How presentation works?
iguaan
Post by iguaan »
I have created a weather sensor which has hum, temp, baro, predicition and lux.
Aslo i have attached there another ds temp sensor (for node internal temp for safety, since it's ac powered).
Problem is that when i update fw over ota or reboot node, it'll occasionally detect sensors all mixed up:
temp/hum, temp, baro/temp/hum etc... Also when it does that, not all the data will be updated on combined sensros.
Is there a way to present the sensors to domticz so, that it recognises 1 combined weather sensor and then others.
I have tried with all different Sensor ID's 1-4, lux id5 and internal temp id6.
Also tried with giving same sensor ID number to hum, temp, baro and predicition.
Occasionally when Domoticz detects it as a combined sensor, it doesn't update all values after initial value has been sent.
If i monitor the data on myscontroller, all the variables are updating on the node.
What is the correct way to present sensors to domoticz so that i can get one weather data sensor and other data so, that domoticz won't mix them up.
Edit: Maybe there is some other manual besides on the website or wiki that i can look into?
iguaan
Re: How presentation works?
Post by iguaan »
Sent from my MI 9 using Tapatalk
iguaan
Post by iguaan »
Anyone?
FireWizard
Post by FireWizard »
iguaan
Post by iguaan »
Couldn't find anything helpful. Mostly about http API but this part is handled in gateway which is compiled by mysensors crew and I don't want to interfere there.
