To answer my own questionjberinga wrote: ↑Friday 24 July 2020 8:32 https://github.com/rolandbreedveld/nest-api
Just looking for a confirmation: Is this also working on a Synology NAS with Domoticz running?
Thanks Roland for creating this!
My cookie expired, so I had to get a new one following the instructions on https://github.com/rolandbreedveld/nest-api.CPtje wrote: ↑Friday 24 July 2020 11:32 A strange thing that caught my eye was the beginning of the cookies value: '$cookies = '__Secure-3PSID=zg...'
I have never before seen it beginning with "___Secure"
Again, updating my NEST with a new temperature works! So I would think that authentication should work fine, but the above info says something diferently. So I am really puzzled.
Any help to solve this would be welcome.
I have the same issue. I needed to refresh the cookies, but the $cookies; value started with ___Secure as well, which it didn't before.Superdeboer wrote: ↑Tuesday 18 August 2020 9:06My cookie expired, so I had to get a new one following the instructions on https://github.com/rolandbreedveld/nest-api.CPtje wrote: ↑Friday 24 July 2020 11:32 A strange thing that caught my eye was the beginning of the cookies value: '$cookies = '__Secure-3PSID=zg...'
I get the same value starting with "___Secure", which I never have seen before either. But after updating nest.auth.php with the new values, it still doesn't work.
Also, when I run "bash get_nest.sh -d" on command line, I get an error message identical to the one you posted. I am puzzled... but if I understand correctly, just waiting solves this all in magic way.![]()
shenkie wrote: ↑Monday 24 August 2020 19:37I have the same issue. I needed to refresh the cookies, but the $cookies; value started with ___Secure as well, which it didn't before.Superdeboer wrote: ↑Tuesday 18 August 2020 9:06My cookie expired, so I had to get a new one following the instructions on https://github.com/rolandbreedveld/nest-api.CPtje wrote: ↑Friday 24 July 2020 11:32 A strange thing that caught my eye was the beginning of the cookies value: '$cookies = '__Secure-3PSID=zg...'
Nest-API won't update now and throws an error when running get_nest.
HiPtje wrote: ↑Saturday 12 September 2020 19:46 Hello Roland,
Are there minimum installations need it to make the script work ? Mine worked, but my installation did get corrupted. Nu I have a clean Buster, fully updated with Domoticz Beta. I did install and config, your Nest script, but get a error.
"get_nest.sh: line 39: php: command not found" Do I mis software ?
Greetings,
Peter
Hidjalexnl wrote: ↑Monday 31 August 2020 21:23 Same problem after expiring .... any change how to fix this??
I have a Google account, my previously used Nest account is not in use anymore.Superdeboer wrote: ↑Tuesday 22 September 2020 9:37 This is strange. I tried it again, but I do not get a value with "ANID" at the beginning, like you.
I followed the steps from your instructions carefully, but my cookie starts with "__Secure-3PSID".
Could it be that there are different Google accounts that get different structures for the cookie?
I paired my Google Nest after the account migration that started this thread. So I did not have an old Nest account.
[edit]
Buuuuut... with the cookie values that I retrieved today (note: still not with the extra data before the __Secure-3PSID that rolandbreedveld mentioned!) it does indeed work again, like magic. I don't understand what happened or what the difference is between last time and this time, so that's a pity, because I cannot analyze the problem that I had before. But giving it another try certainly is worth it.
This worked for me!rgroothuis wrote: ↑Sunday 01 November 2020 21:36 What is the best way to get Nest support into Domoticz? Which plugin? Suggestions?
Is this still working for you? Mine stopped working halfway August and nothing seems to workBasssment wrote: ↑Sunday 01 November 2020 22:18This worked for me!rgroothuis wrote: ↑Sunday 01 November 2020 21:36 What is the best way to get Nest support into Domoticz? Which plugin? Suggestions?
Read all the lines verry closely!
Yes still werking. Possibly you need to renew your cookie and auth key. Then it Will work again.tinushigh wrote: ↑Saturday 07 November 2020 19:37Is this still working for you? Mine stopped working halfway August and nothing seems to workBasssment wrote: ↑Sunday 01 November 2020 22:18This worked for me!rgroothuis wrote: ↑Sunday 01 November 2020 21:36 What is the best way to get Nest support into Domoticz? Which plugin? Suggestions?
https://github.com/rolandbreedveld/nest-api![]()
