I added a proximity sensor to the water meter and plugged it in the wemos that reads the electricity and gas meter.
I added a dummy incremental counter and on utility tab changed it to water. First issue is that it shows 10 liter steps instead of the liters to sensor counts. (checked with a 12lt bucket)
Second issue is I'd like to see a real graph of the water usage in minutes instead of every hour. Now it's just a big chunk of cooking toilet and shower in a single hour.
How do I change the graph to minutes? The wemos is set to update every minute as well.
Water usage shown as hours, I'd like to see in minutes
Jasper79
- Domoticz version: 2020.2
Re: Water usage shown as hours, I'd like to see in minutes
No one knows if it's possible to get a different graph for water just like electricity for example?
- Brutus
Hi,Jasper79 wrote: Thursday 20 August 2020 15:08 Hi,
What sensors end software did you use for the Wemos?
Greetings Brutus.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
Jasper79
Espeasy icm deze BX versie
€ 2,35 8%OFF | LJ12A3-4-Z/BX LJ12A3-4-Z/BY New Inductive Proximity Sensor Detection Switch NPN DC 6-36V for Arduino
https://a.aliexpress.com/_B1Tqr9
- Brutus
Thnx Will look in to that. Did you manage to change solve the Liter problem?Jasper79 wrote: Saturday 26 September 2020 13:22 Espeasy icm deze BX versie
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
Jasper79
Nope, no one has come up with a solution yet
