change or some kind of alert when a value is too high
Like you can do with a normal block in custom.js
function getStatus_262(block){
var idx = block.idx;
var device = block.device;
   if(parseFloat(device['Data'])>2){
      block.addClass='warning';
if(parseFloat(device['Data'])<1.4){
   else {
      block.addClass='';
meatpuppet
Post by meatpuppet »
I installed Dashticz successfully, however for some reason I can't set the min/max values on my thermostat-setpoint. Is it possible on this specific device or did I miss something ? Here is the code:
blocks['tsalon_manu'] = {
        idx: 24,
        title: 'Salon_MANU',
        type: 'dial',
        width: 6,
        min: 15,
        max: 25,
        setpoint: 20,  // this value will be used to control the color of the outer ring, e.g. < 15 is blue, >= 15 is orange
        shownumbers: true,  // display the numbers on the dial (default is false)
        showring: true, // display outer ring color all the time (default is false, will only display when hover over)
        showunit: true // display unit for the dial value (default is false)
The min and max remain default values...
Thanks a lot for your support!
Lokonli
Post by Lokonli »
HansieNL wrote: Friday 09 October 2020 20:14
Not yet,,,
  type: dial,
  values: [
        idx: 12,
        value: 'Temp'
       idx: 13,
       value: 'Setpoint',
       isSetpoint: true
      idx: 14,
      value: 'Humidity'
Try latest beta :)
Lokonli
Post by Lokonli »
meatpuppet wrote: Saturday 10 October 2020 20:09 Hi,
        idx: 24,
        type: 'dial',
        width: 6,
        min: 15,
        max: 25,
Try latest beta.
madpatrick
Hi Lokonli,
I lost 2 dials after the latest beta.
blocks['gr_tuin'] 		= {idx: 's1',type: 'dial', color: '#ffff00', width: 3, last_update: false, title: ' '}
blocks['gr_kamer'] 		= {idx: 's2',type: 'dial', color: '#ffff00', width: 3, last_update: false, title: ' '}
blocks['ventilatie'] 		= {idx: 112, type: 'dial', color: '#ffffff', width: 3, last_update: false, title: ' '}
blocks['dimmer_hal']	 	= {idx: 154, type: 'dial', color: '#ffff00', width: 3, last_update: false, title: ' ', shownumbers: true, showring: true, showunit: true}
The group dials idx:'s1' and idx:'s2' are not visible anymore after your last update
meatpuppet
Lokonli wrote: Saturday 10 October 2020 22:15
        idx: 24,
        type: 'dial',
        width: 6,
        min: 15,
        max: 25,
Try latest beta.
Thanks, that works. However now when I click on the dial to change the setpoint value it does not update anymore in Dashticz (it does in domoticz). I need to refresh the page to see the updated value on the dial... Did I miss something?
Lokonli
Post by Lokonli »
madpatrick wrote: Sunday 11 October 2020 11:19 Hi Lokonli,
s1 and s2 are scenes/groups, and indeed that will not work at the moment.
I even was not aware it was working for scenes/groups.
I'll fix it in the next beta.
Lokonli
Post by Lokonli »
meatpuppet wrote: Sunday 11 October 2020 13:48
        idx: 24,
        type: 'dial',
        width: 6,
        min: 15,
        max: 25,
Try latest beta.
I had to change the update mechanism to support multi-device. I'll check.
Mrblomme
Post by Mrblomme »
Lokonli wrote: Friday 09 October 2020 16:01
    idx: 25,
    temp: 27,
    type:'dial',
Done! Thanks!
