In latest beta FontAwesome has been updated to 5.14.0
Dashticz 3.5.2 Beta
Re: Dashticz 3.5.2 Beta
Many thanks for that !
Hi (AGAIN sorry for that)
I have installed a water meter in domoticz.
I want to show this in domoticz. It shows only the total m3 i used, but not the daily. 0.025m3
I used the codes _1 _2 _3 but doesnt show the other values
As you can see you see only the total stats.
Here is the json output of domoticz
Could it be that the counter incremental not is coded in dashtics ?
Defining the value and unit parameter might work for water devices. Try the following: (sorry, can't test myself at the moment
blocks[11831] = {
value: '<CounterToday>',
unit: '',
it works, it only converted to 0,03 m3 instead of 0,025m3. So i will see only the 10 20 30 40 50 liters.
Is it possible to calculate it to liters ?
edit: tried with the format option mentioned on the docs below. Button won't change and stay the same
https://dashticz.readthedocs.io/en/beta ... formatting
Try adding the following to the block definition:Vomera wrote: ↑Thursday 13 August 2020 16:06
decimals: 3
Cool it works, i tried also to convert it to liters, but it is impossible (tried also some graph parameters hoping that it will work only on block parameter)
- Target OS: -
do you know if the garbage provider of Almere is changed? Since two weeks it shows Black (zwart) for GFT. Thanks in advance.
First disable garbage name mapping, by adding the following to CONFIG.js:madradrakie wrote: ↑Wednesday 19 August 2020 21:36 do you know if the garbage provider of Almere is changed? Since two weeks it shows Black (zwart) for GFT. Thanks in advance.
config['garbage_use_names'] = 0;
In the default name mapping DUO doesn't exist. You can add the mapping from DUO to Gft by redefining garbage_mapping in CONFIG.js as follows:
config['garbage_mapping'] = {
rest: ['grof', 'grey', 'rest', 'grijs', 'grijze'],
gft: [
'gft',
'tuin',
'refuse bin',
'green',
'groen',
'Biodégradables',
'snoei',
'duo'
pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
kca: ['chemisch', 'kca', 'kga'],
brown: ['brown', 'verre'],
black: ['black', 'zwart'],
milieu: ['milieu'],
kerstboom: ['kerst'],
aeea: ['aeea'],
textiel: ['textiel'],
sorti: ['sorti'],
config['garbage_use_names'] = 1;
- Target OS: -
thanks Lokonli for your help again. I will remember this trick for the next time the module is not working.
