heads-up: Error http://json.mijnafvalwijzer.nl/ - only for paying customers...  [Solved]
plugge
Post by plugge »
As of today, mijnafvalwijzer.nl closed down the json response.
2020-09-10 18:10:01.642 Error: Error opening url: http://json.mijnafvalwijzer.nl/?
Only paying customers have access. I pay indirectly via my city community, but that doesn't count as "a paying customer" :x
jsiegmund
Re: heads-up: Error http://json.mijnafvalwijzer.nl/ - only for paying customers...
Post by jsiegmund »
Marked solved but how did you solve it? I was using the same service which now stopped working, which alternative did you switch to?
plugge
Post by plugge »
jsiegmund wrote: Tuesday 29 September 2020 21:35 Marked solved but how did you solve it? I was using the same service which now stopped working, which alternative did you switch to?
There is no Domoticz solution. The alternative is to subscribe to the email notifications.
The 'solved' marker is there because the mystery of the error (empty JSON) was solved.
Re: heads-up: Error http://json.mijnafvalwijzer.nl/ - only for paying customers...  [Solved]
plugge wrote: Tuesday 29 September 2020 22:37 There is no Domoticz solution. The alternative is to subscribe to the email notifications.
@jvdz already worked around it with a "classic Lua" implementation see this post
dzVents version (using the same work-around) can be found here
