Problem connecting to Evohome Web API
For Evohome related questions in Domoticz
philips
Re: Problem connecting to Evohome Web API
Post by philips »
Anyone, please ?
Logging through website works OK.
In Domoticz (2020.2) when trying to log on to Web API of the Evohome wifi version (this one: ATC928G3027) I keep on getting in Domoticz logs this:
2020-09-16 11:58:47.472 Status: (Evohome) connect to Evohome server
2020-09-16 11:58:49.069 Error: (Evohome) retrieve installation info returned message: Request was bad formatted or cannot find required ID parameter in the URL.
2020-09-16 11:58:49.069 Error: (Evohome) failed to retrieve installation info from server
2020-09-16 11:59:59.112 Error: (Evohome) retrieve installation info failed with message: Timeout was reached
and no new devices appear.
I've recreated the account but without success. I've also gave permission to a second account and tried logging through that one but also without an success.
Thanks for help !
Raspberry Pi 4 2GB
ichipek
Post by ichipek »
Hi Guys,
Brand new: RPi and Domoticz user but the problem seem to be old...
 2020-10-01 08:48:14.395 Status: New sensors allowed for 5 minutes...
2020-10-01 08:48:24.636 Status: (Evohome) Worker stopped...
2020-10-01 08:48:24.637 Status: (Evohome) Worker started...
2020-10-01 08:48:34.638 Status: (Evohome) connect to Evohome server
2020-10-01 08:48:35.925 Error: (Evohome) retrieve user account info failed with message: Values provided by API aren't supported by client or field filled by client is not supported.
2020-10-01 08:50:05.933 Status: (Evohome) connect to Evohome server
2020-10-01 08:50:07.262 Error: (Evohome) retrieve installation info returned message: Request was bad formatted or cannot find required ID parameter in the URL.
2020-10-01 08:50:07.262 Error: (Evohome) failed to retrieve installation info from server
2020-10-01 08:51:37.899 Error: (Evohome) retrieve installation info returned message: Request was bad formatted or cannot find required ID parameter in the URL.
2020-10-01 08:53:07.907 Status: (Evohome) connect to Evohome server
2020-10-01 08:53:09.117 Error: (Evohome) retrieve installation info returned message: Request was bad formatted or cannot find required ID parameter in the URL.
2020-10-01 08:53:09.117 Error: (Evohome) failed to retrieve installation info from server .
reloading Honeywell account didn't help also...
philips
Post by philips »
The author of this plugin told me he will not maintain compatibility with Domoticz anymore.
Its sad to say but Domoticz is not working with EvoHome anymore in the API version. Maybe using the HGI80 device and connecting using USB may be a solution but I can't find it anywhere to buy in a price that will economicly make sense. I'm quite dissapointed about this situation and just spent 600E on a system that can't be controlled from Domoticz :(
Raspberry Pi 4 2GB
ichipek
Post by ichipek »
Funny it wasn’t mentioned anywhere or nobody complained it stopped working at some point...
Anyway this sucks.
EoT.
