Problem including z-wave devices
CyberE
Post by CyberE »
Hardware: RPi 3
Controller: AEON Labs ZW090 Z-Stick Gen5 EU
After a fresh install of Domoticz 2020.2, I am no longer able to include z-wave devices. Putting it in "find-mode" and pressing the appropriate buttons on the sensor, does not make it include. When I used the pre-2020 version of Domoticz, there was no problem. Including went just fine.
When doing so, there are no errors visible in any log (that I know of), and the status log in Domoticz does not seem all that strange to me.
2020-08-10 14:01:01.451 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2020-08-10 14:01:01.516 Status: OpenZWave: Starting...
2020-08-10 14:01:01.516 Status: OpenZWave: Version: 1.6-1033-g3661f170
2020-08-10 14:01:04.362 Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
2020-08-10 14:01:04.362 Status: OpenZWave: ManufacturerSpecificDB Ready
2020-08-10 14:01:04.541 Status: OpenZWave: Driver Ready
CyberE
Re: Problem including z-wave devices
Post by CyberE »
So I found the problem, well not the root cause, but a work around. It looks like the controller is remembering the old z-wave devices from before the fresh install, although they do not show up in any interface or even tools like "PC Programmer".
In order to get the devices included again, I first had to unplug the z-wave stick from the Pi. Hold the button to trigger "exclusion-mode", orange LED ring is now blinking. Pressing the in-/exclude button on the z-wave device. The led ring on the controller is now blue for a moment. Then to include it again, I press the controller button again, swiftly, so it goes into "inclusion-mode", you can tell by the blue blinking LED ring. Then again, pressing the in-/exclude button on the z-wave device.
After that part is done, I'm going to the hardware-tab in the Domoticz web-interface. This now shows a strange line, like "node connection something something" but not the actual device. In order for it to work properly, I have to choose the "Include node" option and again press the in-/exclude button on the z-wave device. Now it comes up as the correct device and I can use it like I normally did.
I hope this helps if you experiencing the same issues and maybe there is somebody how can explain the logic behind this, because I surely can't.
