Dashticz v3.6 master
Lokonli
Re: Dashticz v3.6 master
Post by Lokonli »
Do you see issues with all your graphs?
Can you post the code from CONFIG.js for a graph with problems?
Remelco
Domoticz version: 2020.1
Post by Remelco »
Yes , I have 2 graphs and both have the same problem.
Also the icons are disappeared from nu.nl and nos.nl
my config.js of the graphs:
// Definition 'Elektriciteit' graph
blocks[p1_grafiek_elektra] = {
title: 'Energie',
graph: ['line','bar','bar'],
custom : {
"vandaag": {
range: 'day',
filter: '12 hours',
data: {
netto: 'd.v+d.v2-d.r1-d.r2',
gebruikt: 'd.v+d.v2',
geleverd: '-d.r1-d.r2'
"maand": {
range: 'month',
filter: '1 months',
data: {
"jaar": {
range: 'year',
filter: '12 months',
data: {
legend: true,
datasetColors:['blue','red','yellow']
// Definition 'Gas' graph
blocks[p1_grafiek_gas] = {
title: 'Gas',
width: 12,
height: '425px',
custom : {
"dag": {
graph: 'bar',
range: 'day',
filter: '24 hours',
data: {
Gas: 'd.v'
"maand": {
graph: 'bar',
range: 'month',
data: {
Gas: 'd.v'
"jaar": {
graph: 'line',
range: 'year',
data: {
Gas: 'd.v'
legend: false,
datasetColors: ['yellow'],
displayFormats : {
minute: 'h:mm',
hour: 'h:mm',
day: 'DD MMM',
week: 'DD MMM',
month: 'MMM',
Lokonli
Post by Lokonli »
Remelco wrote: Tuesday 29 September 2020 20:19 Yes , I have 2 graphs and both have the same problem.
    title: 'Energie',
    custom : {
        "vandaag": {
            range: 'day',
            filter: '12 hours',
            data: {
        "maand": {
            range: 'month',
            filter: '1 months',
            data: {
        "jaar": {
            range: 'year',
            data: {
    legend: true,
	title: 'Gas',
  width: 12,
  height: '425px',
  custom : {
  	"dag": {
               graph: 'bar',
  		range: 'day',
                filter: '24 hours',
		  data: {
		  	Gas: 'd.v'
  	"maand": {
               graph: 'bar',
  		range: 'month',
		  data: {
		  	Gas: 'd.v'
  	"jaar": {
               graph: 'line',
  		range: 'year',
		  data: {
		  	Gas: 'd.v'
  legend: false,
	  displayFormats : {
	  minute: 'h:mm',
	  hour: 'h:mm',
	  day: 'DD MMM',
	  week: 'DD MMM',
	  month: 'MMM',
How did you define p1_grafiek_elektra and p1_grafiek_gas?
Remelco
Post by Remelco »
Is this what you meant?
var p1_elektra_nu = '56_1';
var p1_elektra_vandaag = '56_2';
var p1_elektra_totaal = '56_3';
var p1_grafiek_gas = 'graph_57';
var p1_grafiek_elektra = 'graph_56';
Jimster
Post by Jimster »
I use an older tablet (Samsung Galaxy Tab 3) for Dashticz, since 3.6 the OWM data isn't visible anymore. I tried an incognito tab, cleared browser data and cookies, restarted, but no luck. On every other devices the data is visible. I guess this is because of the older Android version (4.4.2). I'm tried Chrome and Fully Kiosk Browser. Does this have anything to do with CORS not being supported?
Lokonli
Post by Lokonli »
Remelco wrote: Tuesday 29 September 2020 21:14 Is this what you meant?
Yes, thanks.
I cannot completely reproduce your issue, but I've fixed some bugs that might have caused this.
Can you test latest beta? (3.6.2)
Lokonli
Post by Lokonli »
For the missing icons: which icons do you mean exactly? Can you attach a screenshot?
If you use an icon from fontawesome check whether the icon still exists (fontawesome.com).
Sometimes you have to completely refresh the cache.
Lokonli
Post by Lokonli »
Jimster wrote: Tuesday 29 September 2020 21:19 I use an older tablet (Samsung Galaxy Tab 3) for Dashticz, since 3.6 the OWM data isn't visible anymore. I tried an incognito tab, cleared browser data and cookies, restarted, but no luck. On every other devices the data is visible. I guess this is because of the older Android version (4.4.2). I'm tried Chrome and Fully Kiosk Browser. Does this have anything to do with CORS not being supported?
Yes, could be.
As a small test, can you try the following:
In the file ./js/weather_owm.js, line 63, remove the first two slashes.
So change:
//    _CORS_PATH +
into
    _CORS_PATH +
Jimster
Post by Jimster »
Lokonli wrote: Tuesday 29 September 2020 22:48
Yes, could be.
So change:
//    _CORS_PATH +
into
    _CORS_PATH +
Yes, it works now.
Lokonli
Post by Lokonli »
Jimster wrote: Tuesday 29 September 2020 23:25
Yes, could be.
So change:
//    _CORS_PATH +
into
    _CORS_PATH +
Yes, it works now.
hmm, interesting.
I have to check why it doesn't work on Android 4.4.2 without CORS proxy.
Lokonli
Post by Lokonli »
Yes, could be.
So change:
//    _CORS_PATH +
into
    _CORS_PATH +
Yes, it works now.
I've slightly changed the request to OpenWeatherMap, which might solve the CORS issue on Android 4.4.2.
Can you help with testing? I don't have an android 4.4.2 device.
The new new file can be downloaded from:
https://raw.githubusercontent.com/Dasht ... her_owm.js
or:
switch to the git branch 'testowm'
Jimster
Post by Jimster »
Lokonli wrote: Wednesday 30 September 2020 14:28
Yes, could be.
So change:
//    _CORS_PATH +
into
    _CORS_PATH +
Yes, it works now.
or:
I did git checkout testown
Tested it, but unfortunately it doesn't work.
Lokonli
Post by Lokonli »
ok, thanks for testing.
I'll add an additional config setting ...
Lokonli
Post by Lokonli »
Jimster wrote: Wednesday 30 September 2020 16:34
Yes, it works now.
or:
I've created a new beta.
Add the following to CONFIG.js to enable the CORS proxy for OWM:
config['use_cors'] = 1;
Can you test the latest beta?
Remelco
Post by Remelco »
Lokonli wrote: Tuesday 29 September 2020 22:31
Yes, thanks.
I have tested the latest beta date 30-9-2020 but stil no graph.
Icon aanwezig.png (36.62 KiB) Viewed 2747 times
Icon weg.png (3.89 KiB) Viewed 2747 times
Grafiek leeg V3.6 (ook bij beta).png (25.96 KiB) Viewed 2747 times
Lokonli
Post by Lokonli »
Remelco wrote: Wednesday 30 September 2020 21:22
Yes, thanks.
hmm, annoying.
Can you open DevTools in Chrome by pressing F12. Then refresh Dashticz. Do you see any error in the DevTools console tab?
or failed network requests on the DevTools network tab?
Jimster
Post by Jimster »
Lokonli wrote: Wednesday 30 September 2020 20:48
Yes with the latest beta and adding this line it works now. Thanks!
Lokonli
Post by Lokonli »
Yes, thanks.
Found it. Totally forgot the following:
The graph now support 'multidevices'
However, that means in the custom graph you have to add the device id to the value, as follows:
    title: 'Gas',
    width: 12,
    height: '425px',
    custom : {
    "dag": {
    graph: 'bar',
    range: 'day',
    filter: '24 hours',
    data: {
    Gas: 'd.v_57'			//_57 added
    "maand": {
    graph: 'bar',
    range: 'month',
    data: {
    "jaar": {
    graph: 'line',
    range: 'year',
    data: {
    legend: false,
    displayFormats : {
    minute: 'h:mm',
    hour: 'h:mm',
    day: 'DD MMM',
    week: 'DD MMM',
    month: 'MMM',
That should do it ...
Remelco
Post by Remelco »
Lokonli wrote: Wednesday 30 September 2020 22:41
Yes, thanks.
    title: 'Gas',
    width: 12,
    height: '425px',
    custom : {
    "dag": {
    graph: 'bar',
    range: 'day',
    filter: '24 hours',
    data: {
    "maand": {
    graph: 'bar',
    range: 'month',
    data: {
    "jaar": {
    graph: 'line',
    range: 'year',
    data: {
    legend: false,
    displayFormats : {
    minute: 'h:mm',
    hour: 'h:mm',
    day: 'DD MMM',
    week: 'DD MMM',
    month: 'MMM',
For the gas the graph is is working.
I am only struggling with the elecric graph. Where can I add the d.v. to d.v._56.
This is not working:
data: {
netto: 'd.v_56+d.v2-d.r1-d.r2',
gebruikt: 'd.v_56+d.v2',
Lokonli
Post by Lokonli »
try:
data: {
netto: 'd.v_56+d.v2_56-d.r1_56-d.r2_56',
gebruikt: 'd.v_56+d.v2_56',
geleverd: '-d.r1_56-d.r2_56'
