devices = {
'Arbeitszimmer Flur',
'Arbeitszimmer Wohnzimmer'
local Wand = domoticz.devices('Arbeitszimmer - Wandbeleuchtung')
local Decke = domoticz.devices('Arbeitszimmer - Decke')
local dimLevelWand = 1
local dimLevelDecke = 0
domoticz.log('Device ' .. device.name .. ' was changed. State: ' .. Wand.state, domoticz.LOG_INFO)
if device.state == "B1" then
Wand.toggleSwitch()
if device.state == "B3" then
if Decke.state == 'Off' then
Decke.setState('On')
Decke.setState('Off')
if device.state == "B1L" then
repeat
dimLevelWand = dimLevelWand + 0.01
--domoticz.log('Set ' .. Wand.name .. ' to dimLevel '.. dimLevelWand, domoticz.LOG_INFO)
Wand.dimTo(dimLevelWand)
until dimLevelWand >= 100
elseif device.state == "B1RL" then
if device.state == "B2L" then
repeat
dimLevelWand = dimLevelWand - 0.01
--domoticz.log('Set ' .. Wand.name .. ' to dimLevel '.. dimLevelWand .. '%, after ' .. delay .. ' seconds', domoticz.LOG_INFO)
until dimLevelWand <= 0
elseif device.state == "B2RL" then
I'm having trouble as the script is running too fast and I don't get that slow fade to be able to stop at the desired new level. Usually it's going form 0 to 100 and the same backwards instantly. Is there a way to slow down the script? like a delay() or sleep() without the bad behaviour of sleep or delay?
schwuppdiwupp wrote: Wednesday 02 September 2020 19:23
Hi!
I'm trying to write a script to dim my light using an aqara opple switch.
devices = {
domoticz.log('Device ' .. device.name .. ' was changed. State: ' .. Wand.level, domoticz.LOG_INFO)
Wand.cancelQueuedCommands()
if device.levelName == "B1" then
Wand.toggleSwitch()
elseif device.levelName == "B3" then
elseif device.levelName == "B1L" then
for dimLevel = 1, 100 do
Wand.dimTo(dimLevel).afterSec(dimLevel / 10)
elseif device.levelName == "B2L" then
Wand.dimTo(100 - dimLevel).afterSec(dimLevel/ 10)
devices = {
data = {
lastColor = { initial = 0 }
colors = { 2700, 3500, 5000, 6000, 7000 }
Wand.toggleSwitch()
for dimLevel = Wand.level, 100 do
Wand.dimTo(dimLevel).afterSec(dimLevel / 20)
for dimLevel = 1, (Wand.level-1) do
Wand.dimTo(Wand.level - dimLevel).afterSec(dimLevel / 20)
elseif device.levelName == "B1D" then
--TODO setKelvin
Wand.setKelvin(colors[domoticz.data.lastColor + 1])
domoticz.data.lastColor = domoticz.data.lastColor + 1
elseif device.levelName == "B2D" then
--TODO setKelvin
if domoticz.data.lastColor - 1 < 0 then
domoticz.data.lastColor = 4
Wand.setKelvin(colors[domoticz.data.lastColor - 1])
domoticz.data.lastColor = domoticz.data.lastColor - 1
I'm still strugglin with adjusting my white balance. setKelvin doesn't change anything. guess I'll have to go with setColorBrightness.
Is there a way to get the color the light is set to atm?
schwuppdiwupp wrote: Thursday 03 September 2020 12:52
I'm still struggling with adjusting my white balance. setKelvin doesn't change anything. guess I'll have to go with setColorBrightness.
Wand.setColor(,,,,,,2,255)
Wand.setColor(2,255)
and some other variations
What's the correct way to set temperature?
Thanks for your help
If the devicesubtype is RGBWW you can use the setKelvin method (levels 0..100) but because setKelvin is not a standard command, internally it use a JSON API call. Therefore the cancelQueuedCommand() will not work.
