Timerplan switch button
ocean123
Post by ocean123 »
How can I make a switch button to set vacation-timerplan on and off. The only way I found at the moment is by settings to switch between two plans. We just want a simple button to switch on/off.
When switch is "on" then follow timer plan X. When switch is "off" follow timer plan Y. We do not want a Google calendar connection.
Does someone has any suggestions how?
In the future there will be a physical button connected to the gpio-pin or by z-wave
felix63
Domoticz version: 2020.1
Re: Timerplan switch button
Post by felix63 »
You can make a virtual switch and attach this action to it:
http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=0
ocean123
Post by ocean123 »
Thanks for your suggestion.
Greats
Ocean
Ron
Domoticz version: 2.2284
Post by Ron »
I was struggeling a little with this, but its not complicated:
Create a dummy switch
Settings dummy switch, On action:
http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=2
Settings dummy switch, Off action:
http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1
ActiveTimerPlan=2 --> Holiday timer plan with ID 2 (Second timer plan with Idx 2)
ActiveTimerPlan=1 --> Default timer plan with ID 1 (Standard/default timer plan with Idx 1)
If switch is on timerplan Holiday/2 is activated, if switch is off timerplan Default/1 is activated.
