PWM with an arduino
doodoovane
Domoticz version: v2.3530
PWM with an arduino
Post by doodoovane »
Hello guys ,
I am trying to integrate an arduino nano-based assembly into domoticz which allows me to manage the speed rotation of a fan (PWM) from 0 to 100.
The arduino and the Raspberry pi are connected via USB and I already have a python script which allows me to manage it from the terminal.
For the moment, in domoticz I have a virtual switch (dimmer).
I need help for a script that varies the speed of my fan according to my virtual ...
The script I am using on the RPI is posted below.
[Raspberry pi fan control and monitoring with bash](https://www.domoticz.com/wiki/Raspberry_pi_fan_control_and_monitoring_with_bash)
here is the one on the arduino:
const byte OC1A_PIN = 9;
const byte OC1B_PIN = 10;
const word PWM_FREQ_HZ = 25000; //Adjust this value to adjust the frequency
const word TCNT1_TOP = 16000000/(2*PWM_FREQ_HZ);
byte in = 0;
void setup() {
  pinMode(OC1A_PIN, OUTPUT);
  Serial.begin(9600);
  Serial.println("Demarage du PWM"); // so I can keep track of what is loaded
  // Clear Timer1 control and count registers
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
  // Set Timer1 configuration
  // COM1A(1:0) = 0b10   (Output A clear rising/set falling)
  // COM1B(1:0) = 0b00   (Output B normal operation)
  // WGM(13:10) = 0b1010 (Phase correct PWM)
  // ICNC1      = 0b0    (Input capture noise canceler disabled)
  // ICES1      = 0b0    (Input capture edge select disabled)
  // CS(12:10)  = 0b001  (Input clock select = clock/1)
  TCCR1A |= (1 << COM1A1) | (1 << WGM11);
  TCCR1B |= (1 << WGM13) | (1 << CS10);
  ICR1 = TCNT1_TOP;
void loop() {
if (Serial.available()) {       // Check if there's data
    char buf[10];
    int in = Serial.readBytesUntil('\n', buf, sizeof buf - 1);
    buf[in]=0;
    in = atoi(buf);
    if (in > 100)
      in = 100;
    Serial.println(in);// Pass the value of "in" to the pin}
    setPwmDuty(in); //Change this value 0-100 to adjust duty cycle
void setPwmDuty(byte duty) {
  OCR1A = (word) (duty*TCNT1_TOP)/100;
doodoovane
Re: PWM with an arduino
Any help? :idea:
P.S: English is not my native language do not hesitate to ask for more explanations if it is not clear.
doodoovane
I now got a solution but nothing to do with python so here the new thread https://www.domoticz.com/forum/viewtopi ... 42&t=33772
