Window open -> stop heating
groovesurfer
Post by groovesurfer »
I use different heating sensors (Eurotronic Spirit) and windows open/closed sensors.
Now I want the heating sensor to lower the temperature to 10 degrees when the window is opened. When the window is closed again, the temperature should return to the previous value.
I tried to do this with the following event: Image
This works, but the heating sensor continuously readjusts (every 30 seconds) loudly.
Is there any other way to do this?
My heating plan:
0am - 18 degrees
6am - 21 degrees
9pm - 18 gedrees
Re: Window open -> stop heating
groovesurfer wrote: Monday 28 September 2020 23:02 I use different heating sensors (Eurotronic Spirit) and windows open/closed sensors.
I would not know how to do this in Blockly (probably something with an additional uservariable)
but in dzVents it could look like below script.
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
return
    on =
        devices =
            'Türe Terrasse',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
        marker = 'Heizung',
    execute = function(dz, item)
        local heizung = dz.devices('Heizung Wohnzimmer')
        local function setSetPoint(dv, setPoint)
            local function round(value)
                return dz.utils.round(value, 1)
            if round(dv.setPoint) ~= round(setPoint) then
                dv.updateSetPoint(round(setPoint))
        local function thermostat(dv)
            local setPoint = 18
            if dz.time.matchesRule('at 06:00-21:00') then
                setPoint = 21
        dz.log(item.name .. ' updated. State is now ' .. item.state,dz.LOG_DEBUG)
        if item.state == 'Open' then
            setSetPoint(heizung, 10)
            thermostat(heizung)
groovesurfer
Thank you very much for your reply.
The script works, but when I open the door/window (the heating sensor goes to 10 degrees) an close it again, it goes to 18 degrees and not to 21.
What can I do?
groovesurfer wrote: Tuesday 29 September 2020 9:08 The script works, but when I open the door/window (the heating sensor goes to 10 degrees) an close it again, it goes to 18 degrees and not to 21.
What can I do?
Please try again after changing the line
if dz.time.matchesRule('06:00-21:00') then
to
groovesurfer
Cool, that works. Thank you very much.
groovesurfer
Now it´s after 21:00 o´clock and the heating didn´t change the temperature to 18 degrees.
What can be the mistake?
groovesurfer wrote: Tuesday 29 September 2020 22:22 Now it´s after 21:00 o´clock and the heating didn´t change the temperature to 18 degrees.
So far the script only reacted to a device event. This one should also control the thermostat time based.
return
    on =
        devices =
            'Türe Terrasse',
        timer =
            'at 06:00',
            'at 21:01',
    logging =
        marker = 'Heizung',
            local setPoint = 18
                setPoint = 21
        if item.isTimer then
            thermostat(heizung)
                thermostat(heizung)
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
I have the same constellation with the Eurotonics and window-sensors. I did it in another way. When window is opended, I change the haeating mode to off, when window is closed, I turn it on again. It switches automatically to the last temperature. The time based temperatures are onyl handled in time-plans of the thermostat device. To switch the heater off or on, I have a dummy-switch. When turning this off or on, the eurotonics changes the mode. The advantage of this is, that I see automatically at this switch, if all works correct when window status changes. All is done with lua.
groovesurfer
Thank you for your posts.
@harry: can you tell me it how you have done it with lua? I never used lua before.
harrykausl
If you want to do it with lua, you should test a little bit with that environment. Then I can try to help you.
groovesurfer wrote: I never used lua before.
Yes you did Image
dzVents is 100% Lua
groovesurfer
ah ok :lol:
The script (waaren) works now perfect.
Thank you ;)
