How to manipulate reported values?
Kurtsejr
- Domoticz version: 2020.2
I have a Samsung SmartThings Outlet that works with my ZiGate gateway. The Outlet can monitor power usages in Watt. I have tested with a unit that I know usages 40W, but in Domoticz this is reported as 400 watt. This means that I need to divide by 10, how do I do this in Domoticz or in ZiGate?
Re: How to manipulate reported values?
It might required some adjustments in the integration.
Can you send me the export.json as specified I. This page https://github.com/pipiche38/Domoticz-Z ... -device.md
Kurtsejr
Thanks! the export.json is attached
/Kurt
/Kurt
- export.zip
- (4.31 KiB) Downloaded 78 times
I've check the following device: "Græsrobot tænd/sluk og energiforbrug"
On the file you provided I'm getting 5.3 Watts (on the last measurement). Is that incorrect ?
Could you move to beta-4.10.108 ?
Then , I would recommend to
1/ remove the existing widgets created for this device
2/ redo the pairing
=> You should then get Power, Meter, Plug and Voltage
git pull
git checkout beta
git pull1/ remove the existing widgets created for this device
2/ redo the pairing
Kurtsejr
Have done as you suggest, update to the beta version and then delete the existing widget and reboot my Rasp. It seems to be working, it recharge and the power usages is a bit high, but now I also have a "," in the reading
. Check again tomorrow and return.
The Zigate web is different, there is no traffic overview in the main Zigate web page, but I can find my devices under management, and the topology is also ok.
What do you mean by Zigate web is different ? can you share a screenshoot
Kurtsejr
Hi pipiche
Data is now as expected, super and great!
Attached is the Dashboard, no change if I hit the refresh
TKurt
TKurt
- zigate dashboard.PNG (160.66 KiB) Viewed 1654 times
Excellent, if you are happy, i'm too.
Would you mind to register your device to the Zigbee compatible Database, so we can track the Zigate compatibility ?
https://zigbee.blakadder.com/
Kurtsejr
Of cause, done.
What about the dashboard? - will there be an update?
/Kurt
/Kurt
For the dashboard, can you enable the Console mode from your browser (usally you need to press F12) and then select Console, do a Refresh and check if there is any errors ?
Could you try with an other browser ?
Kurtsejr
Sorry for the late answer, have tested Chrome and Edge, in Console window(tap) no errors - sorry.
Kurtsejr
Will it be OK to move to stable release, version 4.9.005 - meaning that my measures will still be working?
Kurtsejr
Have discovered this: the "frontpage" has no errors in "Console mode", but when i enter Settings in the menu I get this:
Hope it's useful
plus a lot more as above.
Hope it's useful
- Spoiler: show
Can you try to clear the cache ?
Kurtsejr
Sorry no impact, if I clear the cache
/Kurt
/Kurt
ben92
HI,
Can u open the console when you are on the dashboard, hit Refresh buton.
Take a picture of the console tab and the network tab please.
on the network tab, you will see the data that passes between the plugin and your browser.
Check that the call to "plugin-stat" brings you data by clicking on the line and going to the preview tab.
On Chrome browser please.
