Dimming with a button (long press event)  [Solved]
schwuppdiwupp
Post by schwuppdiwupp »
Hi!
I'm trying to write a script to dim my light using an aqara opple switch.
		devices = {
			'Arbeitszimmer Flur',
			'Arbeitszimmer Wohnzimmer'
	    local Wand = domoticz.devices('Arbeitszimmer - Wandbeleuchtung')
	    local Decke = domoticz.devices('Arbeitszimmer - Decke')
	    local dimLevelWand = 1
	    local dimLevelDecke = 0
		domoticz.log('Device ' .. device.name .. ' was changed. State: ' .. Wand.state, domoticz.LOG_INFO)
		if device.state == "B1" then
		  Wand.toggleSwitch()
		if device.state == "B3" then
		    if Decke.state == 'Off' then
                    Decke.setState('On')
                    Decke.setState('Off')
		if device.state == "B1L" then
		    repeat
		        dimLevelWand = dimLevelWand + 0.01
                --domoticz.log('Set ' .. Wand.name .. ' to dimLevel '.. dimLevelWand, domoticz.LOG_INFO)
		        Wand.dimTo(dimLevelWand)
	        until dimLevelWand >= 100
        elseif device.state == "B1RL" then
        if device.state == "B2L" then
		    repeat
		        dimLevelWand = dimLevelWand - 0.01
                --domoticz.log('Set ' .. Wand.name .. ' to dimLevel '.. dimLevelWand .. '%, after ' .. delay .. ' seconds', domoticz.LOG_INFO)
	        until dimLevelWand <= 0
        elseif device.state == "B2RL" then
I'm having trouble as the script is running too fast and I don't get that slow fade to be able to stop at the desired new level. Usually it's going form 0 to 100 and the same backwards instantly. Is there a way to slow down the script? like a delay() or sleep() without the bad behaviour of sleep or delay?
Any help would be appreciated!
Re: Dimming with a button (long press event)
schwuppdiwupp wrote: Wednesday 02 September 2020 19:23 Hi!
A solution could look like
        devices = {
        domoticz.log('Device ' .. device.name .. ' was changed. State: ' .. Wand.level, domoticz.LOG_INFO)
        Wand.cancelQueuedCommands()
        if device.levelName == "B1" then
          Wand.toggleSwitch()
        elseif device.levelName == "B3" then
        elseif device.levelName == "B1L" then
            for dimLevel = 1, 100 do
                Wand.dimTo(dimLevel).afterSec(dimLevel / 10)
        elseif device.levelName == "B2L" then
                Wand.dimTo(100 - dimLevel).afterSec(dimLevel/ 10)
schwuppdiwupp
Re: Dimming with a button (long press event)  [Solved]
Thank you very much! I have a little lag but it's working now!
        devices = {
    data = {
        lastColor = { initial = 0 }
        colors = { 2700, 3500, 5000, 6000, 7000 }
          Wand.toggleSwitch()
            for dimLevel = Wand.level, 100 do
                Wand.dimTo(dimLevel).afterSec(dimLevel / 20)
            for dimLevel = 1, (Wand.level-1) do
                Wand.dimTo(Wand.level - dimLevel).afterSec(dimLevel / 20)
        elseif device.levelName == "B1D" then
            --TODO setKelvin
            Wand.setKelvin(colors[domoticz.data.lastColor + 1])
            domoticz.data.lastColor = domoticz.data.lastColor + 1
        elseif device.levelName == "B2D" then
            --TODO setKelvin
            if domoticz.data.lastColor - 1 < 0 then
                domoticz.data.lastColor = 4
            Wand.setKelvin(colors[domoticz.data.lastColor - 1])
            domoticz.data.lastColor = domoticz.data.lastColor - 1
I'm still strugglin with adjusting my white balance. setKelvin doesn't change anything. guess I'll have to go with setColorBrightness.
Is there a way to get the color the light is set to atm?
schwuppdiwupp wrote: Thursday 03 September 2020 12:52 I'm still struggling with adjusting my white balance. setKelvin doesn't change anything. guess I'll have to go with setColorBrightness.
        Wand.colorTable = Wand.getColor()
        domoticz.utils.dumpTable( Wand.colorTable )
Will show the current color attributes of device Wand.
What do you want to do with this color information?
schwuppdiwupp
2 options, didn't decide, which way to go:
  • same dimming option as for brightness
  • use a list with defined values and jump through the list
Thanks to your help I get the values I'd like but how do I set the colortemp correctly?
I tried some variations but always keep getting errors.
Wand.setColor(,,,,,,2,255)
Wand.setColor(2,255)
and some other variations
What's the correct way to set temperature?
Thanks for your help
schwuppdiwupp wrote: Thursday 03 September 2020 21:00 2 options, didn't decide, which way to go:
If the devicesubtype is RGBWW you can use the setKelvin method (levels 0..100) but because setKelvin is not a standard command, internally it use a JSON API call. Therefore the cancelQueuedCommand() will not work.
Check the dzVents wiki and API / JSON wiki pages
Users browsing this forum: hemant5400z and 1 guest
