Python Plugin : Broadlink
- wizardnl
Re: Python Plugin : Broadlink
when running the setup i get the following error
File "setup.py", line 223
print("\r>> Bytes downloaded -->" + state + str(leng) + state, end='', flush =True)
SyntaxError: invalid syntax
zak45
- Domoticz version: V2024.4
please check that :wizardnl wrote: Monday 17 August 2020 19:32 when running the setup i get the following error
Be sure that your active python version is > 3.4
this mean: python --version
should give output e.g. python 3.x.x and not python 2.x.x
see this link https://www.domoticz.com/wiki/Using_Python_plugins
or this one : https://linuxconfig.org/how-to-change-f ... bian-linux
DrMacabre
- Domoticz version: 4.11590
Gret work. How do import my commands from the official app ?
zak45
Thanks.DrMacabre wrote: Thursday 20 August 2020 11:15 Gret work. How do import my commands from the official app ?
Import work only from e-control app.
if you use it, see this link :
https://www.domoticz.com/wiki/Plugins/B ... RM2_Device
DrMacabre
Oh ok, like the old version then. I thought there was something else. What’s the « upload » « import » and « econtrol » buttons for ?zak45 wrote: Thursday 20 August 2020 11:59Thanks.DrMacabre wrote: Thursday 20 August 2020 11:15 Gret work. How do import my commands from the official app ?
I got a broadlink bad key when trying to connect to the web interface/import
zak45
1:DrMacabre wrote: Thursday 20 August 2020 15:49
upload : allow to upload file
import : read ini files from import directory and try to generate ini files to be used by the plugin
econtrol: generate ini files into import folder from e-control database files ( the 3 files required )
2: ????
DrMacabre
I want to import the 3 files, in the instructions, it says connect to http://mydomoticzIP:9000/importzak45 wrote: Thursday 20 August 2020 16:162: ????DrMacabre wrote: Thursday 20 August 2020 15:49
That’s where i get broadlink bad key onscreen message.
Is there another way to upload the 3 files from the app to the plugin ?
DrMacabre
Ok the 3 files are now in /ini/ but from there, what should i do ?
zak45
the files need to be under import folder ....DrMacabre wrote: Thursday 20 August 2020 17:05 Ok the 3 files are now in /ini/ but from there, what should i do ?
Just click on e-control button, should create all ini files for import. (name start by IMP-)
If all is ok, click on import and should create ini files that will be under plugin control after.
I let the old WiKi for reference only, but all is now into the admin file (including the file transfert - upload button)
DrMacabre
Sorry, i still mostly get it, i have now a bunch of ini files in /import/ and some broadlink ini files in /ini/ but i don’t remember how to turn this into devices. I recently lost my whole domoticz and had to start from scratch but with time i totally forgot the process to make this plugin works. All i can remember is having all my buttons from e-control showing up as devices in domoticz before i crashed
zak45
No problem.DrMacabre wrote: Thursday 20 August 2020 19:16 Sorry, i still mostly get it, i have now a bunch of ini files in /import/ and some broadlink ini files in /ini/ but i don’t remember how to turn this into devices. I recently lost my whole domoticz and had to start from scratch but with time i totally forgot the process to make this plugin works. All i can remember is having all my buttons from e-control showing up as devices in domoticz before i crashed![]()
This is a new plugin with new logic.
Now, Domoticz device is not automatically created, you select the ini file you want and click on create device.
- wizardnl
We execute this command : sudo -H python -m pip install python-broadlink-master/.zak45 wrote: Monday 17 August 2020 21:07please check that :wizardnl wrote: Monday 17 August 2020 19:32 when running the setup i get the following error
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Processing ./python-broadlink-master
Requirement already satisfied: cryptography>=2.1.1 in /usr/lib/python2.7/dist-packages (from broadlink==0.14.1) (2.6.1)
Building wheels for collected packages: broadlink
Running setup.py bdist_wheel for broadlink ... done
Stored in directory: /root/.cache/pip/wheels/22/00/bf/e3f9625cfd51378837b1b45ad17d219988821a8bf1c810e9d6
Successfully built broadlink
Installing collected packages: broadlink
Found existing installation: broadlink 0.14.1
Uninstalling broadlink-0.14.1:
Successfully uninstalled broadlink-0.14.1
Successfully installed broadlink-0.14.1
We have installed : python-broadlink-master/.
________________________________________
# We do necessary modifications depend of Platform
put *.py files executable (+x) OK
put *.sh files executable (+x) OK
Checking installation ....
Successfully imported googletrans
Error importing translate
Thank this was indeed my error change my python version now during the setup i get a "Error importing translate" error sorry i am a noob with these things
zak45
please type in term session : python --versionwizardnl wrote: Thursday 20 August 2020 23:06 We execute this command : sudo -H python -m pip install python-broadlink-master/.
and provide your output ....
debian@debian10:~$ python --version
Python 3.7.3
debian@debian10:~$
zak45
@wizardnl
I need also this :
sudo -H python -m pip list
I need also this :
- wizardnl
pi@raspberrypi:~ $ python --version
Python 3.8.0
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo -H python -m pip list
Package Version
asn1crypto 0.24.0
broadlink 0.14.1
certifi 2018.8.24
chardet 3.0.4
configparser 3.5.0b2
cryptography 2.6.1
entrypoints 0.3
enum34 1.1.6
idna 2.6
ipaddress 1.0.17
keyring 17.1.1
keyrings.alt 3.1.1
pip 18.1
pycrypto 2.6.1
PyGObject 3.30.4
pyOpenSSL 19.0.0
pyxdg 0.25
requests 2.21.0
requests-toolbelt 0.9.1
RPi.GPIO 0.7.0
SecretStorage 2.3.1
setuptools 40.8.0
six 1.12.0
urllib3 1.24.1
wheel 0.32.3
pi@raspberrypi:~ $
Python 3.8.0
pi@raspberrypi:~ $
Package Version
asn1crypto 0.24.0
broadlink 0.14.1
certifi 2018.8.24
chardet 3.0.4
cryptography 2.6.1
entrypoints 0.3
enum34 1.1.6
idna 2.6
ipaddress 1.0.17
keyring 17.1.1
keyrings.alt 3.1.1
pip 18.1
pycrypto 2.6.1
PyGObject 3.30.4
pyOpenSSL 19.0.0
pyxdg 0.25
requests 2.21.0
RPi.GPIO 0.7.0
SecretStorage 2.3.1
setuptools 40.8.0
six 1.12.0
urllib3 1.24.1
wheel 0.32.3
pi@raspberrypi:~ $
zak45
Looks ok....wizardnl wrote: Thursday 20 August 2020 23:32 pi@raspberrypi:~ $ python --version
Python 3.8.0
pi@raspberrypi:~ $
Package Version
asn1crypto 0.24.0
broadlink 0.14.1
pi@raspberrypi:~ $
Do you install with "python setup.py" or "sudo python setup.py" ???
- wizardnl
python setup.pyzak45 wrote: Thursday 20 August 2020 23:38Looks ok....wizardnl wrote: Thursday 20 August 2020 23:32 pi@raspberrypi:~ $ python --version
Python 3.8.0
pi@raspberrypi:~ $
Package Version
asn1crypto 0.24.0
broadlink 0.14.1
pi@raspberrypi:~ $
zak45
python setup.pywizardnl wrote: Thursday 20 August 2020 23:42 Do you install with "python setup.py" or "sudo python setup.py" ???
[/quote]
do with : sudo python setup.py
- wizardnl
[/quote]
pi@raspberrypi:~/domoticz/plugins/broadlink $ sudo python setup.py
print("\r>> Bytes downloaded -->" + state + str(leng) + state, end='', flush=True)
zak45
So, come back error occur with wrong python version ...wizardnl wrote: Thursday 20 August 2020 23:47 pi@raspberrypi:~/domoticz/plugins/broadlink $ sudo python setup.py
and when you do : sudo python --version ??
Users browsing this forum: willemd and 1 guest
