Timer function  [Solved]
oost1346
Timer function
Post by oost1346 »
Hi guys,
I'm new to dzVents so need some help :)
I want to create an function which counts the minutes a certain switch is on and want to put the minutes in a variable (so I can use it in a blockly)
Can you experts give me an example of such code so I can play with it?
Thanks in advance....
Bob
Re: Timer function
oost1346 wrote: Sunday 30 August 2020 10:32 I want to create an function which counts the minutes a certain switch is on and want to put the minutes in a variable (so I can use it in a blockly)
This should do it
return
    on =
        timer =
            'every minute',
    execute = function(dz)
        local myDevice = dz.devices('mySwitch')
        local myVar = dz.variables('mySwitch active minutes')
        if myDevice.active then
            myVar.set(myDevice.lastUpdate.minutesAgo)
        elseif myVar.value ~= 0 then
            myVar.set(0)
oost1346
Re: Timer function  [Solved]
Post by oost1346 »
Thanks waaren....works like a charm :)
Bob
