- Spoiler: show
More info here: https://dashticz.readthedocs.io/en/beta ... tom-graphs
Great to hear that fixed itwebrazor wrote: Monday 20 July 2020 10:35 i missed the device idx for the custom data, did not need that before.
thanks for your help
columns[2] = {
blocks : ['20_3'],
width: 6
//PVoutput.org grafiek
blocks['graph_20'] = {
devices: [20],
title: 'Zonnepanelen',
graph: 'bar',
beginAtZero: true,
datasetColors: ['yellow'],
debugButton: true,
graphTypes: ['v'],
legend: {
'v_20': 'Power generation',
'c_20': 'Power Consumed',
}Probably the default graph settings are used, since as block you select '20_3' while your graph is just '_20'.Chris12 wrote: Tuesday 18 August 2020 8:54 Hi, Im using latest beta and just started with dashticz but somehow I cannot get any bar graph? I also tried the master version yesterday but suffered the same problem. Th graph is still the default, with a line, no title or legend as well.
So I guess I'm missing a part somewhere?
My code:Code: Select all
columns[2] = { blocks : ['20_3'], width: 6 } //PVoutput.org grafiek blocks['graph_20'] = { devices: [20], title: 'Zonnepanelen', graph: 'bar', beginAtZero: true, datasetColors: ['yellow'], debugButton: true, graphTypes: ['v'], legend: { 'v_20': 'Power generation', 'c_20': 'Power Consumed', } }
blocks['20_3'] = {
popup: 'graph_20'
}When I added this part in my config file, the result was that some of my graphs and blocks disappeared after an refresh of dashticz.HansieNL wrote: Wednesday 19 August 2020 21:27 @Chris12 Have you tried to define the default unit for gas? See: https://github.com/Dashticz/dashticz/b ... formatting
Can you post the Domoticz json output of the Youless device, then I'll check:
http://domoticz-ip:port/json.htm?type=devices&rid=123
To be clear the block itself shows the m3 unit correct like "Gas Vandaag 0,40 m3", but when clicking on the block the graph shows kWh in the left upper corner like: Gasverbruik = 0,400 kWhLokonli wrote: Friday 21 August 2020 11:27Can you post the Domoticz json output of the Youless device, then I'll check:
replace 123 with your Domoticz device id.Code: Select all
"ActTime" : 1598003442,
"AstrTwilightEnd" : "23:10",
"AstrTwilightStart" : "04:17",
"CivTwilightEnd" : "21:29",
"CivTwilightStart" : "05:58",
"DayLength" : "14:17",
"NautTwilightEnd" : "22:15",
"NautTwilightStart" : "05:12",
"ServerTime" : "2020-08-21 11:50:42",
"SunAtSouth" : "13:43",
"Sunrise" : "06:35",
"Sunset" : "20:52",
"app_version" : "2020.2 (build 12213)",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Counter" : "561154.500",
"CounterToday" : "0.400 m3",
"CustomImage" : 0,
"Data" : "561154.500 m3",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 15,
"HardwareName" : "YouLess LS110 (MinderGas.nl)",
"HardwareType" : "YouLess Meter with LAN interface",
"HardwareTypeVal" : 6,
"HaveTimeout" : false,
"ID" : "80",
"LastUpdate" : "2020-08-21 11:50:34",
"Name" : "YouLess LS110 (Gas)",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" :
0
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "YouLess counter",
"SwitchTypeVal" : 1,
"Timers" : "false",
"Type" : "YouLess Meter",
"TypeImg" : "counter",
"Unit" : 1,
"Usage" : "0 m3",
"Used" : 1,
"ValueQuantity" : "",
"ValueUnits" : "",
"XOffset" : "0",
"YOffset" : "0",
"idx" : "346"
"status" : "OK",
"title" : "Devices"
}I see that the Youless devices get kWh by default in the graph header.Chris12 wrote: Friday 21 August 2020 11:53To be clear the block itself shows the m3 unit correct like "Gas Vandaag 0,40 m3", but when clicking on the block the graph shows kWh in the left upper corner like: Gasverbruik = 0,400 kWhLokonli wrote: Friday 21 August 2020 11:27Can you post the Domoticz json output of the Youless device, then I'll check:
Here's the output:
{ "ActTime" : 1598003442, "AstrTwilightEnd" : "23:10", "AstrTwilightStart" : "04:17", "CivTwilightEnd" : "21:29", "CivTwilightStart" : "05:58", "DayLength" : "14:17", "NautTwilightEnd" : "22:15", "NautTwilightStart" : "05:12", "ServerTime" : "2020-08-21 11:50:42", "SunAtSouth" : "13:43", "Sunrise" : "06:35", "Sunset" : "20:52", "app_version" : "2020.2 (build 12213)", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Counter" : "561154.500", "CounterToday" : "0.400 m3", "CustomImage" : 0, "Data" : "561154.500 m3", "Description" : "", "Favorite" : 1, "HardwareID" : 15, "HardwareName" : "YouLess LS110 (MinderGas.nl)", "HardwareType" : "YouLess Meter with LAN interface", "HardwareTypeVal" : 6, "HaveTimeout" : false, "ID" : "80", "LastUpdate" : "2020-08-21 11:50:34", "Name" : "YouLess LS110 (Gas)", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "YouLess counter", "SwitchTypeVal" : 1, "Timers" : "false", "Type" : "YouLess Meter", "TypeImg" : "counter", "Unit" : 1, "Usage" : "0 m3", "Used" : 1, "ValueQuantity" : "", "ValueUnits" : "", "XOffset" : "0", "YOffset" : "0", "idx" : "346" } ], "status" : "OK", "title" : "Devices" }
Yes that works! One solved... 4 to goI see that the Youless devices get kWh by default in the graph header.
Can you test by adding format:0 to the block definition of the graph?
This should keep the current unit (which is m3)
For 1:Chris12 wrote: Friday 21 August 2020 12:22 @Lokonli, maybe you know how to solve some other things noticed in the graphs I have as well.
1. I have a multigraph which shows the solar power generation (bar graph) and the temperature (line graph), how can I make sure the line graph is on top of the bar graph? as it is now sometimes behind the bar graph.
2. In a graph when hovering over the values, I can see a pop up with for example the value of the temperature.
How can I get a unit behind that value? So is shows for example 25 C or 1.789 kWh, instead of just the numbers?
3. How can I make sure my grahps have an overview of 00:00 till 23:59, instead of a 24h overview (which is not handy for solar power generation graphs for example).
4. I also have 2 graphs in dashticz based on a Dummy Device out of domoticz, which show me no values in the graph. Looking in domoticz is shows me values in the graphs. The created block in dashticz shows the latest value. Also this block does not have a popup graph although that is configured.
//Zonnepanelen opbrengst + temperatuur BME280
blocks['Zonnepanelen-graph'] = {
debugButton: true,
iconColour: ['green'],
title: ['Zonnepanelen'],
graph: ['bar','line'],
devices: [20,288],
height: '200px',
width: 12,
aggregate: 'sum',
custom : {
"24 uur": {
range: 'day',
filter: 'day',
data: {
Opbrengst: 'd.v_20',
Temperatuur: 'd.te_288'
"Maand": {
range: 'month',
filter: 'month',
data: {
"Jaar wk": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
"Jaar mnd": {
range: 'year',
filter: 'year',
groupBy: 'month',
data: {
legend: false,
beginAtZero: true,
refresh: 60,
drawOrderDay: ['v_20','te_288'],
drawOrderLast: ['v_20','te_288'],
drawOrderMonth: ['v_20','te_288'],
datasetColors:['lightgreen','Red']
}Code: Select all
"ActTime" : 1598035603,
"ServerTime" : "2020-08-21 20:46:43",
"Sunset" : "20:52",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "6600 Watt",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 13,
"HardwareName" : "Daikin-Slaapkamer-Verbruik",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"ID" : "82330",
"LastUpdate" : "2020-08-21 20:45:02",
"Name" : "Daikin-Slaapkamer (Verbruik)",
"PlanID" : "0",
"PlanIDs" :
0
"SubType" : "Electric",
"Timers" : "false",
"Type" : "Usage",
"TypeImg" : "current",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "330"
"status" : "OK",
"title" : "Devices"
}Code: Select all
//Airco Slaapkamer
blocks['AC-Slaapkamer'] = {
width:4,
icon: 'fas fa-fan',
idx: '330',
title: 'Daikin Slaapkamer',
graph: true,
popup: 'AC_Slaapkamer_graph'
blocks['AC_Slaapkamer_graph'] = {
debugButton: true,
title: ['Daikin Slaapkamer'],
graph: ['bar'],
devices: [330],
height: '200px',
width: 6,
custom : {
"24 uur": {
range: 'day',
filter: '24 hours',
data: {
Verbruik: 'd.v_330'
"Maand": {
range: 'month',
filter: 'month',
data: {
Verbruik: 'd.v_330'
"Jaar wk": {
range: 'year',
filter: 'year',
groupBy: 'week',
data: {
Verbruik: 'd.v_330'
"Jaar mnd": {
range: 'year',
filter: 'year',
groupBy: 'month',
data: {
Verbruik: 'd.v_330'
legend: false,
beginAtZero: true,
datasetColors:['orange']
